Question about GE Two Ericsson M-pa Mpa Hand Held Radios Chargers
No charcher Is there any other way to charge the batterie
    Dedicated:
    Visited the website for 20 consecutive days.
  • 341 Answers
Find a very similar charger (volt/amp) to battery power and cut the mini plug of, separate and trim wire ends then tape wire-ends to correct poles on battery. Then charge as normal.
Posted on Apr 07, 2014
Dead battery 1990 xlh sportster 1200
The voltmeter test provides a general indicatorof battery condition. Check the voltage of the battery to verify that it is in a 100% fully charged condition. If the open circuit (disconnected) voltage reading is below 12.6V, charge the battery and then recheck the voltage after the battery has set for one to two hours. If the voltage reading is 12.8V or above, perform the load test described below.
The load test measures battery performance under full current load and is the best indicator of battery condition. Load testing a battery tat is not FULLY CHARGED i.e. at 12.8 VDC can permanently damage it. Fully charge it first and then let it stand for at least an hour before the load test is done. You also need a load tester. AND you should know how to perform a load test. Often the best way to load test a battery will be to take it to a battery shop and have it done there.
VOLTAGE (OCV) STATE OF CHARGE FOR AGM BATTERIES IS:
12.8 VDC = 100%
12.6 VDC = 75%
12.3 VDC = 50%
12.0 VDC = 25%
11.8 VDC = 0%
COLD CRANKING AMPERAGE (CCA) for a DYNA battery is 270
19 AMP HOUR BATTERY =
BATTERY STATE OF CHARGE = 12.8 VDC = 100% Charge; Rate of Charge = N/A
BATTERY STATE OF CHARGE = 12.6 VDC = 75% Charge; Rate of Charge @ 3 AMP = 1.75 hours @ 6 AMP = 50 minutes @ 10 AMP = 30 minutes @ 20 AMP = 15 minutes
BATTERY STATE OF CHARGE = 12.3 VDC = 50% Charge; Rate of Charge @ 3 AMP = 3.5 hours @ 6 AMP = 1.75 hours @!10 AMP = 1 hour @ 20 AMP = 30 minutes
BATTERY STATE OF CHARGE = 12.0 VDC = 25% Charge; Rate of Charge @ 3 AMP = 5 hours @ 6 AMP = 2.5 hours @ 10 AMP = 1.5 hours @ 20 AMP = 45 minutes
BATTERY STATE OF CHARGE = 11.8 VDC = 0% Charge; Rate of Charge @ 3 AMP = 6 hours, 40 minutes @ 6 AMP = 3 hours, 20 minutes @ 10 AMP = 2 hours @ 20 AMP = 1 hour
The figures listed above assume that the battery is charging at room temperature. If warmer than room temperature, use a slightly shorter charging time. If colder, use a slightly longer charging time.
The use of constant current chargers to charge maintenance-free batteries is not recommended. Any overcharge
will cause dry-out and premature battery failure. If a constant current charger is the only type available, do not exceed the charge times listed above and do not continue charging the battery if it gets hot. When charging, never exceed 15 volts for more than 30 minutes.
If the battery gets hotter than 110 degrees F. (43 degrees C) during charging, discontinue charger and allow the battery to cool. Overheating may result in plate distortion, internal shorting, dry out and/or other damage.
Apr 22, 2014 | Harley Davidson XL 1200 S Sportster Sport...
Chaging batter
12.8 VDC = 100%
12.6 VDC = 75%
12.3 VDC = 50%
12.0 VDC = 25%
11.8 VDC = 0%
COLD CRANKING AMPERAGE (CCA) for an XLH battery is 270
COLD CRANKING AMPERAGE (CCA) for a 2001 XLH battery is 270
I have 2 DeWalt Lithium-ion batteries Apprx. 4 years old, charged 3 times...won't charge now
Either bad batteries or a bad charger. You can use a multimeter to test for DC voltage output in the charger.
May 03, 2012 | Dewalt 18v Battery Hammer Drill Dcd950...
I purchase a stanley 450 amp battery jumper.and i woul like to know how can i plug a radio in my ice shack with this product and if so where can i purchase this.to whom this may concern thank you.
the most simple way to run the radio from a charcher is to hook radio and charger to a battery
the charger will charge battery and battery will supply constant volts to run radio
Jan 04, 2011 | Stanley Garden
I lost my charcher so im trying to do it with the computer but i cant,
Having gone over a month without a response to my query regarding make and model, I assume this is no longer a problem.
Sep 21, 2010 | Cameras
Charger is too hot
Some chargers do run a bit on the hot side. Check your charger with an ohm meter to see if it's getting the proper output. If not, then the charger is struggling to run the machine, and this is causing it to heat up. Also keep in mind that if the charger isn't getting the proper output to the machine, it can damage the new battery or the machine, and will need to be replaced.
Aug 07, 2008 | HP Pavilion dv6000z Notebook
Battery charge indicator seems faulty.
Solved own problem. Bad conection between pcb and battery contact pins. Reheat each battery pin on the pcb carefully until solder reflow occurs then remove heat. PDA now repaired
Aug 03, 2008 | Fujitsu Pocket Loox 410 Pocket PC
Jensen GPS charger adapter
just get a standard 5 volt charger. Most 5 volt chargers use the same plug size. My jensen uses the same charcher as my pocket pc and my mp4 player.
Jun 16, 2008 | GPS
Samsung D500 not able to charge
Your port has been damage, somebody have prob plug it in the wrong way. Chepect selution is to buy a desktop or standalone charcher that you put your battery in to charge.
Dec 10, 2007 | Samsung SGH-D500 Cellular Phone
GE Two Ericsson M-pa Mpa Hand Held Radios Chargers Logo
43 people viewed this question
Top GE Radio Communications Experts
Greg Cann
Greg Cann
eradiostore
eradiostore
J.D. Browning
J.D. Browning
Are you a GE Radio Communication Expert? Answer questions, earn points and help others
