Question about Pioneer VSX520 Receiver
Unlocking volume lock
The volume on my receiver is locked at 48. How can I get it to go louder?
I cannot hear any sound out of my Polaroid TDX-01930B television.
Hello
First make sure that the "Mute" function is OFF. If it is set to "ON", no volume will be there.
Your TV has a volume lock function included [Global Volume Lock].
The remote comes preset to allow independent volume control of each selected device (Global
Volume Unlock). However, you may change the Volume Lock setting to Global Volume Lock so that
one device's volume will control volume in all other modes. After that, you can perform Individual
Volume Unlock on a selected device to set its volume control for independent operation or Global
Volume Unlock to remove all volume locking.
Locking Volume Control to One Mode (Global Volume Lock)
[1] Press and hold SET UP until the red LED blinks twice; then release.
[2] Enter 9-9-3 and then press the mode key for the device you want to control volume (for
example,TV). The LED blinks twice. Now when you press VOL+, VOL-, or Mute, the selected
device (for example, TV) will control the volume regardless of the current mode.
Unlocking All Volume Control (Restoring Global Unlock)
[2] Enter 9-9-3 and then press VOL+. The LED blinks four times.
Volume is now independently controlled for all programmed devices.
Unlocking a Single Device's Volume Control
[1] Press a device key (TV, VCR/DVD, CBL/ SAT, or AUX).
[2] Press and hold SET UP until the red LED blinks twice; then release.
[3] Enter 9-9-3 and then press VOL-. The LED blinks four times. Volume is now
independently controlled for the selected devices.
OK
May 06, 2011 | Polaroid TDX-01930B 19 in. LCD HDTV
Unlock code
Enter your 15 digit IMEI
>>>Before we can send your unlocking code we need you to do something for us first. Every phone has a code that is as unique as a fingerprint, it is called an IMEI number. To locate your unlocking code we need you to provide us with your IMEI number. (You can either locate your 15 digit IMEI number underneath your battery, usually on a label, or alternatively you can simply dial *#06# on your phone)
Unlocking code is requested for your IMEI
>>>Once we have received your payment we send a request for the unlocking code for your Pantech Duo. Within 48-72 business hours (excluding weekends & holidays) of us receiving your payment we will send you your unlocking code with step-by-step instructions on how to enter it
Your Pantech Duo is instantly unlocked
>>>After entering the IMEI unlock code, your phone is instantly unlocked and ready for use on any GSM Network. This is a permanent unlock and your device can never be locked again
Apr 22, 2011 | Pantech Duo Smartphone
Receiver very low when watching tv or dvd
It's just "Digital Audio" vs "Analog Audio" You can use the "Volume Offset" function in the receivers "Main Menu" to compensate for this. Go into the menu then go to audio and or input settings and you can adjust the offset and lock it in. If you still have a problem, post a comment and I can help you some more. There is not a "problem" it's just the way the audio is transmitted. Like when your watching TV and a commercial comes on and BLOWS you out of the room. That's going from clean digital to noisy analog.
Aug 05, 2009 | Yamaha RX-V463 Receiver
How to take off the volume lock off a 2gb silver ipod nano
On your iPod go to "Settings" then "Volume Limit," now change it.
Hope this helps!
Jul 05, 2009 | Apple iPod nano
Need to unlock my sony ericsson k850i please
try this steps
number1logo.gif Enter your 15 digit IMEI
›››Before we can send your unlocking code we need you to do something for us first. Every phone has a code that is as unique as a fingerprint, it is called an IMEI number. To locate your unlocking code we need you to provide us with your IMEI number. (You can either locate your 15 digit IMEI number underneath your battery, usually on a label, or alternatively you can simply dial *#06# on your phone) number2logo.gif Unlocking code is requested for your IMEI
›››Once we have received your payment we send a request for the unlocking code for your Rogers Sony Ericsson K850i. Within 48-72 business hours (excluding weekends & holidays) of us receiving your payment we will send you your unlocking code with step-by-step instructions on how to enter it number3logo.gif Your Sony Ericsson K850i is instantly unlocked
›››After entering the IMEI unlock code, your phone is instantly unlocked and ready for use on any GSM Network. This is a permanent unlock and your device can never be locked again
Jun 19, 2008 | Cell Phones
Please help me a little bit..
palzacer07,
plug your into ur computer as if u were gonna charge it and itunes should pop up saying how much memory and stuff u hav. above that there i sa button that says RESTORE. press that and it should put it back to the original settings but u will lose all ur songs.!..thank you!!..
Jun 15, 2008 | Apple iPod nano
No Sound
1) First check the mute.
2) Make sure there aren’t headphones plugged in, that will disable the speakers.
3) Check the audio setup
4) Check your Volume lock
Changing Volume Lock
The remote comes preset to allow independent volume control of each selected device (Global Volume Unlock).
However, you may change the Volume Lock setting to Global Volume Lock so that one device’s volume will
control volume in all other modes. After that, you can perform Individual Volume Unlock on a selected device to
set its volume control for independent operation or Global Volume Unlock to remove all volume locking.
1. Press and hold SET until the red LED blinks twice; then release.
2. Enter 9-9-3 and then press the mode key for the device you want to control volume (for example, TV).
The LED blinks twice. Now when you press VOL+, VOL-, or Mute, the selected device (for example,
2. Enter 9-9-3 and then press VOL+. The LED blinks four times. Volume is now
Unlocking a Single Device’s Volume Control
1. Press a device key (TV, VCR/DVD, CBL/ SAT, or AUX).
2. Press and hold SET until the red LED blinks twice; then release.
3. Enter 9-9-3 and then press VOL-. The LED blinks four times. Volume is now
Mar 15, 2008 | Polaroid FLM-2632 Television
Pioneer deh-p750 locking
Try pressing the reset button. It is usually in a little recessed hole on the front panel.
Aug 28, 2007 | Pioneer DEH-P750MP CD Player
FAN LOCK
Well it seems like you got a big problem, its because if its to high of volume the fan should start, read the instructions if that dont work, take a-part the unit look at the fan then if its not fixable buy a new fan
May 21, 2007 | Sharp XLDV60H Shelf System
Pioneer VSX520 Receiver Logo
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
Ian Summerfield
Ian Summerfield
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
