Question about Lenovo a780 dual sim
Maximum device limit reached for this user. Delete profile to register a new device
Amazon kindle instructions
according to the following page... "
How many Kindles can I use to access titles in my library?
Most books you purchase from the Kindle store may be simultaneously accessed for your personal use on up to six Kindles or Kindle-compatible devices (such as Kindle for PC or Kindle for iPhone) registered to your Amazon.com account. If the limit is less than six simultaneous copies for a specific title, you'll see the message "Simultaneous Device usage: Up to X simultaneous devices, per publisher limits" on the Amazon.com detail page.
If you reach the device limit and want to replace one of your current devices with a new one, you must first deregister and delete the content from the device you wish to replace before you can access the content in question from your new device. For device registration instructions, please see the Help page for the device you wish to register/deregister on the Kindle Support pages.
Subscription content such as magazines and blogs can only be downloaded to one Kindle at a time and cannot be accessed from Kindle for PC.
So yes, you can read the ebook on multiple devices, but be aware that there is a limit of 6 (or fewer) devices." http://android.stackexchange.com/questions/10094/if-i-buy-an-ebook-an-amazon-can-my-son-with-another-android-device-read-my-bo
Jul 04, 2014 | Tablets & eReaders
Won't login
when your netbook starts up, press f8 and from the following menu, choose to start using safe mode with gui. If you have specified an administrative password at the time of windows installation, use that to log on. If you have not, you should be able to simply log on with the administrative account. Now, go to the control panel>user accounts and create a new user account. Now, you should be able to logon using the new user account. Make this one an administrative/standard account instead of a limited one. When you logon using this account, you should be able to get your data of the previous account from C:\Users\<previous profile name>... You can take backup of this data and then delete the previous user profile to avoid further confusion.
Hope this helps.
Nov 19, 2013 | eMachines eM250-1915 Netbook
Cant login
Restart your computer in safe mode. To do this first power it down wait 10 seconds. Locate the F8 key; press power button an start tapping F8 key. This will bring you to a screen with many options. Choose safe mode. This is a limited mode but many things can be fixed including your profile. Option 1. Go to control panel user accounts. Here you can add an account. Option 2 Delete your account (make sure there is another account you can log into prior to doing this) Go to start->computer right click then click properties. In system properties click advanced tab. Under user profiles click settings. In the User Profiles dialog box, select the profile that you want to delete, click Delete, and then click OK. Click Start, type regedit in the Search box, and then press ENTER. Locate and then click the following registry subkey:
    1. HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\ProfileList
      Right-click the SID that you want to remove, and then click Delete.
  1. Log on to the computer and create a new profile.
  2. Hope this info helps.
Apr 27, 2013 | Acer Computers & Internet
I forgot my password to open this jump drive.My computer will not let me gain access to any of my files on the disk. What can I do to access it again?
Retrieving a forgotten password on a Cruzer Enterprise drive How do I recover the password on my Cruzer Enterprise drive? Password hint
If you set a hint when you enabled the password protection, click Hint in the log in window to display the hint you entered. If you did not set a hint or still can not remember your password, you can click Forgot Password on the logon window and choose a new password. This will reformat the drive.
Reformatting will delete all files and applications in the user-accessible removable partition.
Password attempts
There is a limit of 10 attempts (default) before the drive is locked and no further access is possible. During this process, you MUST change the password and reformat the drive. This is an important security feature, protecting data in lost devices from brute force hacking attempts.
Cruzer Enterprise drive managed by CMC (Central Management and Control)
A drive managed by the Cruzer Enterprise CMC software can be unlocked remotely by the System Administrator when it is inserted into an online computer. The System Administrator can unlock the drive remotely even after the maximum failed password attempts has been reached. The user must then choose a new password. Data stored in the removable partition will be preserved.
If the device is managed but in an offline computer, the System Administrator can send the user a one-time unlock code. The user must enter the code then choose a new password. The existing data on the removable partition will be preserved.
hope this helps
Feb 27, 2011 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Cant open applications! it says maximum no of applications reach
This happened to me and I found that by shutting off the phone and turning it back on will get rid of it...hope that helps :)
Apr 01, 2010 | LG CHOCOLATE BL40 (1 GB) Cell Phone
Flashing orange light. Have tried switching off and on, holding down power and resume switches. Nothing works
your printer has reached to its printing limit. Its printer has a maximum of printing point it is registered in the printer memory. When it reach to its limit it will stop. To solve this problem you need to use CSS Utility Software so that you can make the printer reset then you can print again. You can download for just type CSSutility software in google or yahoo. then download.
Feb 12, 2010 | Canon PIXMA iP90 InkJet Printer
The casio te-2200 ECR only can accept maximum 2000 scanning PLU. But cause the manufacturer change barcode very often, this machine reaches their 2000 limitation so quickly. So I want to know that if we...
The TE2200 maximum Barcode (Scanning PLU) is 5000, however, it is depend on how we "dissipate" the RAM memory.
You have to delete the unused Scanning PLU yourself.
Sep 17, 2009 | Casio Parts Cash Register PC Desktop
How do I delete and add other Mii's
This process only deletes Miis so that you can add new ones,
up to a maximum of 8.
Nintendo provides no advance notice that there is a limit of 8 players.
1. Go to the Wii Fit screen displaying all of your current Miis.
2. Select the Mii you want to delete.
3. Keep hitting the A button to go through all the extraneous jazz-ma-tazz nintendo inflicts upon us
until you come to the calendar page with the options BODY TEST and TRAINING at the bottom.
On this page you will see USER SETTINGS in the upper right-hand corner.
4. Select the USER SETTINGS page (push the A button).
5. Select DELETE USER DATA (push the A button).
6. Select YES to confirm that you want to erase the data.
I found this process very counter-intuitive as it required me to select the Mii that I wanted to delete,
then act as if I were going to use this Mii, before giving me an option to manage the settings for that Mii.
The process for using a memory card to save Miis has been impossible so far.
I purchased a Wii memory card, but cannot figure out how to bring the data from the memory card
back into the Wii Fit game.
Dec 30, 2008 | Nintendo Wii Fit for Wii
Flashing orange and green light
Nov 21, 2008 | Office Equipment & Supplies
Forgot my admin password how do logon
-There are two ways to access system 1 is for the admin and the other is for users.
-If you have forgotten the password for the USER , you may want to try this thing.
Winsows XP:
-Restart the computer-press f8 until you reach windows advance option menu-click safemode w/ command prompt-type c:windows\system32\restore\rstrui.exe -choose a date that you remember you can logon properly on your system.
- Follow the instructions given to perform the System Restore process.
Windows Vista:
-Restart system -press f8 until you reach windows advance option menu select REPAIR -select appropriate language settings -choose system restore.- GUI system restore page will come up -choose a date that you remember you can logon properly on your system.
-LAST OPTION
- Boot using the WinVista Installation DVD, then Run Repair Options- Launch command prompt, then type
-net user administrator /active:yes
-This will enable the “The Administrator account” in vista. Then try to boot normally back in vista.Take note that “The Administrator” account will be an option in the login screen Login using the administrator account then browse on the damaged profile under c:\users\exampleprofile Then try to copy all the files on the folder to a temporary folder. Delete the damaged profile eg. c:\users\exampleprofile .Create a new User Profile with the same name as the damaged user profile. You can do this in Control panel/User Account . Copy all the files from the temporary folder to the new user profile created. Restart system
-IF No..GO -Back-up -Reinstall windows
Oct 11, 2008 | Computers & Internet
Lenovo a780 dual sim Logo
21 people viewed this question
Top Lenovo Cell Phones Experts
james laughton
james laughton
richie46
Are you a Lenovo Cell Phone Expert? Answer questions, earn points and help others
