Question about Boating
I have a 1986 Evinrude Outboard, I am able to tilt the motor up only but will not tilt down. When operating the tilt switch on the remote lever I can hear the relay clicking so electrically seems fine
1986 Evinrude 70 will tilt up but will not tilt down...please help!
    Sergeant:
  • 456 Answers
Check tilt switch and trim tilt relay
Posted on Mar 29, 2014
  • 5 Answers
SOURCE: How to disconnect shifting lever on a 1994
This is a long shaft, should disconnect just below carburetor. Pull all the way out of mid section.
Posted on Oct 02, 2010
  • 193 Answers
SOURCE: The trim/tilt on my 97 Johnson 150 outboard is not
Make sure there is not a spring loaded locking lift latch engauged. If there is you will see a little movement and then the motor will sound slower. If there is no movement and the motor runs the same speed with no change you are low on hydraulic tilt and trim fluid.
Please take a moment and rate my answer............ Thanks
Posted on Nov 30, 2010
  • 43 Answers
SOURCE: on my 150 yamaha four srtoke outboard. the tilt
That is a classic sign of a saltwater spray or water condensation buidup issue. Any time you are dealing with a powerplant issue on a boat, the prudent thing is to take ti to a mechanic. A vessel underway at sea without power represents a serious danger and can become a real emergency very quickly.
While I still believe it is almost certainly an issue with water that has mades its way into the controls I would not attempt to repair this problem without first running it by your local mechanic.
Good luck.
Posted on Apr 03, 2011
  • 12 Answers
SOURCE: I need wiring diagram for 1968 Evinrude 55Hp
barbosam08.jpgbarbosam08_0.jpgbarbosam08_1.jpg These are specific to that motor.
Posted on May 23, 2011
SOURCE: free download for repair manual for an Evinrude
My outboard motor is old and used.When I went to run it for the first time everything worked except when I went to put it in forward gear the boat went slowly but when I gave it more gas the engine just reved up but the boat wasn't going any faster.The motor is 40hp gale model.I think because it is bought used the prop is not the right one and it seems like it's slipping as I go faster.
I would appreciate any feedback on this problem.
Thax, Don
Posted on Jul 03, 2011
Identifying this outboard motor from evinrude, AQABVA71K899
Rob, AQABVA71K899 does not seem to come up as a valid # for referencing engine. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Outboard Engine Serial Number Year Match up
Evinrude Outboard Motor Model Numbers
EVINRUDE OUTBOARD MOTOR MODEL YEAR LOOKUP GUIDE 1913 1979 MASTERTECH MARINE
Jul 11, 2016 | Boating
Can't get any power to my evinrude tilt and trim what am I doing wrong ?
Check fuse.try connecting trim wires from t/tilt motor direct to battery supply to see if motor is ok.t/tit solenoid could be faulty,switches could be faulty.broken wire in loom or control box
Aug 16, 2014 | Sierra International 18-6756 Marine Power...
How do i install this cable and is this what locks motor in up and down position
your elec cmc elec tilt and trim will keep your motor from kicking up in reverse you must have a problem on the swivel bracket on the motor
May 16, 2014 | Light Outboard Motor Boat Bass Fishing...
How do i replace the water pump in a 2005 150 hp evinrude outboard motor
Take the cowling off. Also drop the foot. There wil be a stainless linkage rod that runs the length of the motor that you will have undo to drop the foot. The water impeller will be inside a stainless casing that you will have to disassemble.
Aug 17, 2012 | Boating
The trim/tilt on my 97 Johnson 150 outboard is not moving. Tilt motor runs. Some time ago my mechanic told me not to run the tilt all the way to the top, which is, I think, what happened. Any ideas on...
Nov 28, 2010 | Sierra International 18-6756 Marine Power...
Evinrude 225hp will not power tilt batteries OK manual release will turn but still not able to tilt motor?
Check trim tilt switch (if that's ok ) Try the trim / tilt relay inside the engine cover.
Could also be limit switch above the trim motor up further under the motor.
My bet is switch or relay
Good luck
Aug 14, 2010 | Clymer EvinrudeJohnson Outboard Shop...
Cant find how to tilt evinrude outboard
have you got hydraulic trim/tilt? if so control button /switch will be on or near throttle handle-if not you will have to manually lift and insert pin at bottom of mount on transom
Oct 02, 2009 | Boating
Can not lower the motor manually. 1989 Evinrude outboard 60 HP
There is a screw usally on the right side looking at back of motor use large screw driver loosen motor will come down I guess you have trim and tilt
Jun 14, 2009 | Boating
Boating Logo
211 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
