Question about Honeywell Seven Sheet Micro Cut Paper Shredder 9207 7 Sheet Micro Cut Paper Shredder
Overload light stays on
Motor will run in reverse red overload light stays on with the unit switched to auto/on position will not accept paper to shred or switch on in forward position when the paper is inserted
  • Honeywell Master
  • 1,087 Answers
Most likely the cutters are still stuffed with paper shreds and needs to be dismantled and cleaned
Posted on May 21, 2014
Why doesn't OfficeMax OM99732 shredder work on Auto?
My shredder would not sense paper being inserted and the sensor could not be cleaned. So "Auto" no longer worked but the manual reverse DID work. I opened the thing up, reversed the polarity on the red and black wires on the connector for the main drive motor and VOILA!!! I can use my shredder in manual mode by switching it to REV. Be mindful that this keeps the motor running until it is switched off. This can heat the motor and cause failure so I limit my shredding to 60 seconds then give it a rest so it will cool down. Also there is no emergency reverse so watch your fingers and neck ties.
Dec 17, 2012 | Office Equipment & Supplies
Shredded a few sheets of paper. clicked off. Have power at outlet. No damage to cord or connections. No auto reset of internal overload protection, amount of paper shredded far too few to trip...
Hi, make sure the cutters are not jammed with paper. To reset turn the unit to reverse for 2 seconds then auto then off. Allow to cool for 25 minutes then retry. Also make sure the base is locked in properly. Hope this helps, regards Phil.
Jul 08, 2011 | Fellowes Office Equipment & Supplies
My fellows jbo1 jamed and then stopped running is there a reset buton?
Chances are it's over heated.
Ensure the wastebasket is empty then move power switch to the REVERSE position. This will reverse the jammed paper out of the shredder. If shredder jams again, alternate control switch slowly between REVERSE and AUTO (l) positions to attempt to move jammed paper completely through the shredder. If the shredder jams in reverse mode, move the switch to AUTO (l), depress the manual forward button located on the center of the shredder head and allow to run for five seconds. If jam does not clear, move switch to REVERSE again and allow to run for five seconds. Repeat this process until jam is cleared. If necessary, turn off shredder and use care to grasp the paper and carefully pull out to clear jam. Once cleared, move switch to AUTO (l) to continue shredding. The jamming may be happening because the cutting cylinder needs to be oiled. See oiling instructions below.
From fellow's website: http://www.fellowes.com/fellowes/site/support/support_troubleshooting.aspx#jammed
Dec 15, 2010 | Fellowes Office Equipment & Supplies
Royal 85x crosscut shredder stopped working
Some shredders aren't designed to shred anything more than paper. Credit cards, staples, paper clips and the like could have jammed it up. Try running the shredder in reverse and oiling the blades. More help with paper shredder oil here: http://hubpages.com/hub/Paper-Shredder-Oil
If you can't get the paper shredder up and running, it looks like you might have to pick up a new paper shredder. Paper shredders can be pretty cheap though, great guide to cheap paper shredders here: http://hubpages.com/hub/Best-Paper-Shredders
May 25, 2010 | Royal 85X Shredder
Shredder will not start when paper is inserted. switch is on auto. This happened after a long session of shredding
Two possible problems;
  1. Teeth underneath lid are jammed; sometimes (especially after a long session) although the papers go through, debris builds up and can get caught in the teeth; to clear unplug and with tweezers or a tina flathead screwdriver, pull out shreds of paper still caught
  2. Motor is overheated; once cool, try it again (move switch to reverse to see if motor is still working). If motor is working, see Step 1 for a jam; some jams can be cleared by running it in reverse. Royal doesn't recommend "long" shredding sessions. My unit recommends sessions of 20 pages or less. If you try to overwork the shredder, it will overheat and in some cases, fry the motor.
I hope this helps answer your problem. Best of luck!
Greg
Nov 12, 2009 | Royal 10X Shredder
Runs in reverse, but no on auto.
check and see if there is a jam of paper inside the unit or around the sensors
Jul 20, 2009 | Royal 10X Shredder
The shredder will run in reverse but will not run foreward.
Inside the shredder there is a motor which is wired to run both forward and backward, the way it does this is to transfer the power from the switch to a couple of wires on the motor
The forward running motor will be linked to the auto start button which will tell it to work with the paper sensor.
When you select the Forward function the Auto Start is taken out of circuit and the Forward switch should supply the motor
After all of that I would say that the switch is open circuit on the Forward contact and needs replacing
Jun 12, 2009 | OfficeMax 0M96431 Shredder
Infoguard SX100M unit will not shred. Green light comes on.
I have the Infoguard SX100M Axeus, sold by Staples.
Only the reverse was working, UNPLUG and open back cover, the paper mechanical switch was working fine, red side switch, the gears and fuse were all ok, I think something on the circuit board was fried.
Anyways, I switched the BLACK and WHITE wires with each other going to the shredder motor, thus when I switched it to reverse, it would go foward and shred. Its working now, only in reverse.
Jan 10, 2009 | Cross Infoguard Shredder SX102M
Shredder runs in reverse only can u help?
make sure your paper sensor detector is clean....If so, you probably have a bade sensor...
Mar 30, 2008 | Fellowes P700-2 Shredder
Shedder one works
This is an issue with the paper feed sensor which may be a electronic eye or a mechanical switch if it is mecanical you may just have to jiggle the switch a few times, occasionally paper may get stuck behind it not letting it activate. If it is electronic you have bad sensors or bad pc board and you'll have to contact the manufacturer for further info.
Mar 07, 2008 | Aurora Global AS501X-MS Shredder
Honeywell Seven Sheet Micro Cut Paper Shredder 9207 7 Sheet Micro Cut Paper Shredder Logo
440 people viewed this question
Top Honeywell Office Equipment & Supplies Experts
 Mikey
Mikey
Lesley Cameron
Lesley Cameron
Are you a Honeywell Office Equipment and Supply Expert? Answer questions, earn points and help others
