Question about Lexmark C522n Laser Printer
I have my driver now for my Lexmark C522, but can't connect!
Thanks to Kakima, I have the driver, but I can't seem to connect it to the Mac. The computer can't see it, so when i click on the plus sign to add a printer, I can't see it in the options. Do Ineed to do somthing more than just install the driver?
  • Chris Dec
    Chris Dec Mar 29, 2014
    Duh... I shut the printer off... waited for a few seconds, put it back on and there is the printer in my options! I forget the almost universal fix for many computer problems is turnit off, then turn it on. Thanks everyone... I think I am good to go. This is a fabulous site.
Hi i have a lexmark printer that i use to have connected to an old computer but now need to connect it to my netbook. The paperwork for the printer has x1100 but the printer has x1180 on it. My problem is...
Before you connect the printer via the USB cable to your netbook, check the version of the operating system(e.g. Mac or Windows - XP, Vista or Windows 7). If you are using Vista or Windows 7, check if it's running on 32-bit or 64-bit operating system by going to the Start menu > right click on Computer > Properties. NOTE: USE VISTA DRIVER IN WINDOWS 7. FOR MAC, ONLY WORKS UP TO 10.3 version.
You can download the Lexmark X1180 driver by visiting the Lexmark website at http://bit.ly/9W56vE. Click on "change OS" to select your operating system (see image):
Then click on "FILTER" (see image):
Click on the driver under "Recommended Downloads". Download, execute the file and follow the instructions in the software.
Hope this helps. Let me know if you need further assistance or you can also contact Lexmark technical support. Thanks.
Nov 01, 2010 | Lexmark C533DN InkJet Printer
I have an X6100 What is the download for a mac pro?
Try these :
1. Lexmark x6100 driver for mac
2. Lexmark x6100 driver for mac
3. Lexmark x6100 driver for mac
One of the above given links should be compatible for your Mac.
Good luck.
Thanks for using FixYa.
Sep 20, 2010 | Lexmark Office Equipment & Supplies
I have plenty ink but i cant get anything that has blue in it
The issue might be caused by a defective or improperly installed supply. Here's an article on Colors Missing on Pages Printed on a Lexmark C520, C522, C524, C530, C532 or C534. Just click on this link: http://bit.ly/aR3uRB. You can also try swapping the supplies, however, if the problem continues it's a possible EP driver assembly or printhead assembly issue. If you're having difficulty following the instructions, don't hesitate to contact Lexmark technical support or your authorized service provider for further assistance. Thanks.
Aug 30, 2010 | Lexmark C534N Printer
Light yellow horizontal lines on C522
Remove the supplies and clean the yellow printhead. For instructions on how to clean the printheads, click on this link: http://bit.ly/bCoz92. Just follow the instructions. If that doesn't help, might need replacement. If issue remains after printhead has been cleaned and the supply has been replaced, I suggest you contact Lexmark Technical Support for further assistance. Thanks.
Jul 11, 2010 | Lexmark C522n Laser Printer
Trying to get lexmark 8300 series to work on my mac.....no one seems to know the answer to this one.....pls help
The Lexmark 8300 was not designed by Lexmark for Mac and therefore there are NO drivers to support this printer with Apple products.
Apr 17, 2010 | Apple MacBook Mac Notebook
My new lexmark z640 does not seem compatible with my mac
  • Unplug the printer cable from the computer.
  • Unistall the printer drivers from Device manager and also unistall the all the printer appications
  • restart the computer
  • try to download drivers from the below given link by selecting the Operating System
http://www.downloaddelivery.com/downloads/cpd/cjb640EN.exe
  • after installing the cannon drivers and software it will ask you to connect the printer.
  • then you can connect the printer and print a test page.
Hope this help. Please Rate My Response! Thanks!
Prem
Dec 18, 2008 | Lexmark Z640 InkJet Printer
Lexmark C500n is not working under Mac OS 10.5
yes there is no MAC driver you have to manage with windows.
Sep 20, 2008 | Lexmark C500n Laser Printer
Lexmark Z45 drivers needed for mac
The mac driver for the Dell 1700 is Lexmark 332N. The mac driver for the Z45 is on the Lexmark web site.
Feb 24, 2008 | Dell 1700 Laser Printer
Lexmark C522n Laser Printer Logo
47 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
