Question about McCulloch Garden
I have a McCulloch Mac3200, I have replaced all the fuel lines, rebuilt the carb, new spark plug, and clean the muffler. When it warms up it will change rpm at high speed and bog down and has no power. It is fine until it warms up. What do I need to do?
    Sergeant:
  • 384 Answers
Sounds like you may have not mix the proper amount of oil to the gas. As the piston expands due to heat build-up the engine slows down.
Posted on Jun 15, 2009
Weedeater idles but bogs when i press the throttle.i rebuilt the carb,changed all fuel lines and gourments and removed muffler,cleaned screen.replaced plug. Still no change.I noticed a small amount of fuel...
as long as your fuel mixture is correct, thier is an air fuel mixing screw on the carb locate it adgust it wial it is running u can hear , see and smell the diferance how it is running .check proper plug gap and condition.good luck
Feb 25, 2013 | Garden
Chainsaw wont throttle up dies out;cleaned out carb. relaced fuel lines .
pull your muffler off and see if it revs up, if it does then your spark aresster screen or muffler is plugged, from carbon or mud dobber hornets
May 22, 2012 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
My homelite starts good,when warm wont run when pull throotle on
hello sir, my machine will only start when pumping primmer bulb or squirting fluid in the carburetor than stops. the fuel line has broken off, in most small carburetors this is a ongoing problem.old fuel will crystallize when left in tank for a long time.plugging up ports, fuel lines, small screen in carburetor.fuel lines will dissolve clogging carb.this is why it will run when the choke is on creating a vaccum to where there is fuel forced in the carb to rum,also the gas will evoporate leaving the oil behind clogging up carb.the thing to do is remove carb. and clean out,replaceing gaskets or fuel line if necessory.use carb cleaner to clean out carb.make sure to make note where fuel line go.the fuel filter broke off of fuel line letting debris get in carb plugging it up.the muffler is known to clog up a lot on these machines where thay want run. the compression should be 60 to 120 lbs any thing below 60 is junk. when adjusting the carb screws turn in all the way than turnout 1 1/4 turns turn in slow untail machine runs also you need to check for spark by removing plug and grounding aginst engine to chech spark, ok.a new spark plug would be a good ideal too , if you are going to make these repairs use new fuel line and filter,hope this helps,any comments welcome,thank you, ~~
Feb 03, 2012 | Homelite Mighty Lite Lawn Trimmer
My husky 576 is pouring fuel out of muffler and collecting gas at spark plug. What should I.do
carb needs to be rebuilt you will most likely just need the diaphragm kit , may be time for fuel lines also. can be a little tricky to do.. part costs about $10-15 or less don't forget to clean the screen in the muffler . this should spark her back to life
Jan 31, 2012 | Husqvarna Garden
Mac 335 chainsaw won't start /run
Start with basic stuff first, drain the fuel tank and re fill with clean fuel oil mix, press the purge bulb ten or so times to pull the fresh fuel into the carb, now try again, if no better remove the spark plug and check for a spark ( make sure the ignition switch is on ) no spark try a new plug, still no spark check for wires shorting out, if ok replace the ignition unit, if it has a good spark is the plug getting wet with fuel, if not it may have a blockage in the carb, this will require a carb re build, if the plug is wet remove the muffler and check the condition of the piston through the exhaust port, any damage here and the saw will require a re build and possible new cylinder and or piston.
Jan 22, 2011 | McCulloch Garden
Mcculloch start with choke will run when choke in will not run when use throttle wont pick up
Fuel starvation - 'lean fuel' condition
Basic things to check:
1) spark plug
2) spark arrestor in muffler
3) fuel lines and tank filter
4) turn adjustment needles out (counterclockwise) 1/4 to 1/2 turn
Chain Saws:
5) check impulse tube and intake boot for cracks or leaks
*if all of the above are OK and/or do not improve performance then:
Remove Carburetor
6) replace gaskets/diaphragms
a) use a spray carb cleaner to clean jets, holes, and body of carb
b) fuel pump diaphragm goes against the carb body,
then the gasket towards the outside
c) metering gasket goes against the carb body,
and the diaphragm goes towards the outside
I’m happy to assist further over the phone at https://www.6ya.com/expert/rolandw_c013176d62ee17ae
Nov 21, 2009 | McCulloch Garden
Homelite bx90 leaf blower: won't run in cold weather
Basics to check:
1) Spark plug - brown or dark brown - OK
a) is it carbon or fuel fouled
b) is there spark
2) Muffler remove for inspection
a) exhaust screen clean or plugged
b) inspect cylinder wall/piston as the flywheel is slowly rotated
3) Check cylinder compression
1) spark plug
Chain Saws:
Remove Carburetor
Nov 15, 2009 | Homelite 'Yard Broom' Leaf Blower
35 cc
1) spark plug
Chain Saws:
Remove Carburetor
Nov 13, 2009 | McCulloch 16 In 4.5 Hp Electric Chainsaw...
Yesterday I ran the unit dry on fuel, I have rebuilt carb/replaced all fuel lines and replaced the spark plug and it still won't make rpm's
May still have dirt trapped in the carb.... take it to a specialist for "Sonic Cleaning"
Also may be worth taking the exhaust/muffler off and checking the bore for score marks to make sure it isnt seizing up
Oct 08, 2009 | Homelite 'Yard Broom' Leaf Blower
Garden Logo
145 people viewed this question
Top McCulloch Garden Experts
Jim Parker
Jim Parker
roeb
Matt Olenzek
Matt Olenzek
Are you a McCulloch Garden Expert? Answer questions, earn points and help others
