Question about Camping, Backpacking & Hiking
2 ipad my slender will not work it keeps the month and date but I can not put any info into
Calender will not let me put any thing in it
My Bluetooth device that was previously picked up by the denon sound bar purchased only 3 months ago is now no longer being picked up. Apple says prob is not with iPad
You can try a few things on the iPad.
you can't start by just resetting the networks settings on the iPad and power cycling the sound bar.
if the issue persist then plug your iPad into a computer with iTunes, back up and restore the device. Set the Device up as new. If the device can now connect to the sound bar you can try to restore from the iTunes back up you created. If the issue comes back when you put the info back in the device then you will need to set up as new.
if the is still not resolved and you know the iPad can connect to other Bluetooth devices then you will need to reach out to Denon.
Apr 30, 2017 | Apple Tablets & eReaders
Ever since you changed my e-mail format I cant get on my calender
FixYa cannot access your computer to change your email or computer settings.
You can try restoring your computer to a date before your email problem occured.
Click on Start - All Programs - Accessories - System Tools - System Restore and select a date to restore your computer, select a date before your email problem started.
Apr 29, 2012 | Acer Computers & Internet
Please tell me in E-Z words how to set the clock and calendar on the Canon MP11DX calculator? Manual instructions, which I cannot locate anyway, are absolutely unclear. Please HELP!
To set the calender: Press the Calender/Time button. Press and hold the Time Set button for 3 seconds; the first digit of the date will start blinking. Then type in the date as two digit number for the month and date and a 4 digit number for the year. Add a zero in front of the month or day if under 10. Then press Time Set again. Press the CE/C button to return to the Calculation mode
(hold for 3 seconds)
Thus for today [Cal/Time] [Time Set] 0 9 1 5 2 0 1 0 [Time Set] [CE/C]
For December 1, 2010 [Cal/Time] [Time Set] 1 2 0 1 2 0 1 0 [Time Set] [CE/C]
To set the Time from the Calculator mode, you press the Calender/Time button twice before pressing and holding the Time Set button for 3 seconds; again the first digit of the current time will blink. Then type in the time as a 4 digit number followed by the AM/PM button to switch from AM to PM or PM to AM. Then press the Time Set button again and then the CE/C button to return to the calculator mode. You will see an A (AM) or P (PM) to the right of the time as you set it.
So for 5:06 PM you type
[Cal/Time] [Cal/Time] [Time Set] 0 5 0 6 [AM/PM] [Time Set] [CE/C]
I hope this helps. You can find the manual here: http://www.usa.canon.com/cusa/consumer/products/calculators/printing_calculators/mp11dx#BrochuresAndManuals as a pdf.
(I'm using Cal/Time for the button that has an icon that looks like a 1 month calender on the left and a clock on the left.)
Sep 15, 2010 | Office Equipment & Supplies
Ds lite is reading system date error
Known problem with the NDS Cards but here is a temporary fix:Take out the NDS cards and start up DS without them
  • Tap the symbol in the middle of the screen at the bottom that looks like a DS.
  • Tap the blue box with a calender and clock in.
  • Change the date a month or two back.
  • Restart DS with NDS cards in.
Even though this is temporary the people at NDS are working for a solution. But until then you might just have to keep putting the date back.
Apr 15, 2010 | Nintendo DS Lite
Problem with computer.need to put everything to factory settings. i have windows xp
If you want to put everything to factory settings, then just restore Windows XP to the installation date or the date of purchase of your Computer.To restore the computer follow these steps. Navigate to
1.) Start--> All Programs---> Accessories--> System Tools ----> System Restore. 2) Open System Restore tool and then move back to the initial installation of your Operating System. Click the "Back" on the calender displayed. 3) When the installation month is displayed you can see some bold or highlighted dates. 4) Click any highlighted Day and then Press "Next" . Now the System Restore will be performed and the system restarts. 5) After the system restart you will be notified of a successful restoration completed. In the above way you can put the factory settings of the operating system.
Nov 07, 2009 | Dell Dimension 2400 PC Desktop
System restore does not work it says try another date same thing happens
Only the dates listed in bold have a system restore on them. Try one of those.
May 20, 2009 | Toshiba Satellite A75-S206 Notebook
SOund not working on compaq cq40-330tu with win xp sp3
Click Start, right click My Computer, go to Properties, Hardware, Devise Manager. Click on the plus mark, check for any yellow question marks in Sound, video and game controllers. If you see one, right click the device then you can try a number of things. Do not disable the device. Try up-dating the driver if no driver is found try uninstalling the driver and restarting the computer. The computer might install the driver after it loads Windows. You can try double clicking or going to properties from the right-click menu. Check the devise status trouble shoot if necessary. The first thing I want you to try is from the properties menu, go to driver, then click Roll Back Driver. If all this don't work go to Start, Help and Support, then System Restore. Restore to an earlier time. Choose a day and month in the calender previous to the day you last remember it working, then click next and follow the instructions. See if that does it, the days available or restore points will be highlighted in th calender.
May 15, 2009 | Compaq Computers & Internet
Confused about my due date my husband arrived from home last oct.5,2008 and my last monthly period was sept.18,2008 i am pregnant now when is my exactly due date??
I believe it is 36 weeks from the date of conception (don't ask me to explain what conception is). grab a calender and work it out
Robert
Jan 11, 2009 | Cameras
Sigmatel s9 manual
MY SIGMATEL CHINES CELL PHONE MO. NO.S9 IS NOT CONNECT MY PC BY USE. I WANT TO DOWNLOAD SOME SONGS AND VIDEOS.
Dec 11, 2008 | Handmark Software MobileLists (950142) for...
Calendar sync
Sounds like either you Service book [CICAL] maybe curropt; delete the service book and wireless sync the device to push new service book.
If that doesn't work; check if your colleagues have the same issue too, it may be a greater issue with the BES. i.e - One way Calender Sync issue.
Ask your IT guy to go through the BES logs to search for errors under your PIN for the day you had made entries on Calender.
Do few Tests - one from the Device and sync and the other on your desktop mail and sync.
I hope this helps, let me know how it goes,
Thanks.
Nov 10, 2008 | AT&T Blackberry Curve 8300 Smartphone
Camping, Backpacking & Hiking Logo
Top Camping, Backpacking & Hiking Experts
Tom Chichester
ray gallant
Are you a Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
