Question about Small Games Falling Block
Remington model 6 rifle
What is thread size on thumb screw
Iam looking to buy a gun.its a remington model 700 serial number is E6340162 an would like to know how much its worth?
that will depend on the grade of rifle you want any place above 7 or 800.00 us
Nov 10, 2016 | Optics
Rifle will not fire,side bar rod and cover broke long time ago,i threaded a 3/16 rod iwas able to crank it back loaded it but it will not fire.
  • Get the proper spares for it. You know it has a safety?
  • DIANA ORIGINAL : Model 48 & 52 - Airgun Spares www.airgunspares.com/store/category/64/791/DIANA-ORIGINAL/Model-48... Diana/Original Piston Seal. Fits Models: 34, 36, 38, 46, 46E, 48, Stutzen, 300R, TO5, P31, 66, 75 & Remington Express
  • Diana/Original - Airgun spares ' Chambers Gunmakers ... https://www.gunspares.co.uk/categories/24035/DianaOriginal ... Shotgun & Rifle spares. HOME ' CATEGORIES. Airgun spares; ... Diana/Original - Airgun spares. Please select the MODEL you require`
  • RWS Parts. Diana RWS Air Guns, RWS Air Rifles and ... www.pyramydair.com/m/RWS-Parts/44/73 RWS Parts. We carry Diana RWS Air ... You must be 18 years or older to buy any air gun or air rifle in our ... (T01) Model number 30223000. Umarex: RWS. Starting at ...
  • May 01, 2016 | Optics
    My 597 22 rifle only every other round will fired. How do I fix it?
    Couple of things could be happening:
    dirty firing pin channel
    Bad lot of ammunition.
    Light/broken hammer spring.
    Clean it thoroughly and shoot it again.
    Mar 19, 2014 | Remington Model 597 .22 Long Rifle 16.5...
    I have a Remington rifle which is a 22 caliber octagon barrel rolling block type serial number J282433. Any info on this rifle would be appreciated.
    Could use more info, such as markings on the barrel and or breach. The Remington rolling block type single shot goes back to the 1860'S. The first 22 calibers around 1888. The rolling block went through 8 changes. The different types or changes are where various pins and screws are located, size and shape of hammers and triggers. The New Model Number 4, made from 1890 - 1933 came standard in 22 cal. with a 22 1/2 inch Oct. barrel. It will have a small lever on the right side of the breach. Approx 50,000 of these where made between the years noted. You could very well have a model 1, 2 or a model 7, which will be rare if in very good shape as only 1000, No. 7's where made. Tracking the serial number will be hard unless you contact Remington.
    Oct 30, 2011 | Optics
    The plate that the mount screws to is loose how do i tighten it?
    You mean the one you have pictured there? It has the big thumb wheel on it? It won't tighten up? Is it stripped? Or is the receiver stripped out? You could replace that big screw with a bolt, you would lose your quick detach, Or if the receiver is stripped, you'll have to get it tapped out, and get the new bolt anyway, going up one size. and using a fine thread. It can be a screw, with a slot head or an allen head. Hope this helps.
    Feb 26, 2010 | Weaver Ruger Mini 14 Rifle Elevated Scope...
    Looking for the age of a Remmington model 121
    These rifles were made between 1936 and 1954. There is more detailed information about them on the Remington website.
    Oct 17, 2009 | Remington Electric Chain Saw
    Small Games Falling Block Logo
    67 people viewed this question
    Top Small Games Apps Experts
    Are you a Small Games App Expert? Answer questions, earn points and help others
