Question about Ingersoll Richmond Watch
Ingersoll watch. Need to change date
How to change date?
How can I set?
Shirley, RE POST make model # and your complete question, so we at Fixya can answer your question effectively.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Apr 17, 2016 | Watches
My watch is changing date at 2 am instead of at midnight, i have tried rechanging it manually, but still each day at 2 am it changes the day again. Why it not change at 12am O'clock what I can do pls
Thread: Tag Heuer Carrera changes its date at 3:00 am instead of ...
forums.watchuseek.com > Forum > Watch Brands > TAG Heuer
Jan 1, 2012 - 6 posts - ‎3 authors
The watch used change the date, as it should, at midnight but I just noticed last night that it now waits until 3:00 am... Does anyone have any ideas. ... Join Date: Jan 2012; Posts: 2 ... Changing the date on an automatic watch - Watchuseek ...
Mar 2, 2015
Damage of changing date at midnight on automatics ...
Oct 18, 2013
Setting the date destroys the watch? - Watchuseek, The ...
Sep 8, 2010
Thread: Does setting date between 9pm and 3am damage ...
Jun 6, 2010
More results from forums.watchuseek.com
How do analog watches know to change the date at ... - Quora
https://www.quora.com/How-do-analog-watches-know-to-change-the... QuoraThere is a gear within an analog watch that is used to change the date at the appropriate time. The gear ... Watches: What is a fair price for a authentic 1970's vintage "McQueen" Rolex Explorer II? Why does the day start at midnight?
Jan 21, 2016 | Watches
Just got a new Seiko watch but the date won't change automatically
Main cause would be that the date gear teeth have been stripped. This is done by setting the date whilst the hands are trying to change the date themselves (between 10pm and 2am). Always adjust the date with the hands around 6.0clock. You will need to return your watch to where you bought it for repair I'm afraid.
Jan 18, 2013 | Seiko watch - SXDA42 Watches SXDA42 Ladies
I Have a fossil 10 atm watch & the date doesn't change automatically so i change it manually but then half way thought the day it changes the date
Your watch is 12 hours out of step.
The date changes every second time the hour hand passes 12 O'clock.
Your watches' second pass is at midday instead of midnight, so to make it operate correctly, you need to wind it on 12 hours. The date will then change at midnight.
Jul 13, 2011 | Fossil Watches
My analog Guess watch has a date display only (no day). I have re-set the date over and over, but it changes the date at noon instead of at midnight.
Your problem is caused by the fact that the watch is 12 hours out of step.
Wind your watch forward 12 hours, reset the date if you need to and you watch will then change around midnight.
(if you need to change the date more than one day, when it has past the change time, wind it back and then forward to step the date forward. You may have to experiment to see how far past the change point (in both directions).
Jun 04, 2011 | Guess G85675G WristwWatch
I recently took my fathers ingersoll duo watch to a repair shop to have new batteries installed unfortunately they were unable to separate it and get inside. could you please tell me how to do this.
I wouldn't advise you to do it yourself, as without special tools and knowledge you will just damage that watch. The best way is to type in your browser: watch repairs + your area. You should find plenty of them there. Contact by phone first and explain what sort of watch you do have and what's needed to do. Ask watch repairer on the phone, because only him/her will be able to understand specific needs. Do not explain to manager or just personell - they are useless. When you are satisfied with the answer over the phone, go there and give your watch for whatever it needs.
Jun 02, 2011 | Watches
Fix date n month on wrist watch
mcdevito75 here The stem has 2 positions, we all know the 1 to pull the stem out and set the time, day, date. try this, first go thru the watches 24 hour cycle to get the month you need, now slip a fingernail just under the stem (crown) and gently lift to it"s first position, it may take a few times to get used to, when you have it turn the crown (stem) to change the date easily, change the date to 1 date before the date you want, now go thru the watches 24 hour cycle to get to the date you need. Now the watch is set and will change on time at around mid--nite.
Jul 19, 2010 | Pulsar 5117 Wrist Watch
Setting the date on my rolex president day/date watch
if all else fales, you are probably in need of a service.
Jan 01, 2009 | Rolex Day-Date President 118238 Wristwatch
Pulsar (Seiko) Watch Changes Date at different time.
mcdevito75 here, The manufacturer recommends you don"t try to change the date between certain hours as this could hurt the date changeing mechanism inside the watch, I don"t think you did any harm (LUCKY) and the date changeing 45 minutes before mid nite is just about right. BUT! if the date change was aliitle closer to mid nite at 1 time you can try to reset the date, here"s how, your stem should have 2 positions to change the date without haveing to cycle the watch the 24 hours 60 times. Slip a finger nail just under the crown and gently, gently lift the crown to it:s first position, it may take a little practise but you"ll get it, once you do, trun the crown and you should see the DATE change, if so set the DATE to 1 DATE before the DATE you want, now pull the stem out and set the correct gate and time of day. Your watch is now reset and date will change on time, around nid nite.
Jun 10, 2008 | Pulsar Bracelet PXQ502 Wrist Watch
Ingersoll Richmond Watch Logo
Top Ingersoll Watches Experts
Ansel Alberto
Ansel Alberto
Are you an Ingersoll Watch Expert? Answer questions, earn points and help others
