Question about De'Longhi Nespresso Lattissima Plus Espresso/Cappuccino Machine: Nespresso Latissima Plus Espresso/Cappuccino Machine Red
Cappuccino and latte macchiato buttons blinking
Both lights blinking when milk is attached
I have the same problem... it continuously flashing.. even when it should have reached temperature.. pls advise
Posted on May 18, 2015
    Problem Solver:
  • 5 Answers
The unit is heating the steam - the lights should switch to contant once the right temperature is reached. Make sure to always descale the machine if the cappuccino button light turns orange.
Posted on Dec 02, 2014
Red light on start bottom keeps blinking
There is one solution I can think of. Probably your thing is running out of battery, or it might be that the quality is bad. But if it's new you could always buy a new one or ask your neighbour, friends, family... Anyone, then they might also give you some ideas you could try.
Nov 27, 2013 | Nespresso Aeroccino Automatic Milk Frother
My aeroccino leaks at the pouring spout when it is frothing, just before it is finished. How can I stop this? Please do not say I am putting to much milk in, I am far below the lower line. Is there a...
I called Nespresso and they said this happens a lot, basically it's because you're using the wrong whisk/paddle for the milk level. If you're using the metal wire whisk attachment you can only fill to the first level line. If you're using the plastic/metal attachment you can only fill to the second level line. We were using the wire whisk attachment and filling to the second line, so was overflowing everytime. Since switching attachments it heats perfectly and doesn't leak :)
Feb 20, 2011 | Nespresso Aeroccino Automatic Milk Frother
What does a blue light mean on my aerochino? thanks.
Means you are not heating your milk, the frothing milk will be cold (for iced drinks) because you have held the button down longer than normal. Usually it takes 5 Seconds for the blue light to go on. try turning it on or pushing the button faster, It should turn on red, for heated and frothed milk.
Nov 10, 2010 | Nespresso Aeroccino Automatic Milk Frother
Doesn't heat completely and light blinks
This is either a problem with the thermostat that lives just under the surface of the bottom of the aeroccino jug and is a technical problem that can only be resolved (replaced) by returning it to Nespresso OR it is related to a fine layer of burnt milk that builds over successive use that builds and holds the heat the element produces 'tricking' the thermostat into thinking the milk itself has heated to the desired temperature, not just the burnt layer. Clean the bottom of the jug, regularly with a non scratch scourer and use a mild detergent as well.
Jan 23, 2010 | Nespresso Aeroccino Automatic Milk Frother
Blinking orange light on model D290 and it is not full of capsules
I solved this problem by realizing that I had forgotten to insert back a certain piece of plastic, that I had taken out to clean. this caused the blinking light
Jan 04, 2010 | Nespresso Coffee Makers & Espresso...
What does a it mean if the aerocino is flashing its red light?
We had the same thing, and I think it has to do with overheating as well.
After about two goes of frothing hot milk, a little bit of burnt milk residue had formed on the bottom of the jug. I think that "fools" the temperature sensor, and makes it "think" the milk is hot before the frothing time is up (then shuts the machine off, blinking the red light).
As soon as I cleaned the bottom of the jug (had to scrape it with my nails after leaving water in for a while), all systems were "go" again......
My remedy: rinse the jug quickly with cold water after each use, making sure the bottom stays clean!
Aug 21, 2009 | Nespresso Aeroccino Automatic Milk Frother
Aeroccino Overflows
As a Nespresso demonstrator I've had this question many times- use the black plastic wand for light foam- can use to max line. Using the wire whisk wand for heavy, cappacino foam and fill only to bottom line. This wand uses more aeration to achieve foam density- causing more pressure and your leaks. The wand stored inside the lid doesn't have anything to do with function of the aerrocino.
Jul 06, 2009 | Nespresso Aeroccino Automatic Milk Frother
De'Longhi Nespresso Lattissima Plus Espresso/Cappuccino Machine: Nespresso Latissima Plus Espresso/Cappuccino Machine Red Logo
803 people viewed this question
Top De'Longhi Coffee Makers & Espresso Machines Experts
De Brewerz
De Brewerz
Level 1 Expert
Tom Chichester
Shrikant Shinde
Shrikant Shinde
Level 1 Expert
Are you a De'Longhi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
