Question about Sokkia Sdl30 Digital Level 32X
Charging battery How to remove the battery on Sokkia SDL30?
E191 for total station, sokkia type, it does not observe horizontal and vertical angle & does not measuring
Sokkia total stations are repaired using Sokkia proprietary computer software. You need to return it to a Sokkia shop, no other shop will be able to corect this, not even Topcon (even though Topcon bought Sokkia).
Jul 29, 2015 | Sokkia CX-105, CX series, Total Station...
What battery charger fits these rechargable batterys
Actually I don't know what kind of batteries uses your Sokkia Surveyors Umbrellas Vinyl 8136-41 so please specify the rechargable battery it uses. Probably it is specified in it's user's manual
Jul 22, 2015 | Sokkia Surveyors Umbrellas Vinyl 8136-41
Where can i buy a bdc11 battery?
Which BDC-11 battery do you mean? There are a couple manufacturers who use the same lettering for the model names for their batteries.
If you mean the Sokkia BDC-11, you can try a sokkia dealer. Or you can try a battery supplier. They probally wont have the battery pack, per se, however you should be able to send yours in to be rebuilt, or if you can describe it in good enough detail, they may be able to build the pack for you.
Oct 08, 2014 | Measuring Tools & Sensors
What is meant E024 error code of SET550X SOKKIA total station?
Hi Aung,
E024 is for F4 cal level error.
what this means is that one of the frequencies used in your distance measurement needs adjustment. This adjustment can normally be done as part of your annual service.
Not having it serviced for a long time is often the reason why these types of error will occur....
rgds, Paul
Jun 09, 2014 | Sokkia Set550x Total Station, Two Years...
Error e191 sokkia 1030r
Sokkia 1030r displays e191 in horizontal angle window
Jan 19, 2014 | Sokkia Set210 / Set310 / Set310 / Set510 /...
Manual sokkia cx105
i want to know about methed of back side
Jun 18, 2012 | Sokkia Cx-105 5 Reflectorless Total...
How to download the files from sokkia total station 1030 r
To Down load pls let me know com set up (Sokkia 1030R instrument)
BAud rate ,parity & Bits
May 18, 2010 | GPS
Sokkia Sdl30 Digital Level 32X Logo
29 people viewed this question
Top Sokkia Measuring Tools & Sensors Experts
Vuk B
Carlo Birocco
Carlo Birocco
Level 1 Expert
Are you a Sokkia Measuring Tool and Sensor Expert? Answer questions, earn points and help others
