Question about LG LFX25991ST Super-Capacity 3 Door French Door Refrigerator
Fridge door the latch in the center of the left door doesn't stay in position to close properly. What holds that latch in position? A spring or a magnet ?
  • 82 Answers
SOURCE: freezer door wont stay closed.
If you can pull the freezer drawer out, check to see if there is anything on the floor of the freezer. You can also try reinstalling the drawer. When you take the drawer out make sure that the spring loaded door catches on the sides are facing towards you. That is if it has any.
Posted on Dec 03, 2008
  • 28 Answers
SOURCE: Refrigerator Door not staying closed
Try to raise by adjust the 2 front footing slightly higher than the back, this will tilt the unit slightly backwards. That will help the door to close back by itself.
Posted on May 09, 2009
  • 363 Answers
SOURCE: LG Fridge door constantly beeping when closed
On the display panel press the right key that turns the door alarm on and off
Posted on Jul 21, 2009
  • 19 Answers
SOURCE: I now have the same problem: I HAVE AN LG FRIDGE
LG has issued a service bulletin about this problem. You need to call LG or the ratailer you bought it from and tell them what's going on...the entire cost of the repair (parts and labor) should be covered....at least it was the last time I did one for a customer.
Posted on Oct 04, 2010
MNTECH
  • 1543 Answers
SOURCE: I have a LG side-by-side Model LRFD25850ST - the
The insulation is all foamed in place. Doors can not be dissassembled, other than replacing gaskets.
Posted on Mar 06, 2011
The door flap on my KitchenAid French Door fridge isn't springing completely back into place, and it's catching on the other door.
Locate and adjust the spring responsible for getting that flap into proper place and all will be resolved.
Aug 30, 2015 | KitchenAid Refrigerators
Tip
Lights on one side fridge not cooling.
mine fridge Viking VCBB363L Bottom Freezer Refrigerator.
Took a cell phone camera in video mode and put it in the fridge to see if the light was going out when the door was closed.
Turns out. it wasn't.
This causes the lghts on the left to go out. However, the light on the right stays on and warms up the fridge.
Solution.
Top section air grill. 5 1/4 hex screws.. remove the grill you'll notice door's light switch on right side. a steel spring attached to the switch. When fridge's hinge arm closes the arm pushes on this guy and pushing in the switch button and shuts off the lights.
you can move this with your finger.
In my case switch has a little purple button.
take two pair of 3 in needle nose pliers and CAREFULLY hold center of spring and bend the end nearest you to the left.
You don't have to go crazy Just a bit.
then get you camera ready and check out your work.
Results after you've succeded, replace your parts, and notice after 10 minutes the lights all come on, the alrms stop and the fridge cools normally.
and you saved 200.00
on Jun 24, 2008 | Viking VCBB363L Bottom Freezer...
Door will not stay close
Not much data to go on here. The latch on the door has a spring that holds it down in the locked position. when you pull the handle the latch goes up and you pull the door open. You will have to take the door apart and see if the spring broke or the plastic tab that holds the end of the spring is broken.
Feb 25, 2015 | Maytag Appliances Over-the-Range Microwave...
Drivers door will not latch closed
It appears that the door is not closing far enough for the latch to move to the second position in it's movement. ie on not closing the door properly you will see that it is latched but not closed . Push it harder and it closes properly. Lubricate the latch mechanism and you may have to adjust the catch position to allow the lock to go to the fully locked position POssible rubbers to cold and stiff to allow the door to close easily
Feb 03, 2013 | 1997 Ford Escort
Whirlpool quiet partner iii doesn't latch closed
It is likely the dishwasher is not sitting in the correct position. The levelling screws at the base might need adjustment.
Alternativley the latch is faulty or the door tension springs are displaced and need readjustment.
Please post the model number so I can help you find a proper solution.
Jan 02, 2013 | Whirlpool Dishwashers
The door wont shut properly
see this causes and use the common sense.God bless you
When your dishwasher door has a problem, check these: Latch Springs Hinges Door seal Latch The latch on many dishwashers is adjustable. If your door is easy to close but difficult to latch, adjust the latch to let the door close more easily. If you can't see any way to adjust the latch, yours may be fixed in a certain position. Check for other reasons for the latching problem. If the latch has worn out in a way that makes it impossible for you to close the door properly, you probably need to replace the latch. Springs Your dishwasher has two springs that counterbalance the weight of the door. If either or both of these are broken, the door feels quite heavy and you need to replace both springs. Hinges The hinges are important to the door closing properly. If they're bent or deformed, you probably need to replace them. Once bent, only rarely can they be straightened well enough. Door seal If your dishwasher is new--or if you have just replaced a door seal--the door may be difficult to latch for a week or two. If the tightness persists, though, try adjusting the latch, if it's adjustable. If it's not adjustable, there's probably nothing you can do immediately. But try running the dishwasher on the highest heat cycle to help the seal conform to the door. Otherwise, the seal should compress over time.
Sep 19, 2012 | Hotpoint 24 in. FDW60 Free-standing...
My Kitchenaid khms155lss-2 has a problem latching completely. Once finally latched the microwave would start and then stop during the cooking time because the door became unlatched. I have to stand by the...
Ok.Agreed,latch is not cracked or worn out.But check the grip of latch.Open the door.The hold the latch in your hand and see,if its loose or tight.It should be tight.Press the latch towards down and move it left/right slowly --- slowly.And inspect the latch.It will move,there will be a moment but the position of the latch in the door frame should be tight.If you feel that latch is got very loose,then the door frame needs to be disassembled and latch assembly has to be repositioned and fitted.In most of the cases this latch breaks/cracks and it needs replacement.But in your case,its different,you mentioned that if you keep your oven door pressed then latch remains closed..So if latch is broken/cracked it will not get closed properly.So as per that i think,you will have to check the opposite side of the door frame,where this latch gets into.On that side,there is a interlock type part.Which holds this latch.That part is operated by spring.If in-case that interlock type part or the spring,any of this is got loose then latch will get released after few minutes.--------------- But first as regular troubleshooting,you inspect the latch.Do you feel its loose or getting very easily moved,then open the door frame and check the latch.----------- For that you will required door disassembly diagram:--- Click the link,see part number 3 is door latch.-------- http://www.searspartsdirect.com/partsdirect/partsdirect/showSubComp.pd?imageUrl=http://c.searspartsdirect.com/lis_png/PLDM/W0505176-00002.png -------------- If the latch is properly positioned and intact then ,you will need to disassemble the opposite side cabinet to check the internal part,which hold the latch.For that you will require complete disassembly:---Click this link for complete disassembly:-- http://www.searspartsdirect.com/partsdirect/part-model/Kitchenaid-Parts/Microwave-Parts/Model-KHMS155LSS2/0593/0123370?pathTaken=&prst=0&shdMod=KHMS155LSS2 -------------- The door latch itself or other parts holding the door latch,none of the part is costly then $10.The cost of part is under $10.---------It just require you to figure out,either is cracked /broken part or just loose misaligned part.-------- This will help.Thanks.Helpmech.
Feb 10, 2011 | KitchenAid KHMS155LSS 1000 Watts Microwave...
Cannot open the door of the dishwasher.
  • The latch on many dishwashers is adjustable. If your door is easy to close but difficult to latch, adjust the latch to let the door close more easily. If you can't see any way to adjust the latch, yours may be fixed in a certain position. Check for other reasons for the latching problem.
  • If the latch has worn out in a way that makes it impossible for you to close the door properly, you probably need to replace the latch.
  • Your dishwasher has two springs that counterbalance the weight of the door. If either or both of these are broken, the door feels quite heavy and you need to replace both springs.
May 04, 2010 | Maytag 24" Tall Tub Built-In Dishwasher -...
Door will not stay closed unless latched. spring
Adlust the level on the fridge so that the hinged side is slightly higheer than latch side. They reley on gravity to stay closed.
Dec 24, 2009 | KitchenAid 24 in. KUDI01FLSS Stainless...
Door won't latch
replace the door latch part number 8193830 it will fixya
Sep 23, 2007 | KitchenAid 24 in. KUDS01FLSS Built-In...
LG LFX25991ST Super-Capacity 3 Door French Door Refrigerator Logo
16 people viewed this question
Top LG Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
christian nielsen
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
