Question about Shoprider Scootie TE-787NA - Power Scooter by
I don't know how to remove old batteries in Shoprider Scootie TE-787NA power scooter.
I don't know how to remove old batteries to install new batteries in Shoprider Scootie TE-787NA power scooter.
  • 210 Answers
Posted on Mar 29, 2014
Testimonial: "I can't lift old batteries up from batteries pack after I remove batteries pack cover."
3 Suggested Answers
  • 945 Answers
SOURCE: shoprider deluxe te-889af loses power when reversing
I think that this is usual to have a slower reverse speed for safety.But on your shoprider you should have 4mph and 8mph ,usually if you are at 8mph it won`t reverse at that speed, you have to go to 4mph ,look infront of you there is a dial this controls the speed that you go forward and reverse.If reverse speed needs to be increased turn the dial up,but don`t forget this also increases forwards.
Posted on Oct 16, 2009
SOURCE: Removing batteries from Shoprider scooter
cover is held on by velcro,pull pin holding seat ,batteries sit on frame
Posted on Sep 28, 2011
How do i turn off the beeping that occurs when i go in reverse
the reveerse beeper is a saftey feature to let others know to look out for you coming not to be disabled .
Apr 28, 2014 | Shoprider SCOOTIE Scootie Jr Scooter
I don't know how to remove old batteries to install new batteries in Shoprider Scootie TE-787NA power scooter. I can't lift them up after I remove batteries cover. I can't find it in manual.
Not familiar with that make and model, but we often find that batteries just plain get stuck due to gunk on the battery pan. If you do not see a strap or hold down or anything, try wiggling them to see if that frees them up.
Mar 29, 2014 | Shoprider Scootie TE-787NA - Power Scooter...
Controller i have a invacare controller,is t posiable to convert to a shoprider scooty? both are 24 volt
Hi, yes it is possible, I have done this for my mothers Shoprider Cadiz, are we on about a Rhino controller , a blue colour?? (70 amp controller )
Contact me for further details if required...
Regards
Rob
www.gewizrepairs.co.uk
Feb 02, 2014 | Shoprider TE-787NA-BGRD-Scootie 4 Wheel...
Tiller hand knob
hi, could you show me a picture of this and i can advise on a way to fix it ?
RegardsGeWiz
Feb 06, 2013 | Shoprider Scootie
I installed new batteries and scooter still doesn't run,why?
Check the wiring from the controller to the motor, disconnect the wire ad clean the connections with a contact cleaner or WD40 , and make sure the scooter not in freewheel mode.
Regards
Dec 14, 2012 | Shoprider Scootie
How do you test the batteries and how do you remove the batteries for the Shoprider Scootie?
Bill With a voltmeter you can check the voltage of the batteries through the charger port on the battery pack. Set the voltmeter to 200 volts dc and plug the leads into the two outter holes of the charger port. You will be reading the voltage of the batteries and after a full charge they should read 25-27 volts. The batteries are in the case under the seat. remove the case from the scooter and turn it over there are numerous screws to unscrew to seperate the case and get access to the batteries. Remove the cables from the batteries and also the heat sensors from the batteries. Make sure you reattach the heat sensors to the batteries when you relace them with new batteries. Now you won't be able to do a load test on the batteries in the case but you can get them checked once you remove them from the case. It has been my experience that these smaller batteries do good if they last you a year. If less than that you might have a weak battery and you will need to replace both batteries with new ones. Hope this helps you
Nov 13, 2010 | Shoprider Scootie
Service center for shoprider scootie near Bloomington In
Please go to Shoprider.com and click on the tab for provider locator. When the window opens click on ceritified technician locator. When the window opens put in your zip code and put in the search radius. This will give you technicians who are cerfied with Shoprider scooters closest to your home. Hope this helps.
Nov 05, 2010 | Shoprider Scootie
My shoprider scootie does not show whats left on the battery and the horn does not work. Any suggestions what the problem may be? Thank you
hi, ok, but does the scooter work besides the horn and battery indicator not working ?
If the scooter works okay then the problem is within the tiller control panel , that is the panel on the handlebars, Now it could be a loose wire so carefully take it apart and check to see whether there are any loose wires.
Regards
GeWiz
Jan 12, 2010 | Shoprider Scootie 4 Wheel Compact Travel...
It appears to be out of power but suddenly the power reappears I
ok, that could be one of three things,
A bad connection with the battery so lift the battery and check contacts,
Check wiring to the speed pot, you will have to remove the top unit that house the speed pot etc (Wign wam)
A faultly speed pot is the other cause, to confirm trying moving the pot up and down, is there a lot of play , try moving the lever slowly, if it jerks about, it needs replacing.
Regards
GeWiz.
Oct 17, 2009 | Shoprider Scootie 4 Wheel Scooter
Forward/reverse pot is flaky, where can I buy one?
You will need the make, model and the serial number off your scooter. The serial number should be on the frame down under the shroud cover under the seat. Call the manufacturer with this info, and they will either issue you a part, or usually, refer you to an authorized repair facility for replacement of the part. Replacement is pretty straightforward once you have the tiller shroud opened up. Good luck.
Jul 23, 2009 | Shoprider Scootie TE-787NA - Power Scooter...
Shoprider Scootie TE-787NA - Power Scooter by Logo
196 people viewed this question
Top Shoprider Health & Beauty Experts
Robin Hill
Robin Hill
Colin Taylor
wcdoc1953
wcdoc1953
Are you a Shoprider Health and Beauty Expert? Answer questions, earn points and help others
