Question about Frigidaire FAFW4221LW Washer
Fafw4221lw0 will only use casual setting
Only washes on casual everything else will time out and never start
Whats the casual setting for
casual -- Average or slightly slower spin speeds
Nov 20, 2012 | Maytag Centennial 3.2 cu. ft. SuperSize...
Kenmore HE2 won't finish spin cycle
you have blockage in you drain plug. to solve this problem you'll have to remove the lower front panel of your machine by removing the 3 (1/4") screws on the vary bottom of the machine. once the panel is removed you'll see a 1 1/2" white PVC drainage plug. turn the inner plug to the left in till open. (WARNING ALL THE WATER IN THE DRUM WILL DRAIN THOUGH THIS PLUG) remove debris likes socks or everything that's there replace the panel and your all set.
May 28, 2009 | Kenmore HE2 Plus Front Load Washer
GE 5500 washing machine TERMS
These are the agitator and spin speeds.
Mar 11, 2009 | GE WBSR3140DW Top Load Washer
Washer will not go to the rinse cycel.
check cold water line...onthejob,,,im assuming no rinse cycle only..onthejob,,,no mater the cycle
Jan 31, 2009 | Kenmore Elite 45986 Front Load Washer
Wash Settings have changed
These times are pre-programmed and not user selectable.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Dec 30, 2008 | Kenmore 46462 Front Load Washer
Dryer won't start, but all indicators on front look like it did
Check it is not set to time delay start , if not you may have an electronic module fault
Dec 20, 2008 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Whirlpool front loading washer
I am having trouble starting the washer . I set the cycle on casual and press the start button and the washer sensor showed to " Done" instead of starting. I only bought it three months ago.
Jul 19, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Frigidaire FAFW4221LW Washer Logo
46 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
