Question about Sony Ericsson Cyber-shot C902 Cellular Phone
My c902's imei blacklisted...!!!! how do i repair this
How do I remove Samsung Galaxy S5 Active imei number from blacklist?
You will need to ask your cellphone provider. Normally blacklisted because it is stolen, or has been moved to another carrier when the previous carrier still owns the phone under an unexpired contract. This is the official line on this
You can check your IMEI number is Blacklisted in AT&T, Verizon, T-Mobile, Telus, Sprint...Blacklist IMEI is lost, stolen or ineligible (Bad, Barred, Blocked, Financed, Under Contract) mobile phone. Always check blacklist before buy, sell or get phone.
http://www.protectyourdata.ca/check-the-status-of-your-device-in-canada/
http://imei-number.com/imei-blacklist/
https://imeidata.net/blacklist/check
Unlock Bad IMEI Phone that Blacklisted Blocked or Stolen
Mar 04, 2016 | Samsung Cell Phones
Samsung galaxy s6 g-sm920v imei repair
Samsung Galaxy s6 GSM 920v: IMEI Blacklisted Verizon:
Hello. You can't do anything about the IMEI being Blacklisted from Verizon. That phone is deemed stolen. You bought stolen goods
You could report the Seller to your local police to tell them that you were tricked into buying stolen property.
The only thing you can do with this phone is use it with another cellular provider SIM card. Most Verizon Samsung Galaxy Android phones are already Factory unlocked. You won't be able to get perfect reception on other carriers but you can use it with AT&T or T-Mobile's SIM cards. No Verizon or Sprint though.
Unlocking Galaxy S6 on Verizon
Confused about locked vs unlocked phones Ask Maggie explains
Feb 11, 2016 | Samsung Cell Phones
How to reset with imei security code
The IMEI code is permanent and will identify your phone when it talks to the cell phone company.
Free check Blacklist Mobile by IMEI / ESN / MEID You can check your IMEI number is Blacklisted in AT&T, Verizon, T-Mobile, Telus, Sprint...Blacklist IMEI is lost, stolen or ineligible (Bad, Barred, Blocked, Financed, Under Contract) mobile phone. Always check blacklist before buy, sell or get phone.Supported:+ Private database (more than 1 million imei)+ USA: AT&T, Sprint, Verizon, T-Mobile, Cricket, Metro PCS+ Canada: Telus+ Sweden: Telenor+ Japan: Softbank, AU KDDITo find your IMEI number, type *#06# on the phone keyboard, or is located in the battery compartment.Please enter the 15 digits, without any other character.
Oct 05, 2015 | Cell Phones
I have an T-Mobile lg g flex that i believe is blacklisted is there anyway to fix it
The only way to fix it is changing the imei. What wireless carriers blacklist is really the phone's imei. It also needs to be an imei that nobody is using, you best bet could be an old phone you have lying around or from a friend's. You can also try and talk to the wireless carrier that blacklisted the phone, but then probably you would have to pay whatever is in balance from the previous owner.
Jan 29, 2015 | LG Cell Phones
Remove blacklist off my phone
Go to androidrooter.com. he can fix blacklisted phones
Jul 31, 2014 | HTC One X Android Smartphone Glamour Gray
Imei blacklisted
Hi, I'm afraid no one will do that for you just like that, it's possible to use the Blacklist Check service on Fastgsm site, for example: Blacklist IMEI Check Report
Jan 14, 2014 | Cell Phones
Unlock code c902
The C902 is a camera phone by Sony Ericsson.
If you purchased your C902 with a cellular plan, it would be locked to your company's network and can only be used with that network.
If you want to switch networks and continue to use your C902, you have to get it unlocked from the current network.
The simplest way to unlock your C902 is through remote IMEI unlocking.
1.Obtain the unlocking code for Sony Ericsson C902 from your network's support desk.
You can call them up and talk to a customer support representative.
Request the unlock code and give them the phone's IMEI number.
As an alternative, you can purchase the unlock code from the websites such as Unlocking,
FonesZone or UnlockItNow.
You will need to provide the IMEI number on the websites.
2.
Close all applications to reach the standby screen of the phone.
3.
Press the left direction key on the navigation pad.
4.
Press the * (asterisks) key twice.
5.
Press the left directional key once again. You will see a menu titled "Personalize."
6.
Select "Network" in the menu. Select "MNC2" in the second menu that appears.
7.
Enter the unlock code you obtained in Step 1 and select "OK." This will unlock the phone.
http://www.mobileunlockguide.com/sony-ericsson-c902
Aug 14, 2013 | Sony Ericsson Cyber-shot C902 Cellular...
How can i fix my samsung sgh-e590 in limited service for free
Please check your IMEI by typing: *#06#. Did you try any (free) unlock (reset) codes?
If your IMEI is still good your phone is blacklisted and only your provider can fix that. Otherwise you have to repair your imei
Mar 24, 2012 | Samsung Cell Phones
Thanks
I recommend you contact your service provider.
Blacklisted or Barred Handsets
What is it all about???
A phone may be blacklisted (or barred) for many different reasons, but the most common reason is that it has been reported either lost or stolen! It is only the networks (Orange, T-Mobile, O2, Vodafone etc) that have the facility to blacklist a handset.
If you are unfortunate enough to either lose or even worse have your phone stolen you should report it to your service provider (your network) immediately!
Your service provider can then blacklist the handset so that it can no longer be used to make or receive any calls. The networks do this by adding your phones serial number onto a national blacklist database (Central Equipment Identity Register). Effectively the handset becomes absolutely useless and the thief is in possession of a pretty paper weight! :-))
So How Does Blacklisting Work?
Every mobile phone has a unique serial number. This serial number is called the IMEI number (International Mobile Equipment Identity). It can normally be found underneath the phones battery and it is 15 digits long.
Now each time you switch your phone on or attempt to make a call the network systems check the IMEI number of the handset you are using. At this point the IMEI number of your handset is cross referenced with the Central Equipment Identity Register. If the IMEI number of your handset is on the CEIR then the network will either:
1) Refuse to send a signal to your phone (No signal strength at all)
2) OR WILL supply a signal but will not allow any outgoing or
incoming calls.
If your IMEI number is on the CEIR your handset is blacklisted and therefore useless.
Apr 27, 2008 | Samsung SGH-E370 Cellular Phone
Sony Ericsson Cyber-shot C902 Cellular Phone Logo
26 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
Sandeep Shenoy
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
