Question about MSI L1350D-1672US Netbook
Msi L1350d screen has tiny horizontal lines
Upon boot up the logo is perfect for maybe a second and then gets very thin horizontal lines all across the screen. Sometimes the lines are solid and sometimes they are dotted. Sometimes they show up as white dots on a dark image and black dots on a light image. Sometimes they are solid black no matter what the background image/text is. Every once in a great while the screen or a part of it is perfect for a few seconds but then develops the horizontal lines and appears to "fade" a little. I connected a vga cable and the output to my tv is perfect. The netbook screen is usually readable with the lines but occasionally a previous pop up takes a while to fade away. I have done a "factory restore" where it is supposed to format c: and reinstall windows and I have gone to the bios and chosen to load defaults (yes the lines are in the bios setup too). I have also done all windows 7 required and optional updates. I have loaded the Intel GMA driver option in control panel and chosen all defaults. I tried to update the graphics driver for the Intel Graphics media Accelerator 3150 in the device manager and it says it is the latest. I have toggled through the screen outputs (Fn + F2) and it does the same thing in each one. Any suggestions on whether it is the screen or video card or what I can try next??????
    Master:
  • MSI Master
  • 993 Answers
Screen broken by more pressure
Posted on Jan 18, 2015
  • 564 Answers
If it works fine when you connect to your tv then you've probably got a loose cable on the screen. You'll have to strip it to check.
Posted on Apr 26, 2014
4 Suggested Answers
jcrowder0846
  • 470 Answers
SOURCE: How to Replace Bios? Boot & Reformat Attempts Hang (on every HDD) - I guess BIOS is Corrupted
You can go to the manufacturer web site and go to support then to drivers and downloads there should be a BIOS flash software utility at their site. Click Here to go there. Select your model and make sure it is the correct one. I would also go for the automatic driver update, this will find and seek any drivers for your laptop that are needed, missing, or upgrade them.
If that does not provide the info you need their is also a support number as well as live chat at the link above. I hope this assisted you in some way. John
Posted on May 02, 2012
maxcarson
  • 7627 Answers
SOURCE: msi sleep state appears stuck
Remove ALL media, DVD, CD, USB, unplug, remove battery, plug in reboot. OR try to boot to safe mode, open the Control Panel, select Power Options, set to High Performance, Change Plan settings, set SLEEP and Hibernate to Never.
Posted on Apr 19, 2013
Testimonial: "thank you max not sure but did finally get comp to work your suggestion was certinaly the major factor in repair many thanks"
odiebugs
  • 949 Answers
SOURCE: cdrom driver not working
You don't update the bios unless you change to a newer processor,
that isn't supported by the version you have, if you find the system
is less stable then before, reflash to the old Bios.
There is no download for a cd or dvd rom, you only have downloads for chipset, graphics, sound, touchpads, ethernet, and a few other things.
Cd, dvd roms, use windows drivers,So you don't have to look for drivers.
There is something wrong with the unit, if you can plug in any other
cd or dvd and see if it works, to rule out motherboard problem.
If it works, you can see if is under warranty or you will have to get a new one.
Any questions, post back.
Posted on Feb 07, 2010
Why does my SAMSUNG PLASMA have thin black line? horizontal line How to fix?
Sustain board fault. Contact any service technician. This is not a user repairable fault.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Aug 02, 2014 | Samsung PN64D7000 3D Plasma TV
How to turn on wifi on my notebook msi l1350d
You probably have the answer by now but press the Fn and F11 keys at the same time until you see the wireless logo pop up.
Mar 07, 2012 | MSI L1350D-1672US Netbook
How do i put my MSI atom N455 computer in safe mode. I forgot password and want to bypass it
Safe mode is accessed by hiting F8 repeatedly just after the logo or POST screen. This may or may not allow you to get past your password, depends on if you have an actual administrator account activated.
Oct 12, 2011 | MSI L1350D-1672US Netbook
Msi wind l1350d Where is the memory slot cover?
Depending upon the model it could be on the bottom of the laptop or under the keyboard.
Apr 28, 2011 | MSI L1350D-1672US Netbook
Thin white horizontal lines!!! I've had my WEGA KE-42M1 for 5 years with no problems until about three months ago. After about an hour being on, there are thin white horizontal lines that move randomly...
Sounds like your TV is giving out, plain and simple.
If this doesn't sound right, then only one thing comes to mind. Have you moved the TV recently? Are you using a different coax cable, (if using cable that is). If so, just change the cable back to the previous one and you should be fine.
Aug 21, 2010 | Sony WEGA KE-42M1 42 in. HD-Ready Plasma...
Msi 945p neo motherboard will not boot past the first screen.
Hi there
There maybe a problem with the system memory, take it out, clean the contacts and the slots
Good luck
Jan 26, 2009 | MSI 945P Neo3-F (7236-040(945P NEO3-F))...
Toshiba 27D46 Black Screen - White Horizontal Line
I fixed the problem by taking it to a repair shop
Apr 24, 2008 | Toshiba 27D46 27" TV
Tv not working
this symptom, sometimes called the tube light effect, it is characterised by a bright thin horizontal line across the middle of the screen. this symptom is caused by a breakdown in the vertical deflection circuit. hence maybe the trouble maybe in the vertical oscillator, amplifier or output circuits. but if all i have said is not clear to you, better bring it to a qualified tv technician. good luck!
Mar 08, 2007 | Sanyo DS31590 31" TV
Horizontal 'pinstripe' lines on all channels
sound like the screen control on the flyback is set just a little too high. the flyback has the red wire attached to the tube. the flyback has 2 small adjustable controls. if you look close enough 1 is marked focus & on is screen. turn the screen slightly to the left & look at your picture. the screen is like a master brightness & if it's up too high you will see what is called retrace lines. good luck.
Jan 16, 2007 | Daewoo DTQ-20N3FC 20" TV
MSI L1350D-1672US Netbook Logo
Top MSI Computers & Internet Experts
vsri9
David
David
Matthew Spark
Matthew Spark
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
