Question about Casio Edifice Watches
Analog second hand not working
EF550RBSP
Do I reuse 2 batteries for my Umbro chrono watch?
Normally the Umbro Chronograph watches having analog and digital clock works on single battery. When u put the battery inside ur digital is working fine but some times for analog hands do not move due to the loose button which is used to move the watch hands. So pull it out again and insert it agin gently till tick sound comes and u r good to go.
Let me know if ur watch is working successfully:)
Jan 27, 2017 | The Watches
I have a casio ediface 5033 80W-M10008 how do I set the analog time
Thank you for contacting FixYa.
To set the analog time, press the lower left button 6 times. Next, press and hold the upper left button until the digital time starts to blink. This indicates that you are in analog time setting mode.
Analog time adjustment is completed using the lower right button. Every time you press the button, the analog time will advance 20 seconds. If you need to make a big change to the analog time, press and hold the lower right button to make the hands move faster. Once the analog time is set, press the upper left button to exit the analog time setting mode.
Best regards. Jewel
Sep 15, 2010 | Casio Edifice EFA109-7AV Wrist Watch
How to set the hands to match the correct digital display on my Casio wave ceptor 2734 wva-104h watch
Setting Digital Time
  1. The digital timepiece on a watch is set using the function buttons on the outer part of the watch face. To set the digital time, press and hold the upper left button until the seconds starts blinking. Press the lower right button to reset the seconds to "00."
    Push the lower left button to move to the Daylight Savings Time portion of the watch. Use the lower right button to toggle between "On" and "OFF."
    Press the lower left button twice. The hours unit will start blinking. To advance the hour, press the lower right button repeatedly until the correct hour is displayed. If you need to move the hours unit backwards, press the middle right button until the correct hour is displayed. When the hour is set, press the lower left button to switch to minutes, and use the same commands to change the minutes unit.
    After the time is set, press the upper left button to exit the digital time setting function.
  2. Setting Analog Time
  3. You may find after setting the digital timepiece that the analog display does not match. When this occurs, you need to set the analog time. To set the analog time, press the lower left button 6 times. Next, press and hold the upper left button until the digital time starts to blink. This indicates that you are in analog time setting mode.
Aug 21, 2010 | Casio Watches
Analog second hand freezes periodicaly, digital clock works fine
mcdevito75 here, Sounds like the seconds hand is bent and hanging up on the face. See the repair service directory her at fix ya, bottom of the page click on repair service directory the watches.
Jun 24, 2010 | Timex Expedition 84601 Wristwatch
I have a Pulsar Analogue & Digital Type Series PP4 model PP4005. I am having trouble setting the analog time. When I rotate the crown, the minute hand and hour hand rotate, but when I set the correct...
It's broken. Mine is doing the same thing. Others online have experienced the same defect. I bought mine from woot.com in July and just gave it to my son for Christmas. Check the Seiko website and send it in for repair. It has a 3 yr warranty.
Nov 23, 2009 | Watches
The second hand stop moving but the watch is still working? how do i get the second hand to move?
The hands of an analog watch are often only press-fitted on the shafts (hour and minutes are tubular, seconds solid shaft) and the second hand has probably only slipped so it is no longer being driven. I suspect a watch-maker could reattach it for a small charge.
Sep 25, 2009 | Chase-Durer Bomber Command CD119.9JJX.BR09...
Getting analog part of Mossimo watch to start
FIXED!!!
As it turned out these Mossimo ANA/DIGI watches use two different batteries, one for the digital part (big) and other for the analog mechanism (small).
Have the watch serviced to change the second battery and VOILA!!!!
Enjoy!
Mivales.
Made in Costa Rica!!
Sep 01, 2008 | Watches
Watches Logo
32 people viewed this question
Top Casio Watches Experts
Kazim ERGUNEY
Kazim ERGUNEY
Ansel Alberto
Ansel Alberto
Are you a Casio Watch Expert? Answer questions, earn points and help others
