Question about Whirlpool Washing Machines
Whirpool awe 7728/1
Top-loading washing machine does not fill with water. It just shows that the water supply is turned off.
  • 383 Answers
It's Sensors may have stopped working. Call Customer Service Engineer.
Posted on Mar 29, 2014
  • 1462 Answers
SOURCE: hoover washing machine top load, model 550m.5.5kg
water leak from cold hose nothing to do with other problem. tighten hose connection and fit a new hose washer overfilling probably because air chamber blocked. remove lid. you will see a pressurestat somewhere at the top - usually round with anything from 3 to 7 wires and a small tube underneath. follow hose down and it connects to the air chamber. make sure this is free of gung and check hose for splits and has no blockage. to check the pressure stat itself, attach your own hose to the stat and while machine in fill mode, blow down this hose and you should hear a click and water intake will stop
Posted on May 04, 2007
  • 641 Answers
SOURCE: top loading automatic washing machine not filling
Check the filters on both sides of the inlet water line. Let me know with your results for further assistance if will be needed. Good luck!
Posted on Aug 31, 2007
  • 90 Answers
SOURCE: washing machine
check pressure switch hose
Posted on Jan 06, 2008
mastatech
  • 478 Answers
SOURCE: We just purchased a top load Kenmore 800 washer
The first thing seems to be the timer,or the water level switch. Try filling the washer with water by hand, if it starts to agitate after being filled its the timer, if not it is the water level switch, let me know if you need further assistance.
Posted on Mar 13, 2009
  • 497 Answers
SOURCE: Hotpoint Aquarius WT540 washing machine. will not fill with water
Sounds like a timer switch malfunction.
Posted on Sep 06, 2009
Duet whirpool front loader is filling with water on its own
The washer fill valve is defective and will need to be replaced. The fill valve is right under the main top at the back the fill hoses attach to the valve.
Oct 07, 2014 | Whirlpool Duet GHW9150P Front Load Washer
Your machine does not suck water from the main tap. If the water supply is turned on, water is supplied under pressure to the fill valve which must open electrically to fill the machine. Your water supply may be turned off or the fill valve may be failing to operate
Jun 27, 2013 | Kenmore 22942 Top Load Washer
No water in tub,water supply is conected but it doesn't fill the tub
If your washing machine will not fill, only hot or cold will fill or is slow to fill then read these tips. I have covered many of the things that can happen in these tips...
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
Mar 08, 2011 | Whirlpool Calypso GVW9959K Top Load Washer
Hi! My neptune tl does not seem to have very hot water. I run the washtub next to it until the water is hot, but if you pause the machine, the water that it is filling with is really cool. Cooler than...
What happens if you turn of the cold water valve at the supply and do a hot fill....leave the Hot water supply valve open? Do you hear water filling the wash tub or do you error out with a NF error code for no fill?............. D*ick
Sep 18, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Whirpool Ultimate Care II washer - drips
Your water inlet valve is leaking through. Turn off the water. Remove the hoses from the washer. Clean the sediment screens in the water valve and replace the hose.
If that does not solve the leak through problem,the water inlet valve will have to be replaced.
Use the attached video to show how to access the inside of the washer in the event the water valve needs replacing.
http://appliancejunk.com/forums/index.php?topic=5191.0
Nov 08, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirpool washer wont work
The lid switch, get something to hold it down to make machine work. Turn machine on and push down on lid.
Jul 26, 2009 | Whirlpool CAM2752KQ Top Load Washer
My top loading clothes washing machine fills with clean water when both the water supply to it and the electricity is turned off
when you say water supply--As in the valves from the house? If so, and you still have it filling,call a priest!
if you have the unit turned off and it fills by itself overnight or during the day when it is not on, you would need a inlet valve.
Good Luck!
Feb 19, 2009 | Asko W6021 Front Load Washer
Washer makes noise, will not fill
turn it on and just makes a hummins noise??? not filling with water??? at very least the machine if powered correcly will fill with water, the humming if happening is hte washer trying to fill check your incoming water supply. try alo changing water temp select from cold/warm/hot.
Dec 03, 2008 | Roper RAS8244KQ Top Load Washer
Fh
whirpool front load washer f/h is a water fill error, no water supply to unit. be sure to check you valves are on
Mar 29, 2008 | Washing Machines
The load won't start.
It sounds like you have a bad lid switch.It's an easy fix.You can get the part at your local appliance supply.
Dec 09, 2007 | Whirlpool Ultimate Care II LSQ9549L Top...
Washing Machines Logo
51 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
