Question about Eheim Filter Wet/Dry 2227-37
Won't cycle after first run.
Plug the filter in and the tank emptys.the water fill up water fills in the float chamber, the float won't move the air tube fill with water and the output is nearly nil
Dishwasher won t fill
I had a similar problem with a Kenmore; the problem turned out to be that the float was stuck. On the bottom of your dishwasher there should be something that looks vaguely like a plastic mushroom - that is the float. Just tap it gently and see if it goes down a bit. If it does, gently move it up and down a few times to make sure it's moving freely (make sure to leave it in the down position) and then try to launch a cycle. Good luck!
Mar 18, 2014 | Siemens Dishwashers
What is the float switch
I have no real experience with float switches on dishwashers, but have with some in humidifiers. It's a piece of styrofoam on a narrow metal stick that lifts when the appliance fills with water & lowers when the water empties. If this gets stuck on something, like a dishwasher rack, the unit won't fill or empty the water & the cycles won't work properly. Take a look & see if there is such a thing hung up somewhere in the dishwasher. If you can loosen it, your dishwasher should work again.
Feb 21, 2012 | Beko 24 in. D3421F Free-standing...
I am contacting you as I am a bit desperate for help. Please advise as to what should be done with regard to the Savio Skimmer Filter SS0000. At around 5pm when feeding the fish, I noted the skimmer...
This means that the filter or leaf basket is blocked. When the pump is off, the water levels will look fine, but when the pump pulls water through, even a partial blockage of the filter or basket limits flow so the level falls and eventually the pump 'sucks air'. Remove and thoroughly clean the leaf basket and filter. Good luck!
Aug 12, 2010 | Garden
Not filling with enough water
If you remove the lid and looking at the front of the d/w take of the lefft side panel, at the right bottom on the side you should see a pressure chamber with some micro switches and a red lever. This is possible blocked along with the hose that is attached to it (to the right, behind the chamber) clear them both and retest with the side panel off to check for good flow and to make sure you have not created a leak.
Good luck
Jul 08, 2010 | Neff 24 in. S5555X0GB Built-in Dishwasher
The machine says fill watertank. ventilate. the
Open the hot water valve, and run about a cup of water, this will engage the pump and fill the circuit.
Jun 04, 2009 | Saeco Vienna Digital Coffee Maker,...
Delay on tank fill after flush. Toto Drake bowl ada elongatred
I am not a plumber but stumbled across the solution on my own. While watching the float during the flush cycle, it was obvious that it was very slow in moving downward along with the water level in the tank. The problem was that the small opening in the float chamber was partially clogged. Using just my fingers, I reached under the float chamber and cleaned off any debris that was blocking the opening underneath the float chamber. Put the float back on, and instantly the problem was solved. The tank fill started immediately after I flushed.
Mar 09, 2009 | Toto Drake ADA Compliant Toilet with...
"Fill water tank" prompt
Make sure the magnet in the water tank flow up when you fill it with water.
Best regards
/Mirran
Oct 26, 2008 | Saeco Vienna SuperAutomatica Coffee...
Water problem
Many dishwashers will drain at the beginning of any cycle.
If the water does not fill after the pump-out cycle, then the problem is either the fill valve or the float switch. You should be able to hear the float switch click as you raise or lower it. The fill valve usually hums whenever it has power.
If the fill valve has power but doesn't open, (use a voltmeter) replace the fill valve. If there is no power at the float switch, nor at the fill valve after pumping out, then the clock / timer is at fault.
Mar 10, 2008 | Dishwashers
Fill watertank
float valve stuck. try unplugging and then empty tank.check to see that nothing is visable in water reserve. fill water tank to full and then plug unit back in. hope this solves your problem
Nov 16, 2007 | Saeco Vienna De Luxe Espresso Machine
Fill Watertank Message
The black thing floating in the water tank is a plastic shell with a magnet inside. If you clean it...make sure you reinstall it with the tapered (smaller) side down. There is a slight size difference BUT it will make ALL the difference in the world.
I had no idea there was a magnet in that black/greyish case. The direction of the casing is important.
I had the same problem and that solved it!
Jul 29, 2007 | Miele CVA615 Espresso Machine
Eheim Filter Wet/Dry 2227-37 Logo
77 people viewed this question
Top Eheim Fish Experts
Richard Lindsey ...
ThothMer
ThothMer
Level 1 Expert
Tom Chichester
Are you an Eheim Fish Expert? Answer questions, earn points and help others
