Question about Minolta DiALTA Di183 Copier
Minolta 4000 how to remove the C-40 code
During copy paper is jamped
    Top Expert:
  • Minolta Master
  • 14,161 Answers
Konica Minolta Customer Phone Number Shortest Wait Best Support
Posted on Dec 16, 2014
  • Minolta Master
  • 6,161 Answers
One of the copier fans is bad. Open close the front door. to reset
Posted on Jul 04, 2014
4 Suggested Answers
saxmansaxman
  • 177 Answers
SOURCE: Paper jam and give code
Hi this is a standars problem you will need to take apart the back of the toner hopper where the toner goes in the drive motor or worm gears will be damaged and will need to be replaced or the motor some times you just need to clean around the sensor toner hopper sensor and it will fix the issue
Posted on Mar 04, 2011
Cogz
  • 1326 Answers
SOURCE: Have a MINOLTA CSPRO 4000, erro code C0040----"FAN
The fan is not easy to replace...... The fan is located under the black transport belts. The fan is part
of the unit that brings the paper from the transfer & drum to the fuser unit. The unit is black and it looks like tank tracks. From what I remember the fan is acturely in the transport unit ... Good Luck
Posted on Apr 28, 2011
  • 109 Answers
SOURCE: please i want clean the copies machine minolta cs pro ep 4000
Dear
the best clean is to take the glass out and clean all the mirrror you can see in the exposure system also you must clean the exposure lamp with the alcohol
that all you can do alse if the the copies still dirty that mean there are another problems in your copier must check.
Posted on Nov 25, 2011
Knica minolta Ep 4000 C 0200
Below the drum is an assy. that houses two very fine gold plated wires that do two things since the paper goes between these two wires and the drum the first is transfers the image on to the paper from the drum, the second one prevent the paper from sticking to the drum. One is or both are bad, BROKEN? Remove the assy. and replace both. They are very fine and fragile do not lose the springs. If that does not work you might have bad ends on the assy. after a while the plastic breakdowns and allow the voltage to go to ground. The wires carry around 2000 volts during the copy process. None during power off :) Open close the front door resets the code.
Oct 11, 2015 | Minolta Office Equipment & Supplies
Error code c0200 minolta EP 4000
Sir, right below the drum area when you open the machine front door is a assy. with two very fragile gold plated wires that transfer the image from the drum to the paper. The paper moves over this wires during the copy process. They mite have broken giving you a C0200. Or the same type of wires are above the drum on the drum unit which must be removed to see them mite be bad. did you open close the front door to see if the machine will reset?
Jun 25, 2014 | Minolta EP4000/5000 CS/PRO Copier
Hw do i fix error code c0210 on my minolta dialta di 552
Directly below the drum section is assemble called the transfer/separation assy. the purpose of this unit is two fold. (It houses to very thin gold plated wires) One wire is what helps the transfer of the image from the drum to the paper. Since the paper goes between this wire and the drum, the second wire prevent the paper from sticking to the drum during the transfer process. The code you have been getting means either wire mite be broke, has to cleaned (because of all the toner on it from the drum assy. which need to removed and cleaned. Or The end blocks that hold the wires are getting old and allowing the High Voltage that is applied to the wire during the copy/print process are breaking down allowing the high voltage to ground. Open close the front door to clear. if it comes back have qualified tech look at it.
Mar 09, 2013 | Minolta Office Equipment & Supplies
Minolta copier error code c0200
Debby, Below the drum is an assy. that houses two very fine gold plated wires that do two things since the paper goes between these two wires and the drum the first transfers the image on to the paper from the drum, the second one prevent the paper from sticking to the drum. One is or both are bad, BROKEN? Remove the assy. and replace both. They are very fine and fragile do not lose the springs. If that does not work you might have bad ends on the assy. after a while the plastic breakdowns and allow the voltage to go to ground. The wire carry around 2000 volts during the copy process. None during power off :) Open close the front door resets the code.
Sep 19, 2011 | Minolta EP4000/5000 CS/PRO Copier
What code C0200 mean for minolta ep4000 cspro
Below the drum is an assy. that houses two very fine gold plated wires that do two things since the paper goes between these two wires and the drum the first is transfers the image on to the paper from the drum, the second one prevent the paper from sticking to the drum. One is or both are bad, BROKEN? Remove the assy. and replace both. They are very fine and fragile do not lose the springs. If that does not work you might have bad ends on the assy. after a while the plastic breakdowns and allow the voltage to go to ground. The wire carry around 2000 volts during the copy process. None during power off :) Open close the front door resets the code.
Jul 06, 2011 | Minolta Office Equipment & Supplies
Here is the hostname cspro minolta ep 4000 error code c 0200 how can I do to do to solve this problem thank you for helping me and thank you for your assistance
Below the drum is assy. that houses two very fine gold plated wires that do two things since the paper goes between these two wires and the drum the first is transfers the image on to the paper from the drum, the second one prevent the paper from sticking to the drum. One is or both are bad, BROKEN? Remove the assy. and replace both. They are very fine and fragile do not lose the springs. If that does not work you might have bad ends on the assy. after a while the plastic breakdowns and allow the voltage to go to ground. The wire carry around 2000 volts during the copy process. None during power off :) Open close the front door resets the code.
Mar 07, 2011 | Minolta EP4000/5000 CS/PRO Copier
Minolta error code c-0210 di450, can I fix that myself?
You made the decision, Below the drum is assy. that houses two very fine gold plated wires that do two things since the paper goes between these two wires and the drum the first is transfers the image on to the paper from the drum, the second one prevent the paper from sticking to the drum. One is or both are bad, BROKEN? Remove the assy. and replace both. They are very fine and fragile do not lose the springs. If that does not work you might have bad ends on the assy. after a while the plastic breakdowns and allow the voltage to go to ground. The wire carry around 2000 volts during the copy process. None during power off :) Open close the front door resets the code.
parts Precision Roller Printer Toner Cartridges Parts and Supplies Office...
Dec 26, 2010 | Minolta Office Equipment & Supplies
Paper jam in fuser that crinkles the paper during duplex copying
If you get crickling check the rollers or replace the fuser. Sometimes you can WD 40 the rollers or blow out the paper dust.
Dec 09, 2010 | Konica Minolta Bizhub 222 Black and White...
The ADF Konica Minolta causes paper jamp or may bend 1 corner of
check there are two locking claw for uper cover of adf one is broken check and replace if necessary
Apr 22, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
Minolta DiALTA Di183 Copier Logo
46 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
CheckitRight
CheckitRight
David Burkhart
David Burkhart
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
