Question about Olevia Televison & Video
Sleep button i need to put a timer on my tv so if i fall asleeep it wont be left on all night. but i dont have a remote. how would i do it?
  • 210 Answers
Use the buttons on the front ... press them all until your menu comes up on the screen.....also you could try finding the manual .... buy a universal remote ..... buy a timer for the plug ... turn off the tv . stop watching tv before bedtime .... ask some1 to pop in and check if you have fallen asleep with the tv on , mums are usually always willing to do this for you , but i'd advise caution if your watching adult rated comment they usually do not condone this content ...let us now which option you go for and how it works out for you ... good luck friend
Posted on Mar 29, 2014
  • 12 Answers
SOURCE: can not turn on my tv after the sleep button was used
power supply problem, common with this model
Posted on Mar 07, 2009
SOURCE: Can't set the sleep timer
I have the same problem. Does anyone have a fix?
Posted on Jul 29, 2009
satavlad
  • 405 Answers
SOURCE: my remote does not have the sleep timer button.
Open cover on the bottom part of the remote SLEEP button is there.
Posted on Oct 24, 2009
  • 210 Answers
SOURCE: samsung flatscreen wont turn on but red light is
with tv in standby press INFO / MENU / MUTE / STANDBY on remote tv will come on with service menu DO NOT CHANGE ANY SETTINGS
look at list you will see reset
ONLY USE DOWN NAVAGATION KEY until RESET is highlighted
then PRESS RIGHT NAVAGATION KEY the tv will reset
PRESS STANDBY TO EXIT
the tv will need retuneing after
hope this helps
Posted on Dec 19, 2009
moorah1
  • 181 Answers
SOURCE: Does it have a sleep timer?
hello!
yes, it has the one! you need to go to the menu, setup portion of that. you'll see: clock set, timers, etc. That's where you will find it. A bit complicated, but possible. If your remote lacks "sleep" button, get the one with it.
good luck,
Alex.
Posted on Jan 30, 2012
Since changing to freeview in april i no longer need the use of the original tv remote as the new remote is being used. my problem now is i cant find how to set the tv to sleep mode shud i fall asleep...
Your new FreeView remote will only support the essential functions of your tv. In some cases that's limited to volume up and down, sound mute and on/off only, but often they can do more. Sleep timers are rarely supported.
Your fix is to either set the sleep timer on the old remote, or to buy another fully programmable learning remote control, where you can customise almost every button and use your old remote to teach the learning version its tricks.
Jul 22, 2011 | Televison & Video
My tv turns off after about 10 mins and sometimes a few hours for know reason
Ok not sure if this is your problem, BUT, I have done this before! If you hit the SLEEP button on your TV's Remote control you may be setting the SLEEP TIMER on your TV. It is made so you can watch a show and fall asleep on your couch and the TV will shut off after a specified time. On mine it is anywhere from 30 minutes to 3 HOURS! My remote says the word SLEEP over the timer button. not sure on yours
Hope that solves the problem, just hit the button until the word "OFF" shows on your screen.
Feb 27, 2011 | Televison & Video
TV will not come on with remote or power button
The following instructions are for the Emerson EWC1303/1903 tv/vcr. That's the closest match I could find to the Spongebob Squarepants 13' TV
If it's actually in Sleep mode, do the following:
TO CANCEL THE SLEEP TIMER
Press the WAKE UP/SLEEP button on the remote
control until “SLEEP TIMER” appears.
To view the time left for sleep timer press the WAKE
UP/SLEEP button twice, then press the MENU button
on the remote control to exit the sleep timer setting
If unsuccessful, try unplugging the TV for 1/2 hour, then plug it in and try turning it back on either manually or with the remote. Either of these should solve your problem. Best of luck to you!
May 08, 2009 | Emerson SpongeBob SquarePants TV
Sleep Timer on remote does not work
First try to access the sleep timer menu from the controls on the TV to verify the TV is working.
If that works then the remote has the problem.
Now try this;
Step 1- Pull the batteries out of the remote and leave them out until Step 4.
Step 2- Press and release each and every button one at a time on the remote control until every button has been pressed and released at least once!
Step 3- If your remote has slide switches, you must move the switch to each position then repeat the button pushing in Step 2.
(When you're done, be sure to put the slide switch in the correct position to operate the unit the remote came with!)
Step 4- Put the batteries back into the remote, being very careful to install them correctly.
New batteries should be used if you're not sure about the old ones.
If this does not work, then you may need a new remote unit.
Mar 10, 2009 | Olevia LT37HVS 37 in. LCD HDTV
Olevia TV Remote doesnt work Sleep Timer
The TV is in 'showroom mode'. To fix: Click: Menu --> Picture --> Mode --> Power up then select: Home. Then click menu until you exit the settings. You will now be able to use the sleep timer.
Mar 10, 2009 | Bose Cinemate Digital Home Theater System...
Help...
If you have menu controls directly on your TV. You might try resetting all the settings.
Aug 12, 2008 | JVC AV-24F702 24" TV
Remote controler
press picture/sleep button. use the buttons on lower left to set. press arrow bouttons to set time and hit enter (middle button)
Jul 05, 2008 | Philips Magnavox 20MS233S 20" TV
Sleep Function???
In most cases you can set the sleep timer by accessing the menu. Or if it is a learning remote find a button you dont use and teach it the sleep button from your OEM remote.
Apr 15, 2008 | RCA RCR460 Remote Control
Magnavox lcd tv
Setting the Sleep Timer sleeptimer.gif The sleep timer allows your LCD TV to automatically turn OFF after a given amount of time. You can set the sleep timer using your remote control or through the onscreen display (OSD).
TO SET THE SLEEP TIMER USING THE REMOTE CONTROL
1. Press the SLEEP button on the remote control. The sleep timer appears at
the top of your screen.
2. Press the SLEEP button one or more times to select the time you want.
3. Press the EXIT button to hide the sleep timer display. Your sleep timer is now running in the background. The sleep timer will be hidden after 10 seconds.
Turning On the LCD TV.
1. Press the MAIN POWER switch in the back of the unit (see Back Connectors for location). The Status LED on the front turns orange
and your LCD TV is ready to turn on.
2. Press the POWER button on the front of your LCD TV or on your
remote control. The Status LED on the front turns green.moz-screenshot-6.jpgmoz-screenshot-5.jpg
Dec 18, 2007 | Televison & Video
RCA 32V432T
FIRST THING TO TRY IS RESET-unplug AC cord for a few minutes,hours or overnight==let me know if you need more help.T.
Aug 04, 2007 | RCA 32V420T 32" TV
Televison & Video Logo
Top Olevia Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you an Olevia Televison and Video Expert? Answer questions, earn points and help others
