Duplo DFC-12 On-line IF Err
On-line IF Err on the Duplo collator
The machine was jamming. I pulled the collator away from the base of the image runner. The paper was only 1/2 in the black box and 1/2 up the upper section that the paper goes through. After the paper...
I problem on duplo collator 10000s, is missfeeding the paper, don't pick the the paper, i set the correct hight, and **** pressure, i technician toll me that power supply need to repair , but i don't trust, just some one gime adviced
Oct 28, 2010 | Office Equipment & Supplies
Would like to download owners manual for Duplo DP21
YOU CAN DOWNLOAD IT VIA WWW.GETMANUAL BUT HAS TO PAY SMALL FEES VIA CREDIT CARD
Mar 31, 2010 | Duplo DP21L Copier
Collate copies
The control to collate printing is in the driver. If your machine is equipped with an output tray that will offset sort the sets then they will be staggered otherwise they will be in one stack.
This machine does not collate while copying. Dah...shame on Xerox!
Jan 06, 2010 | Xerox DocuColor 12 Printer
MY Duplo copy machine is DP-24SII.my problem is the ink con`t run out from the drum surface or the ink con`t transfer to my clothes
We AEBO is professional manufacturer of compatible duplicator ink and master for Riso ,Ricoh,Gestetner,Duplo.
For Risograph : RZ/GR/RA/KS/CR/RN/RP/RZ/TR/FR /GRHD/RPHD
For Ricoh: VT/JP-6/JP-12/JP-500/JP-10
For Gestetner: CPI2/CPI7/Stencil ink 217 /CP15/18
For Duplo: 504/51F4/544/744/ND 24
With high quality at economical price . We have been awarded USA SGS certificate and China Excellent Brand.
AEBO packing ,neutral and your customized packagings are all available.
Sincerely hope a pleasant cooperation with you .
meachell@chinaaebo.com
Mar 19, 2009 | Duplo DP21L Copier
HP 3055 printing black lines when using collate feature to copy
All you need to do is to clean the small wide glass (that at the LEFT of the main flat big class). The Auto Document Feeder (ADF) specifically uses this glass to scan for copy (and fax). When it is dirty (such as small dirt or particles on the surface which is easy to gain in long run), it will create thin vertical line(s) as the result.
Jan 28, 2009 | HP LaserJet 3055 All-In-One Printer
Got error code e104 duplo DP-460H
Jan 08, 2009 | Duplo DP460H Copier
Lexmark 4039 10r
I'm pretty sure this is a printer not a copier.
Take out the cartridge and turn it upside down, you will see a (Usually) green cylinder, does it have a ring of toner, or does it appear to have been scrathed ?
Take the copy and put it next to the drum, does the lines match? Then replace cartridge.
If not open back and take out fuser ( two screws for cover and two screws for fuser, are the rollers o.k? replace fuser.
Oct 02, 2007 | Riso RZ310 Duplicator
23 people viewed this question
jasbo
jasbo
