Question about Canon imageRUNNER 7200 Copier
E000830-0000 Machine is not running
Sears kenmore sewing machine model 148-13100 running slow
Did you open the top of the machine and oil every place where metal rubs against metal? Did you do the same under the machine? Use only GOOD quality sewing machine oil. If the machine is slow to recover (it may take a while for the oil to sink in), you can direct hot air from a handheld hairdryer into the internal mechanics. AVOID trying to run the machine until it moves freely or possibly risk damaging the motor.
Apr 23, 2017 | Kenmore Sewing Machines
Is it the motor or the foot pedal that might cause my trouble? Sewing machine runs inconsistent in speed.
HAVE YOU TRIED TAKING THE FOOT PEDAL TO A SEWING MACHINE REPAIR SHOP AND ASK IF THEY COULD TELL YOU IF THE RESISTANCE IS CONSTANT AT DIFFERENT LEVELS OR IF IT FLUCTUATES IN SPEEDS ON ANOTHER MACHINE. MY GUESS IS THAT THE MACHINE NEEDS AN OVER HAUL, THEY DO NEED OILING, ADJUSTING AND CLEANING IN PLACES YOU HAVENT EVEN SEEN YET. I KNOW,.... MY WIFE HAS THREE OF THEM AND THEY RUN BEST IF THEY ARE SERVICED ONCE A YEAR WITH MODERATE USE.
Jan 06, 2015 | Sewing Machines
Sewing machine runs on its own
Turn the power switch to the off position and use the pedal. I suspect you only use the L and H for winding the bobbin automatically and the machine only has one speed.
Nov 21, 2013 | Smartek SB1800 - Sunbeam Compact Sewing...
Motor continues to run after machine has been switched off
If it keeps running after you unplug it, you have somehow gotten your hands on a perpetual motion machine. Use it to run a generator and sell electricity to your neighbors!
Seriously, I think you meant "after you turn it off at the washing machine control panel." You probably have a shorted motor contact in the timer (contacts welded together).
Oct 23, 2011 | Washing Machines
Descaling cycle will not run
You need to push the hot water button on the machine panel to allow water to run out of the steam wand. After a few seconds the machines ventilate message should clear.
Jun 12, 2010 | Gaggia Titanium Espresso Machine
I have a schaerer opal coffee machine, when I switch the machine on, the water light flashes, and a pump runs continuosly as if it is trying to purge the machine. but nothing comes through. does anyone...
I have a schaerer opal coffee machine, when I switch main power machine on, the descaling indicator, cleaning/rinse indicator and stand-by mode indicator lamp remains lit, and a pump runs continuosly. the machine do not ready mode indicator. Yudi INDONESIA
Apr 05, 2009 | Schaerer Opal Espresso Machine
My washing machine does not run at all
Plug off the wall mains. Drain out water. Check out the pump for anything clogging the impeller. Check wires connecting this too.
Mar 26, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Francis francis X1 the water supply seems to be lacking pressure
I would go ahead and run a solution of 50% distilled white vinegar and 50% water through the machine. If the machine still runs slow after that, pour another 50/50 vinegar/water solution into there - let it run just enough so that the vinegar water starts to drip out, then cut the machine off. Let the vinegar/water sit in the machine for about 20 minutes. Then cut the machine on and let the rest of the solution run through. Then run plain water through the machine to clear out the vinegar. Try brewing a batch and see if the machine behaves normally.
If the above fails to resolve the issue, the FrancisFrancis machines are now owned by illy, so would need to contact them for further TS.
-Tha Mp3 Doctor
Mar 08, 2009 | FrancisFrancis! X1 Espresso Machine
Machine stopped running, its getting power but wont run.
Are you sewing or embroidering? If you are embroidering, the machine automatically stops and shows scissors in the window, for you clip the jumpstitch. Then just push the "Run/Stop" button.
Dec 13, 2008 | Husqvarna Rose
Canon imageRUNNER 7200 Copier Logo
22 people viewed this question
old marine
old marine
