Question about Bose Wave Radio
No power Display will not light up no power to radio at all
What fuse is the radio light fuse
What make , module an year vehicle ! Probably the display part is bad , need new radio or have yours fixed . Most usually only one power fuse .
Sep 13, 2016 | Cars & Trucks
Hyundai tiburon 2005 factory radio not working? Power issue maybe?
If the radio was on when you jump started car you may have overloaded display, and the radio as a whole may have suffered. You may need to replace the radio. Sorry can't be more help.
May 06, 2017 | 2005 Hyundai Tiburon
I own a 1999 Mercury Grand Marquis and I need some help. With the headlight switch in the off position all dash and display lights including the digital clock work fine, but the display on the radio and...
There are two 15amp fuses marked 4 and 8 that provide power to the light control module. If those fuses are good, and those circuits have power, the problem may be with the control module. The module provides power to the dash lights.
You may need a shop to trace the circuits and find the problem.
Aug 16, 2012 | Cars & Trucks
Lost radio illumination in 2008 HHR
Internal workings of the radio, if the radio is operating fine then your bulbs/lighting inside the radio is bad as the lights come on with power to the radio. Normally they don't replace this and just swap the radio which is expensive. If the vehicle is still under warranty I would take it back and even if its not its an 08 go and raise hell to the dealer and force them to buy you a new radio!!
Nov 11, 2011 | Cars & Trucks
02 altma radio is working but no clock or radio display at all
First thing look in owners manual for fuse, radio is on different fuse then light display, most likely it is a fuse.
Jun 08, 2011 | 2002 Nissan Altima
Radio lights, steering wheel radio controls, and HUD not lighting
well, this morning they are fine, all i did was checked all fuses that had to do with illumination and radio. none were bad so no replacements were made, and now it works. wish i knew what i did.
Dec 08, 2009 | 2002 Audi A6
Oem Radio installation
*** 91 park ave with delco bose =
black = ground
dark green = lights on input
grey = panel lights
pink = on input
yellow = power input
orange = battery power input
nca = shield ground
tan = left fr spkr +
orange/black = left & right spkr -neg
lite green = right fr spkr +
nca = shield ground
dark blue = right rear spkr +
dark green/yellow = right & left spkr - neg
brown = left rear spkr +
purple/white = display dim output
pink = vehicle speed input
**** 91 park ave without delco bose =
grey = left front - neg
tan = left front + pos
dark green = right front - neg
light green = right front + pos
black = ground
dark green = display dim signal
grey = panel lights
pink = power antanna
yellow = ign input
light blue = right rear - neg
dark blue = right rear + pos
yellow = left rear - neg
brown = left rear + pos .
there YA go
Dec 27, 2008 | 1991 Buick Park Avenue
Radio shuts off when I turn the lights off
does it actually turn off... or do the lites just go off... is that an aftermarket radio... it sounds like they have used the power wire that puts power to the display onto the power wire for running the radio.
Robert
Dec 18, 2008 | 1997 Mercury Mountaineer
My 2000 grand am anti theft radio is locked and I need help unlocking it
This solution is for a 1999 Grand Am SE am/fm radio with tape cassette player:
Ido not know if this works for other Grand Am products past or prior 1999.
If the lcd display of the radio indicates "LOC" if you do not see anything on the display the small light behind the display is out and you need electronics to go further. If LOC appears here is what to do:
First put the ignition key to the ACC position.
2- press the HR clock adjust button once only ; the display should read 000
3-push the HR button successively until you reach 17 on the radio displayffd4cd1.jpg 4-then press on the MN (minutes) button again until you reach the number 42
5-when the number 1742 appears on the display, press on the AM/FM button once and after on the POWER/VOL button to power up the radio.
Sep 02, 2008 | Pontiac Grand Am Cars & Trucks
Bose Wave Radio Logo
27 people viewed this question
Top Bose Audio Players & Recorders Experts
Invebo
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
