Question about Vitamix Super 5000 Work Top Blender
Heated up the almond butter and it still wasn't smooth
Almond butter not smooth and it got very hot
Grams to teaspoon converter
That depends on the density of the substance.
41 grams of water is about 8.32 teaspoons. 41 grams of mercury is about 0.615 teaspoons.
Aug 06, 2014 | Designer Whey Protein Powder Vanilla...
One ounce = how many grams
One avoirdupois ounce is about 28.35 grams. One troy ounce is about 31.10 grams.
May 03, 2014 | Designer Whey Protein Powder Vanilla...
After blending cake batter the blender became hot and it's not working what shall I do
You have burnt up the machine. It will no longer function and would be unsafe to try further. Replace it.
Jun 03, 2017 | Philips HR1350 SingleSpeed Handheld...
Can I upgrade motor on vitamix 4500...it wont make almond butter...
Contact Vitamix, find a service agent through them and have it looked at. You are only going to be able to get your motor (if you need one) through someone associated with Vitamix anyway.
Aug 27, 2012 | Vitamix Turbo Blend 4500 - Heavy Duty Vita...
How to make a smoothie with my bamix handheld blender
That wonderful little stick is all you need, I sure love mine! Make sure your Mixing cup is larger than the one supplied and remember to pump up and down vigorously as you blend. Keep swirling the bottom to make sure everything got picked up and blended. You can also make powdered salt,(great for french fries) powdered sugar, Dried garlic can be made into your own freshest garlic powder (great for spaghetti and pizza). peanut butter, apple butter and Whipped cream. I also use mine to make a crazy Jello only treat that tastes like sherbet, ice cream and Jello just by blending Jello and Ice cubes. Then I chill right away after pouring it into small 3 inch glasses.
Mar 13, 2010 | Bamix Mono Single-Speed Handheld Blender
Vita-mix Blender will not power on
We just had this problem.  Called VitaMix and they talked about resetting the thermal protection switch inside.  They suggested lifting the base down firmly, but gently, on the counter to help the internal switch reset.  I did it while they were on the phone and, sure enough, the machine came back to life.  Hope this helps.
Mar 29, 2009 | Vitamix TurboBlend 4500 Work Top Blender
Vitamix Super 5000 Work Top Blender Logo
46 people viewed this question
Top Vitamix Blenders Experts
Craig Butler
Craig Butler
Holly...
Holly...
Are you a Vitamix Blender Expert? Answer questions, earn points and help others
