Question about Measuring Tools & Sensors
ASCOT WEATHER STATION
Type 6015
Lidl/Auriol Z31601B-RX weather station
1 Weather station
1 Outdoor sensor
2 Batteries, type LR06, 1.5 V
2 Batteries, type LR03, 1.5 V
1 Set of operating instructions
Note:
First insert the batteries in the outdoor sensor, then the weather
station.
http://www.lidl-service.com/static/58242588/91679_en_da.pdf
Jan 02, 2018 | Televison & Video
Where can I find local rainfall amounts for this year?
The National Weather Service Website should be able to help you. If you go to their website (www.weather.gov) and type in the zip code for a location in the upper left it will take you to the forecast page for that location. If you scroll to the bottom of that page and click on past weather information you can view the rainfall totals since January 1. Not sure if that is exactly what you need.
To see current rainfall totals on more of an hourly basis and not once a day when the above site updates check out http://aviationweather.gov/adds/metars/Type in the METAR code for that station (if you don't know it it is in the station.txt file, link on the page). Type that in the box and then make sure you click the button for translated. That will tell you the hourly report for that weather station which, if there was rainfall, should say how much fell.
Apr 04, 2017 | Cars & Trucks
Why can't I receive input from the outside sending unit?
Make sure that all the batteries are good!!
This procedure outlines the typical process to pair the sensor and base.
Base Station Battery Installation
·Remove the printed vinyl label from the LCD screen of the base station
·Position the remote sensor near the base station
·Open the battery compartment at the back of the base station and insert (2) AA batteries according to the polarity markings. Replace the battery compartment cover.
·Within a short time the RF signal icon (located to the left of the outdoor temperature channel indicator) will start flashing. This indicates that the base station is ready to pick up the RF outdoor temperature signal from the remote sensor. It will continue to flash for 3 minutes or until the signal from the remote sensor is detected.
Register the Remote Sensor
·Open the battery compartment at the back of the remote sensor and slide the channel selector switch to your desired channel. For the first remote you may select any channel, for additional remotes select any unused channel
·Insert (2) AAA batteries according to the polarity markings. Be sure to install the batteries in the remote within the time that the RF signal icon is flashing on the base station. 1541 WeatherGuide Wireless Weather Forecaster with Barometer
Jan 07, 2016 | Measuring Tools & Sensors
Changed the batteries in both the transmitter and weather station. It doesn't show temperature on the transmitter or show temperature and humidity on weather station
In some of these weather stations, you have to install the batteries in the transmitter first and then the weather station within a certain time limit. Also, the weather station must be within a specified distance from the transmitter when replacing the batteries.
If you look on the weather station, there should be a make and model number. If you have that, you can visit the website (if there is one) and download an instruction booklet for your model.
Jul 21, 2015 | Measuring Tools & Sensors
Why has my ascot weather station started to need new batteries every three days?
probably has a bad Capacitor inside it and it's shorting out the batteries.
Sep 23, 2014 | Motorcycles
Software for National Geographic 265NC
I tried the software that came with the National Geographic weather station 265NC but found it not what I wanted for history data. I downloaded Cumulus software from Sandaysoft.com I have used it since 2009 and have had no problems. When setting up the station on the software use Fine Offset as a menu selector for type of station as that worked for me.
Feb 07, 2014 | NG Weather NATIONAL GEOGRAPHIC 265NC
Select a weather station
Davis is most reliable even with isolated incidences
Aug 30, 2012 | Davis Measuring Tools & Sensors
Can't find a carb rebuild kit for my 1983 Honda VT500FT Ascot
Bike Bandit has everything you need to rebuild the carburetor on your 1983 Honda VT500FT V-Twin Ascot, click on the link below to view
http://www.bikebandit.com/houseofmotorcycles/1983-honda-motorcycle-vt500c-shadow/o/m9690
Apr 18, 2010 | 1983 Honda vt 500 ft ascot
I find that my weather station rain guage gives a false rain reading occasionally when in fact there is no rain, please help
Depending on the weather station type, you may have a bad tipping cup, or if it uses a saturation sensor, it may be at the end of its useful life or defective. It doesn't sound like calibration since you said it only acts up occasionally. Also check for any bad wiring or terminal connections. Bad connections can cause a host of different problems.
If you know the brand of the weather station, contact the vendor for additional information.
Apr 27, 2009 | Computers & Internet
Measuring Tools & Sensors Logo
54 people viewed this question
Top Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Measuring Tool and Sensor Expert? Answer questions, earn points and help others
