Question about Alcatel Tracfone A382 BIG EASY No-Contract Phone
Removing battery cover
How do I remove back cover
  • Jan Kidd-Dahn Mar 29, 2014
    Never mind. I got it. Thank you! :-)
  • 210 Answers
Post a solution jan for others who may stuggle
Posted on Mar 29, 2014
Where i can replace the battery of my Casio watch,.Casio hunting timer AMW 705
The battery of my Casio 1846 W-71 was dead, so I tried to replace the battery by myself.
First, you need to get a hand on a CR2016 3-volts battery. It could cost you 5$ or 10$, but I got 5 of them for 1.50$ at an electronics discount store...
Get a precision screwdriver, remove the 4 screws. Be careful when you remove the cover, there's a tiny spring. Remember where it is, then remove it. Remove the watch from the shell.
Using a flat mini screwdriver, remove the cover that holds the battery. You'll need to unclip all 4 corners. There are centers to unclip too, not sure if there was 2 or 4 of them.
Remove the battery, place the new one. Clip the battery cover back, and put the watch back in the shell.
I closed the cover. The watch was showing time, buttons were working, but no sound at all. Looked on the Internet, and read that you need to short circuit it.
Look carefully, there is a label "AC" near a small hole. (Inside the hole you'll see the gray spike of a welding). Just touch something metal inside the hole (e.g. the welding spike) and then touch the positive (top) side of the battery. Put the cover back in place, press a button and listen for the beep.
Screw the cover back in place.
Aug 23, 2013 | Watches
I'm trying to clear the memory on my Ti-84 Plus, but every time I hit 2nd then + to access the memory, nothing happens. It doesn't take me to the screen or anything. It justs stays on the blank screen.
  1. Power of device.
  2. Remove primary battery cover.
  3. Completely remove all 4 AA batteries.
  4. Unscrew and remove back up battery cover.
  5. Remove all back up batteries.
  6. Wait 60 seconds.
  7. Reinsert back up batteries and cover.
  8. Reinsert all 4 AA batteries and cover.
  9. Power on device.
  10. Memory cleared!
Mar 13, 2011 | Texas Instruments TI-84 Plus Calculator
How do you change battery for casio 1174 CMD-40?
I like these little RC IR watches. They're great fun!!! For this tutorial, you will need....
  • A small Phillips heads screw driver
  • A pin (or needle)
  • A replacement CR2032 battery
Instructions :
  1. Remove the 4 screws from the back of the watch
  2. Carefully remove the back plate, do not damage the delicate rubber seal
  3. Carefully remove the delicate rubber seal
  4. Use the pin to remove the small rubber block from the battery cover clasp.
  5. The pin should then be inserted in the gap of the white plastic lug, where the rubber block was removed.
  6. Use the pin to gently pull back the clasp of the battery cover.
  7. The battery cover will then open with a 5mm gap approx. It does not need to be removed.
  8. Use the screwdriver to remove the battery.
  9. After the battery has been replaced, just follow the instructions backwards.
I hope this little tutorial has helped.
Feb 10, 2011 | Casio Watches
Can't figure out how to get battery to come out of back compartment so I can replace, What is the trick? 1987 Honda TRX400 foreman 4x4 ATV
All you should have to do is remove the seat (lift the lever on the back right side of the seat and slide it off toward the back of the ATV). There should be a "pop off" cover behind the battery - Use a Phillips screwdriver to remove the "button" tabs and then remove the cover. You can now remove the battery hold down strap and remove the battery.
1) Make sure the ignition switch is OFF
2) Remove the seat
3) Remove the rear fender lid by removing the clips
4) Release the rings and remove the rubber band
5) Disconnect the negative terminal lead from the battery first, then remove the positive terminal lead
6) Remove the battery
7) Clean the batter box before replacing with the new battery
Install in reverse order of removal.
Regards,
Oz
Jan 09, 2011 | Honda Fusion Motorcycles
How To remove the cover from Samsung SGH M-200
To remove the cover of the phone, you follow the process below:
Remove your back cover by pressing down the black part and sliding it downward, remove your battery and sim. Two screws need to be removed,
There are four slots in battery compartment. Two are by the left side and there are two opposite. Push a mobile phone opening tool into each slot and then turn it. This will release the clips that hold the battery compartment in place, now you have the back cover removed
Next release the clips that hold the front cover,
Just gently unclip the hooks that clips the front cover, there are about 6 hooks by the sides, 3 on each side, now you have both back and front cover removed.
Take care and good luck
Oct 14, 2010 | Cell Phones
Disasembly of a phillips norelco shaver 7310xl in order to replace battery.
Remove the 2 screws on the back and remove the back cover. This will allow you to access the inner cover that has 3 screws. Remove those screws and take off the inner back cover to access the battery. Be sure to read the NOTE concerning installation on that page
You will find the battery at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-battery-aa-nimh-p-108.html
Aug 19, 2010 | Health & Beauty
TI BA II battery change How do I do this without ruining the calculator!
Turn off the calculator and turn it over with the back facing you. Using a small Phillips screwdriver, remove the four screws from the back cover. Carefully pry off the back cover. Using a small Phillips screwdriver, remove the screws from the metal battery cover and lift the cover off the battery. Tip the calculator slightly to remove the battery. Caution: Avoid contact with other calculator components. Install the new battery with the positive sign (+) sign down (not showing). Replace the battery cover and the screws that hold it in place. Align the screw holes in the back cover with those in the calculator, then snap the back cover onto the calculator. Replace the screws.
The battery is a CR2032.
May 26, 2010 | Texas Instruments BA-II Plus Calculator
How do I replace the battery and where is it located?
Procedure:
Remove battery cover located under the hood on the passenger side in the back. Simply pry the plastic catch in the front, open it like a lid and jiggle it loose and set it aside.
Use the small flat screwdriver to pop up the center peg in the five peripheral fasteners holding down the plastic compartment cover that you just removed the battery cover from. Each of these has a small black plastic circular flat topped center peg inside a larger plastic circular disk which has 4 slots under which you can slide the screwdriver to pop up the center peg. When the peg pops up simply slide the screwdriver under the larger disk to remove the assembly and loosen that site of fixation. When all five fasteners are out you can remove the entire compartment cover.
The battery terminals are removed with the 10mm wrench
The black box in front of the battery can be lifted out of the way by pressing on the plastic catch in the front of the box to loosen it from the metal flange that it is attached to.
The metal battery holder is removed with the 10 mm wrench. The nut is removed and the long bolt is slid out of the holder and then unhooked from it's bottom anchor. Jiggle the metal bar over the top of the battery to unhook the back hook from its bottom anchor. It may be necessary to lift the plastic over the back of the battery gently and lift out the soft clear plastic washer fluid tube from its guides to get at the back hook.
Gently lift the battery out while holding the cables out of the way.
Tools required:
10mm wrench, small flat screwdriver
Procedure:
Tools required:
Procedure:
Tools required:
Procedure:
Apr 17, 2009 | 2004 Nissan 350Z
I dont know how to insert my sim card
Hey,
* Open ur cell phone cover(back)
* Remove battery.
* Insert sim in a jack(symbol 'll be given aside it, along with direction of sim).
* Put ur battery n cover back..
* Swith on ur phone..
Aug 22, 2008 | Cell Phones
Alcatel Tracfone A382 BIG EASY No-Contract Phone Logo
106 people viewed this question
Top Alcatel Water Sport Experts
Ron Dufek
Ron Dufek
 Mikey
Mikey
Bill Boyd
Are you an Alcatel Water Sport Expert? Answer questions, earn points and help others
