Question about Sony RDR-VX420 DVD Recorder/VCR
Sony rdr vx410 dvd player playing some dvds in black and white
Playing dvds black and white
    Scholar:
  • 89 Answers
  • DVD's are standard definition video sources. Number of lines output is 576 lines, whereas your HD TV set has 720 or 1080 lines. This difference may result in a poorer image. However some DVD players are able to “upscale” picture to obtain a very good picture. Check if your DVD player has the following connectors: YUV, DVI or HDMI. For more information, refer to the instruction manual of your DVD player.
  • Some HDMI or DVI featured DVD players also have an internal processor that can upscale pictures from a DVD to 720 or 1080 lines to provide an excellent picture from a standard definition disc to your HD TV set. Those settings are available from the setup menu of your DVD player. Please refer to the instruction manual of your DVD player.
  • If your DVD player does not have those connectors and only has a SCART connector, or S-VIDEO, or composite, there is not much to do to improve the picture quality. Just make sure that you are not using the cheapest cables and that the picture settings of your TV set are correctly adjusted.
  • Some high end TV sets have a picture improvement engine that can soften a noisy image. Make sure that it is activated from the setup menu of your TV set. Please refer to the instruction manual of your TV set.
  • If people and objects have weird white outlines around them. This may suggest that your TV sharpness is set too high. Make the correct sharpness adjustments from the setup menu of your TV set.
  • Make sure you use good quality cables and that your cables are not too long (less than 5 meters long).
Posted on Jun 17, 2009
Sony RDR-GX350 not able to read recorded DvDs anywhere else except in this unit
Here is the manual. Page 99 shows you how to rest the recorder to factory defaults. https://www.sony.co.uk/electronics/support/res/manuals/3113/31137591M.pdf
Oct 29, 2017 | Televison & Video
RDR VX410 problems
go to sony support website & download software update.
Jun 07, 2012 | Sony Televison & Video
My Sony RDR-VX530 VCR/DVD player/recorder just stops playing
play a lens cleaner cd in it,,, it will work smoothly
Apr 21, 2010 | Sony RDR-VX530 DVD Recorder/VCR
CAN VIEW THE DVD ON A COMPUTER OR THE DVD RECORDER BUT NOT ON DVDS PLAYERS BOUGHT BEEFORE THE RECORDER
This is quite common of older players. Some only work with DVD+R discs and others with DVD-R discs.
Some player also does not read recordable discs (an early form to try prevent piracy)
Also make sure if recorded on your Recorder, that the disc is finalized before you try to play it on an older player. (See your menu / manual on the recorder for the procedure)
Feb 28, 2010 | Sony RDR-VX515 DVD Recorder/VCR
Only black and white
If you are playing different region dvds, they can be of different color formats also
(US = NTSC, Europe = PAL). If your television is not multi-format then non-compatible
DVDs will play black and white. The solution is to purchase a mutli-format TV (accepts
both PAL and NTSC formats)
Aug 31, 2008 | Sony DVP-NS50P DVD Player
Failure to record on -R DVDs
DVD-Rs do work with the RDR-VX500 ...... I had not recorded on mine for a few months after I ran out of the last batch ....... then I tried recording on the newer Sony DVD-Rs I had ...... would not record on DVD-R ..... turns out the instructions say the recorder will not work with any DVDs faster than 8x .... It looks like it's recording but it doesn't ..... then I noticed the newer DVDs were 16x ...... found an old 8x and tried it and it works fine ..... turns out the unit won't record slower on a 16x, it just won't record at all ...... get 8x and you'll be ok
Apr 23, 2008 | Sony RDR-VX500 DVD Recorder/VCR
Sony RDR-GX7 DVD player/recorder - won't play DVD's!!
okay check and see what region is your DVD player if your dv is a region it will not play a region 2 dvd.and the list goes on however you can buy an all region dvd that will play any dvds.good luck
Apr 27, 2007 | Sony RDR-GX7 DVD Recorder
I have a Sony RDR HX510, can you help me?
Have you finalised the dvd disc in the machine ? you must finalise all dvds before playing them in other machines.
Mar 18, 2007 | Sony DVD-NS530 DVD Player
Sony RDR-VX500 does not load some dvds, disc error.
Try the disks in another DVD player. If they play with no problems in another player, then you have a hardware issue with your Sony. Nowadays, if it is out of warranty, fixing it is not worth it, because it is cheaper to replace, at least in the USA.
Nov 27, 2006 | Sony RDR-VX500 DVD Recorder/VCR
Sony RDR-VX420 DVD Recorder/VCR Logo
314 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
