My lg intellowasher 7kg wd-10130f does not pump and always stop and pre-wash , time lights become flash
The water do not come out at all although the pipe is not close
    Master:
  • Washing Mach... Master
  • 676 Answers
Have you check the trap for something lodged in it, if there is water in the machine you can use the small hose next to the trap to remove the water from the machine before opening the trap. If you don't know about the trap read the owner manual. If you need help after that please feel free to contact me.
Posted on Mar 30, 2014
  • Sally Fouche
    Sally Fouche Feb 01, 2015
    Hi, we removed a piece of plastic from the trap, yet the machine still doesn't spin and gets stuck on 10mins (which is the spin cycle.
  • Melissa Martin
    Melissa Martin Feb 01, 2015
    unplug the unit then open the trap back up, remove the trap completely and see if you can reach in with a finger to the pump and spin the impeller you should feel it move to the next postion or you may find some small piece of debris that is stopping the impeller from turning.
SOURCE: lg intello wash wd 8013f
The front panel is flasing when i press play
Posted on Sep 16, 2008
  • 901 Answers
SOURCE: LG Intellowasher 7kg, Model WD-8074FHB - noisy spin cycle
You are right!
Bearings have to be replaced. Replace with the same type and design. All the bearings connected to the washer center shaft has to be replaced at the same time with new set.
Replace the water seals also connected to this. Check the shaft where the bearing sits, for any abrasions or metal damage.
Check the bearing housing also. While carrying out these repairs check the drive belt also. If needed replace it.
If you are happy with the machine outer body and other aspects repair it and re-use it.
Posted on Apr 07, 2010
Testimonial: "Thanks for the quick reply Ambari, that's exactly what I wanted to know. Atleast I'll some idea if the repair bloke is pulling a swifty. Cheers"
jumptrout51
  • 3361 Answers
SOURCE: Manual for LG Intellowasher 7kg
While not exact to your model,this manual may answer your questions.
http://136.166.4.200/contents/Laundry/WD-1070FH/WD-1070FD_Service_Manual.pdf
Posted on Sep 08, 2010
beltronic205
  • 1467 Answers
SOURCE: My LG intellowasher 7kg WD-8015C
Most common,Water supply okay, Door closed properly,Child lock not switched on....? Good Luck
Posted on Feb 16, 2011
  • 6277 Answers
SOURCE: I have a LG Intellowasher
'dE' stands for 'drain Error'.
I would gently suggest as a first step that you clean the drain motor/pump lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to rinse or spin or release the door lock if there is any water still left inside.
Following are my complete and generic guidance notes for checking both the drain motor filter and the drain motor ;-0)
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT (alternatively use a wet vac as sensibly suggested by VinnyB1234!)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!). These panels are either held on by (plasic) screws or will just pull off. Most filters are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Posted on Aug 01, 2011
2008 grand caravan 3.3 L engine blows the plastic Y-coolant pipe twice.
WATER PUMP PULLY LOOSE, OR THERMOSTAT CLOSED CAUSING BACK PRESSURE.
Oct 17, 2016 | 2008 Dodge Grand Caravan
Water pressure
Here is what should be going on.
There is a length of pipe between the hot water that is in your tank and the nozzle you are expecting to get it out of.
It is really possible the are nearly 3 gallons of water in those pipes, especially if the water heater is many feet from the faucet.
Now about the drop in water pressure.
Try the cold water.
Does it do the same as the hot? Does the pressure drop after 2 - 5 minutes?
If so, suspect your pipes are clogged with sediment. How old are the pipes and the house/apartment?
Does the water contain minerals that clog pipes?
If the cold water is good, and the hot not, I should suspect there is blockage in the hot water pipes, especially going in to or coming out of the water heater., or perhaps the faucet is clogged with rust or deposits.
God bless your efforts.
Oct 19, 2015 | Water Water Heaters
Why Dishwasher water not coming in ?
1. check the water shut off valve.
2. Make sure you are closing the door properly it should close completely to get start
3. If you are sure that above to things are fine but still you have problem then check the dishwasher water inlet valve.
4. If you have flexible water pipe connected with your dishwasher then check it if its the one with flood safety at one end of pipe. If you have that kind of flex pipe then change it with regular flex pipe the one without safety.
Aug 20, 2014 | Washing Machines
How to thaw frozen pipes
I use a small electric heater, place it underneith your house in the crawspace, close your crawlspace door. Make sure heater isn't in contact with anything, leave some room around your heater so it don't melt or burn anything, and wait for a short while. WARNING: your pipes probably are busted, and when they thaw will spray water everywhere. Try to place your heater where it won't get wet when this major flood happens. WATER + ELECTRICITY = SHOCK OR DEATH. Make sure if water leaks do occur, unplug your heater and don't get around any water untill your heater is disconnected just to be super safe. BE PREPARED TO SHUT OFF WATER TO THE HOUSE.. so i would have the tools ready and the cutoff exposed to make a quick run to turn off your water. If the frozen pipes are underground, you might want to wait till the temp raises above freezing, or as i hate to inform you, dig up the lines and replace them. It isn't a bad idea to use a heater to keep your lines warm during winter, or use some heat wrap. I used to just let my water run a small trickle in all my spigots like bathtup, kitchen faucets, and lavitory faucets anytime i think they may freeze up.. Hope this helps although its posted in wrong catagory.
Dec 08, 2013 | Cars & Trucks
Windscreen washer makes a noise but no water comes out
Hello king_robe.
Not sure if you're sorted yet, it could be as simple as a tear in the pipe close to the reservoir. In my case (on an 01 520) the tube / pipe burst during freezing conditions. I filled the reservoir with screen wash and noticed suds dripping onto the drive. although this doesnt solve the problem, hope it helps you to fix it.
Daley.
Dec 12, 2009 | BMW 318 Cars & Trucks
Hot water coming out of overflow pipe on my vulcan everhot water
Assuming you are talking about the temperatur/pressure relief valve, it is stuck open.
1. Turn off gas or electric to water heater
2. Close water supply to water heater
3. open hot water faucet on nearest fixture to depressurize hot water system.
4. close tpr valve (you may have to push in on the center spine. It may be resistant to closing from sediment. If so, opening and closing several times may solve that issue.
Once you get the tpr valve closed, close the faucet and open the supply valve. If the tpr stays closed, go ahead and turn on the gas/electric and re-light pilot and turn on control etc.
If the TPR blows again, you will need to replace it. YOu can buy a new one at any plumbing supply store. Shut down the heater again, drain a bit of water out using the valve on the bottom of the tank. there is probably copper pipe connected to the TPR valve which you may have to cut or maybe can just unscrew. The TPR threads out of the tank, install the new valve (make sure to use pipe dope or teflon tape.
Jan 04, 2009 | Water Heaters
My bosch dishwasher does not fill with water (although it drains)
most bosch have the inlet valve at the end of the fill pipe and it has an anti-flood device.
try turning off the water, take off the fill pipe then reconnect it and see if this works.
taking off the fill pipe resets the anti-flood device
Nov 26, 2008 | Bosch 24 in. SHU53 Built-in Dishwasher
Water coming straight through LG SxS fridge freezer
Most likely the pipes were disturbed a bit while remodeling, causing a particle to flow to the inlet water valve and prevent it from closing completely. You will probably have to replace the water valve part number 6877JB3053D (note, if you would have run a gallon water out the water supply tube prior to hooking the water line back up to the refrig. you would not have had this problem)
Nov 21, 2008 | LG LSC26905TT Side by Side Refrigerator
Hotpoint Aquarius WF100
Firstly, there should be only one hose, always connected to the cold supply.
The unit will heat the water to the setting you choose for the wash (40 - 60 - etc)
Secondly, if the unit is leaking water, try turning down the cold pressure, this will slow the supply pressure to the unit and prevent spray out from the detergent drawer.
Your supply tap should have an isloting tap on it, adjust this until it sullpies water at an acceptable rate.
Do this by feeding the hose into a bucket/basin and tweak it until it pours out - not sprays out.
This should alleviate any leaks around the machine.
Hope this helps.
Oct 08, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Washing Machines Logo
180 people viewed this question
Top Washing Machines Experts
