There is no power on lg 50PZ570 at all
Lg just turned off by itself and now we have no power on TV at all
SOURCE: LG tv turns on by itself
this problem is with the inner small micro-swtches ,the side buttons inside are getting intermittantely short...changing of those switches will solve the prob. tc--
Posted on Oct 28, 2007
  • 556 Answers
SOURCE: keeps turning itself off with a red light next to
have you changed the lamp in this set. If you look by the red light it probably says lamp
Posted on Aug 07, 2009
SOURCE: 42 in LG LCD TV turns off by itself
Found that TV started switching off by itself. Would try to come on..green light blinked for 2-3 seconds, tv came on (with picture and sound) for 1 or 2 seconds and then it would turn itself off. Found that the issue is with one channel only. If you are facing this issue....try quickly changing the channel the moment it comes on. You can do it either with remote or with the TV buttons directly. also in the same logic, if this is still happening, try changing the source to another (rgb-pc, av1, av2 etc). Basically change it from whatever input it is on currently, if changing the channels does not work. My symptom was that the tv made a loud 'TIK' 'TAK' sound which is louder than normal.
Posted on Mar 17, 2010
toolkits
  • 1099 Answers
SOURCE: LG TV won't turn on. Power light flashes red/green.
Power supply board just die.It can be dead at anytime.Tries websites Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Posted on May 31, 2010
Testimonial: "good advice"
caroldon
  • 17129 Answers
SOURCE: LG 50 PS 3000 tv will not turn on. Flashes a
Since your TV comes on and shuts off, the possiblity of the main power developing a fault on switch on to shut off as the error amp is asking it to do so.. Please check for any failure of capacitors in the HT section. use a multimeter and test voltage on switch on. make a note and test after it switches off. you will slowly arrive at the point of trouble. look for dry solder joints. use a good iron to carefully solder all joints suspected to look mushy. check the connectors of the HT drives to the panel. there could be fault in the connection resulting in slow build up and causing the error amp to react to shut off. Hope my advice helps. Good day
Posted on Jul 12, 2010
It shuts off 2 seconds after i power on.
Several possibilities but most common seems to be power supply defect or poor connection. Check these resources. Note that other Youtubes that may address the problem are also accessible from the youtube link.
LG Smart TV Keeps Turning Off then On Again
Lg Du 42px12x shuts down fix
May 06, 2016 | LG 42LG50 42-Inch 1080p LCD HDTV
My 32" lg flat screen turns on with remote and then turns itself off and on repeatedly by itself
Hi Mark,
The power supply section needs to be checked. If you are not handy with electronic repairs, please consult some local TV tech.
May 29, 2015 | LG Televison & Video
LG LCD 42" sound but no picture
From this web site it says:
http://www.ehow.com/about_5379235_lg-television-problems.html
Powering Off
  • Many LG LCD television owners report having a problem with their televisions where the screen powers on, but then lasts only a few seconds or a few minutes before powering itself off again. The problem usually occurs with brand new televisions, and in this case is inside the television itself. If your television is powering off unexpectedly, contact LG so it can be serviced.
Read more: http://www.ehow.com/about_5379235_lg-television-problems.html#ixzz2qeK8T3SU
Jan 17, 2014 | LG 42LC2RR 42 in. HD-Ready LCD TV
My LED LG TV 42" turns on/off by itself. Channels do not change.
Sorry to tell ya but your power supply panel or chip is going out! Mine done the same stuff! Freakin flat screens dont last as long as the older t.v's
Nov 01, 2012 | LG Televison & Video
LG 32LD550 Tv will not turn on. Just purchased it a few weeks ago.
Check ur power source?Tries tv unplug,replug the tv back about an hour later.By letting tv resetting itself back to factory setting.Now the tv should be working again.If still have same problems,tv mostly have the power supply board problems.Take it back where u bought it exchange for another tv or call LG for a warrenty repair.
Jan 05, 2011 | LG 32LD550 32 in. LCD HDTV
LG LCD flickers and turns itself off
I'm guessing here.. most probably its the ccfl tubes..
Aug 27, 2009 | LG 37 in. Flat Panel LCD HDTV
Lg tv automatically turn on and off. Power surge
the software in the main control is damaged. call your lg servicer in your area. he might get you a software update
Jul 06, 2009 | LG 47LC7DF 47 in. LCD HDTV
Jan 22, 2008 | LG 42LC2D 42 in. LCD HDTV
Computers & Internet Logo
47 people viewed this question
David Payne
David Payne
