Question about Smeg A42-5 Dual Fuel (Electric and Gas) Kitchen Range
Smeg A42 Opera Cooker. Lower oven thermostat not
Smeg A42 Opera Cooker. Lower oven thermostat not working. How can it be replaced
ronaldo1
SOURCE: cooker not heating up
removed broken element and replaced it. You have to access the fixing screws from the back of the cooker to remove it
Posted on Feb 15, 2008
  • 415 Answers
SOURCE: SMEG A 2.5 Range Oven
sound like the TOD to me. have a technician replace it.
Posted on Sep 13, 2008
SOURCE: I have a Smeg A1-1 Cooker. The main oven door does
you have to replace the door hinge's an easy fix but you have to strip the doors apart so a good time to clean.
Posted on Oct 03, 2009
richardsimpl
  • 230 Answers
SOURCE: I have a smeg A42-5 oven and the digital clock as
Hi There
I have found this for to read and hope this will help you. Let me know how it goes.
The clock stopped The non-electronic clocks on electric range/ovens often don't last long. That's a problem, because the clock is essential to the self-cleaning and timed-bake features. Clocks are rarely repairable--you usually just have to replace them. Electronic clocks have been more reliable. But, they're often integrated with several other features of the range/oven. So when the clock develops a defect, it often renders the entire oven and broiler inoperative. The electronic clock is usually integrated with a circuit board, and the touchpad that holds the buttons you press is often a separate component. If your electronic clock is defective, you may need to replace the touchpad, circuit board, or both. Although these may be expensive, they aren't usually very complicated to replace.
Thank you for writing to fix ya.
Best Regards Richard
Posted on Jan 07, 2010
Testimonial: "Thankyou for your response I suspected that it will require a new clock which I have located online. many thanks"
  • 193 Answers
SOURCE: oven on Smeg A42-2 cut out and is not working
may be thermostat or control card
Posted on Apr 26, 2010
Smeg oven fan and heat not working
This tutorial will show you how to check your Smeg element and how to replace your Smeg cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
  • Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
  • If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  • When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
If this helped you why not get me a beer? Paul is from the Naturally he would appreciate beer How to Repair Home...
Oct 28, 2013 | Smeg Ovens
Replace heating element in smeg oven
Mar 02, 2013 | Smeg Ovens
Smeg oven not working
  1. Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
  2. If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  3. When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
Mar 06, 2012 | Smeg Ovens
Smeg oven stopped working
Jan 27, 2012 | Smeg Ovens
Lower element not working
Jul 16, 2011 | Smeg SE280X Stainless Steel Electric...
I have a Smeg SE 336SS-5 Electric oven, I have recently had problems with the fan motor not working and the electrics tripping out when the cooker has been on for a while. I have replaced the fan motor...
Jul 07, 2011 | Smeg Ovens
Hi, we have a se280x oven and its about 4-5 years old and inherited this when we moved in 2 years ago. But the oven seems to heat sometimes or not constantly and especially seems like e the upper and...
Apr 15, 2011 | Smeg SE280X Stainless Steel Electric...
Suk92mfx5 main oven problem?
the fan element would have blown. it is not uncommon for an element to trip an rcd when it blows. you are on the right track, if you replace the element all your problems should go away
Feb 17, 2008 | Smeg SUK92MFX5 Dual Fuel (Electric and...
Cooker not heating up
Feb 14, 2008 | Smeg A2.5 Dual Fuel (Electric and Gas)...
Smoke from oven
I am a recently retired appliance engineer of 20 years sounds like pure coincidence, check the fan for circuit at terminals, and / or check for movement of blades, that you have not got fan jammed, replace fan motor unit if needed, still cheaper than a call out if i have helped rate me work with safety all the time, unplug at all times when working on any item
Sep 09, 2007 | Kitchen Ranges
Smeg A42-5 Dual Fuel (Electric and Gas) Kitchen Range Logo
122 people viewed this question
Top Smeg Kitchen Ranges Experts
Carmen Mikulic
Joseph Mueller
Joseph Mueller
Your Consultant
Are you a Smeg Kitchen Range Expert? Answer questions, earn points and help others
