Question about Vizio VX240M TV
How to reset a vizio television without the remote
Brightstar remote universal remote control codes for vizio television
Try using code search. If all codes stored in the remote control are searched without results, you may have to try a different universal remote control.
Nov 03, 2017 | Vizio Televison & Video
Setting up vizio sb200 without control lost only have remote to tv
You must have the remote, only the most basic functions can be used without the remote. You can most likely get and OEM remote on eBay or at this site: 1 800 Remotes
Dec 22, 2016 | Vizio Televison & Video
Factory reset without remote
You must have its original remote control do do a factory reset, because, there is no other way to enter its service mode, without its original remote control. A universal remote won't do.
Aug 11, 2013 | Vizio E421VA 42 in. LCD TV
Vizio tv601i remote stop working
if the vizio tvs are of different model numbers but same type name they may not work with same remote as they say, product subject to change without prior notification.....solution.....get the exact remote for that particular vizio model
Jul 20, 2013 | Televison & Video
How to take a vizio 24" tv out of demo mode without remote
go to menu button on side panel to setting setup
Feb 01, 2013 | Vizio L32 32 in. LCD HDTV
How do I hard reset the parental control on a used Vizio p42hdtv10a I just purchased from a TV repair place without a remote?
You will need the original remote (not a universal) and also help from LG by model number for the pin reset----some sets have 9999 for a way to get in but still will need the correct remote. Never purchase a used set without the original remote is my motto.
May 02, 2012 | Televison & Video
How do i reset the parental controls without a remote?
If the TV has a menu button at its front panel, you can access the parential control window and set the control to OFF. If the TV has no Menu button on its front panel control, you must have its original remote control to access this window. Contact the nearest authorised service center for Vizio at your town, to get an orginal remote control to your Vizio TV.
Mar 01, 2012 | Televison & Video
How to exit off photo from vizio tv without remote
First unplug the Tv plug , After you do that hold your power button for about 1 minute then plug your Tv plug back.
Jan 07, 2012 | Vizio VO47L 47 in. LCD TV
Need codes and instructions to reset remote for TV
I would need the make and model number of your remote. Often the model number is located inside the battery compartment.
Jun 17, 2008 | V, Inc. VIZIO RP56 Rear Projection...
Vizio VX240M TV Logo
105 people viewed this question
Top Vizio Televison & Video Experts
CoppellTVRepair.com
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
