Ms 7613 manual
Cpu fan eror
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 61 Answers
If your are seeing this message with a black screen background, i suggest you need a replacement for your fan. for some cases, cleaning your fans with lubricant might work. goodluck!
thanks
Posted on Mar 29, 2014
4 Suggested Answers
Geekman
  • 32281 Answers
SOURCE: i want details for my motherboard ms-7613 ver 1.1
You can get the specifications of this motherboard from this WEB site.
https://h10025.www1.hp.com/ewfrf/wc/document?docname=c02014355&lc=en&dlc=en&cc=us&product=4262655
Posted on Apr 28, 2011
mb350sl
  • 73 Answers
SOURCE: MSI MS-7613 please help i cant find a manual for
This is not the manual (being from HP, it may not be easily available), but it might help you.
https://h10025.www1.hp.com/ewfrf/wc/document?docname=c02014355&lc=en&dlc=en&cc=us&destPage=document&product=4234589
Good Luck!
Posted on Oct 06, 2011
joecoolvette
  • 5660 Answers
SOURCE: ms 7613 ver 1.1
http://bizsupport1.austin.hp.com/bizsupport/TechSupport/Document.jsp?objectID=c01946060&printver=true
View the motherboard photo at the Top, and also the Motherboard layout illustration, at a little over halfway down the page.
1) In the motherboard photo, all the way to the right side. View the Yellowish/Whitish connector, that has two columns of 12 socket holes.
This is where the 24-pin ATX main power cable plugs in.
In the motherboard layout illustration it is labeled - ATX1.
Here is a general example of this power cable, and respective connector on the motherboard,
http://www.playtool.com/pages/psuconnectors/connectors.html#atxmain24
Note that new Power Supply's, generally come with a 20+4-pin ATX main power cable.
This is so it can be used on the older computers that used a 20-pin ATX main power cable, and newer ones that need a 24-pin ATX main power cable.
Do not mix it's extra 4-pin power cable, with the 4-pin ATX +12 Volt power cable.
http://www.playtool.com/pages/psuconnectors/connectors.html#atxmain20plus4
Note the Lock on the side/middle. It has a hook on the end. The hooked end goes over a Tab, on the motherboard's connector.
The Lock works on the same principle as a see-saw on a playground.
You squeeze the top near where the wires come in, and this brings the hooked end away from the Tab, on the motherboard connector.
With the top of the Lock still squeezed in, the power cable is then removed USING the connector. (NOT the wires)
When assured that the power cable is plugged in tightly, and correctly, the hooked end of the Lock will be over the Tab, on the motherboard connector.
2) Look to the left of the Processor socket, and halfway in-between it, and the outside edge of the motherboard.
Whitish 4-socket hole square connector.
This is where the 4-pin ATX +12 Volt power cable plugs in. Power for the Processor. Note that it also has a Lock, with a Tab on the motherboard connector.
In the motherboard layout illustration it is labeled - PWR1
General example of power cable,
http://www.playtool.com/pages/psuconnectors/connectors.html#atx12v4
That's it for the motherboard as for power cables that plug into it.
The rest of the power cables from the Power Supply, plug into the optical drive/s, harddrive, and card reader if used.
4) If your harddrive is an IDE (PATA) unit, it will use a 4-pin standard Peripheral power cable. Same with an optical drive that is an IDE (PATA) unit,
http://www.playtool.com/pages/psuconnectors/connectors.html#peripheral
The computer case fan plugs into SYS_FAN1 connector, which is below the PWR1 connector. You may also have a computer case fan that uses the above power cable.
5) If your Harddrive, or optical drive/s are SATA, they will use a SATA power cable,
http://www.playtool.com/pages/psuconnectors/connectors.html#sata
6) A Card Reader uses a power cable, that is also used for a Floppy Drive.
It is a 4-pin Small Peripheral power cable.
Has the same voltage wires; (Yellow - 12 Volts, Red - 5 Volts), and two Black ground wires, but a smaller connector, than a 4-pin Standard Peripheral power cable,
http://www.playtool.com/pages/psuconnectors/connectors.html#floppy
The front of your computer is the Front Panel.
The area of wires on the motherboard, that the main wires from the Front panel go to, is the Front Panel header.
Although the Front Panel header has NOTHING to do with the Power Supply, I will include it also,
Motherboard positioned in computer case; Processor to the Top, Ram Memory slots to the Right;
The Front Panel header is at the bottom/right of the motherboard.
Black rectangle with 9 contact pins.
In the Motherboard layout illustration, JFP1 is marked under this header.
There are 4 pins across the Top row, 5 pins across the Bottom row.
The pins on the Top row are numbered EVEN.
The pins on the Bottom row are numbered ODD.
Starting on the LEFT side going towards the Right, Top row;
Pins 2, 4, 6, and 8. There is NO Pin 10.
Starting on the LEFT side going towards the Right, Bottom row;
Pins 1, 3, 5, 7, and 9.
A) Pins 1 and 3 are for the HarDDrive activity LED. (Light Emitting Diode)
Pin 1 is for the Positive ( + ) wire.
If the HDD LED is dim when the harddrive is active, switch the wires around.
B) Pins 5 and 7 are for a Reset switch, IF a Reset switch is used.
C) Pin 9 is N/C. Not Connected. Reserved for factory use.
D) Pins 2 and 4 are for the Power On LED.
Pin 2 is for the Positive ( + ) wire.
If the PWR ON LED is dim when the computer is on, switch the wires around.
E) Pins 6 and 8 are for the Power On switch.
F) Again, there is No Pin 10.
For additional questions post in a Comment.
Regards,
joecoolvette
Posted on Aug 16, 2012
Cisco 7613 come in romon1 mode
YOu can get IOS from here
http://www.cisco.com/c/en/us/support/routers/7613-router/model.html#~rdtab1
Look for file in directory after downloading it to router.router# dir flash
Issue command boot flash
Router#boot flash:flename
Jul 23, 2014 | Cisco 7613 Router
Replace battery MS-7613
The battery is round and shiny. Pick up one edge of the battery and slide it out if it's socket. Obtain a replacement with the same numbers or equivalent 3 volt coin cell and slide it back into it's socket. When you reboot, immediately enter BIOS setup and set the correct time and date. Then continue to boot.
Apr 09, 2014 | MSI Hp Iona-gl8e Oem Motherboard Ms-7613...
My msi ms - 7352 ver :1.0 won't display but wen i plug the power cable on the power supply the cpu fan and power supply fan spin but wen i turn the pc on it doesn't display
Auto power on the mother board means there was not found RAM or VGA adapter. If you herd Beep tones
follow this link to identify the error
https://forum-en.msi.com/faq/article/bios-beep-codes
if not pls check the power supply 4pin connector correctly plugged .
Also need to check the cpu and post error codes by post diagnostic card to identify the eror.
Oct 24, 2013 | Computers & Internet
HP motherboard ms-7613 failed...how can i get a replacement?
Should be able to find o a great used one on line
Aug 03, 2013 | HP Computers & Internet
MSI 845GVM-V (MS-7057-010) Motherboard cpu fan not ruuning but smps is ok when jpw1 is disconnected then fan is running but mother board is not on
Hello hare is the homepage:
http://www.msi.com/product/mb/845GVM-V.html#/?div=Manual
Try to download the manual, and check all your connections again.
Try also to renew the power supply.
Check also this site:
http://www.tomshardware.co.uk/forum/261145-13-perform-steps-posting-boot-video-problems
The jpw1 is the main power connection for power to the cpu:
So you probably have a bad power supply.
Good luck
Jan 25, 2013 | Computers & Internet
Need large, clear diagram for MSI motherboard, type ms 7613-iona gl8e
Hello this mainboard belongs to the HP/ COMPAQ support:
https://h10025.www1.hp.com/ewfrf/wc/document?cc=us&dlc=en&docname=c02014355&lc=en&product=4262655
The manual:
https://h10025.www1.hp.com/ewfrf/wc/manualCategory?cc=us&dlc=en&docname=c02014355&lc=en&product=4262655&
You can`t find anything at the msi support site.
Do you get any picture (blue screen of death) ???
Any beep sound ???
This fault could be: ram failure,harddrive,graphic card,cpu.
Or sinply mainboard is dead.
It`s always difficult to do fault finding on a mainboard.
Many thing can go wrong.
And it will sometimes cost more
than a new mainboard or pc to solve the problem.
Ask a qualified repair shop (hp support) about known issues
with this mainboard.
Good luck
Nov 25, 2012 | MSI Computers & Internet
I want details for my motherboard ms-7613 ver 1.1
Apr 28, 2011 | MSI Computers & Internet
Computers & Internet Logo
312 people viewed this question
David Payne
David Payne
