Question about Candy Washing Machines
My candy Eclypsa Washing machine continuously drain water from outlet tube
My washing machine resently repaired. They said they replace drum pose. Now it not fill water to inside. Instead water go though outlet tube. As instructed I raise the outlet tube more than 50cm.
  • Catman Tiger Mar 29, 2014
    I found the solution. What I did wrong is I attached a nother tube to outlet tube to extend it. It cause siphen action and water collect inside it
  • 147 Answers
SOURCE: Simpson 36P450 Washing Machine continuously
It cant drain if you oulet hose is higher than the water level. Raise your drain hose up above your water level. I was pmel (calibration) in the air force..Love it.Went to school at port huneme (navy) school
Posted on Oct 25, 2008
SOURCE: my candy eclypsa CE1400 the
I need a operation manual for Candy Eclyps CG544T, please send me .
Posted on Oct 11, 2008
futureloginn
  • 734 Answers
SOURCE: Kitchenaid Top Loader leaks
It leaksYour washer can develop several types of leaks. You can track down a leak based on when it occurs:
During fill only
During drain and spin only
All the time
During fill only
If the washer leaks only during the fill cycle, check these:
Air-gap device -The air gap is a small device found on most washers that prevents the wash water from being siphoned into the household water supply. It's located either mid-way along or at the end of the black rubber hose that comes from the water-inlet valve. Often it's made of translucent plastic. If one of the air-gap components deforms or cracks, you may need to replace it.
The tube -There's a rubber tube that runs between the water-inlet valve and either the air-gap or the inlet spout. If it cracks or breaks, it can cause a leak.
Inlet spout -Most washers have a plastic spout near the top of the main clothes tub that directs the water into the tub. If the spout cracks or breaks free of its mounting, it can cause a leak.
A washer that leaks only during the spin cycle often has a leak in the main drain hose. Inspect the entire hose and correct any problem you find. Alternatively, the steel or plastic outer tubs can rust, split, or be punctured. This may be most visible during large loads and high water levels. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
All the time
If the washer leaks all the time, check these:
Hot and cold water fill hoses - Check the hot and cold water hoses from the household plumbing. If either hose is leaking, tighten it or replace it, as appropriate.
Main tub seal - The main tub seal is located between the transmission and the outer tub. It's the primary water seal in the outer tub for the transmission-shaft entry point. If this seal leaks, you can see the leak by opening up the machine's main access panel while the machine is full of water with a small amount of detergent in it. The leak appears at the underside of the outer tub, at or near the center. This seal is difficult to replace. You probably should call a qualified appliance repair technician.
Pump - If the pump leaks, you can probably spot the leak when the tub is full of water. The pump has two or more black rubber or plastic hoses attached to it and usually has a drive belt that spins the pump. If the pump is leaking, you need to replace it.
Outer tub - Over time, the steel or plastic outer tubs can rust, split, or be punctured. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
Posted on Dec 12, 2008
SOURCE: GE SpaceMaker washing machine does not stop filling.
try replacing your water selenoid coming in. remember it isnt a mechanical timer it is a computerized timer, so if the selenoid isnt the problem, it might be the computerized timer. computers are very finicky, pain in the a- -!
Posted on Mar 27, 2009
  • 127 Answers
SOURCE: Washing machine will not drain all the water. If
there is always a little water left in the drum assembly when done pumping. however it is usually well below the level of the clothes basket/drum so that there is none contacting the clothes when at rest.
if you can actually visibly see water within the clothes basket/drum when the cycle is complete, then check below.
have you lengthened the drain hose beyond the standard length to reach to your taller than normal sewer/drain inlet??? if so then you're getting more water returning to the unit when the pump shuts off and if the extra hose is long enough then theres enough water returning to your tub so that the basket sits in water at rest..
if so you'll need to install a check valve to keep the additional water from going backwards into your unit. some of these units have one built into the drain hose where it connects to the pump.. i tried looking yours up via the model # listed on the 1st page but got nowhere with that number.
you could also have a restriction in your pump or drain assembly that may be slowing things down some.. can't be of more help without proper model # though..
hope this helps,
best of luck,
ttfn
Posted on Oct 25, 2009
My washing machine motor not rotating in washing cycle. Motor works well in Spinning cycles, but not working agitatewashing movement in any cycle. It's water filling, stopping and draining all works
Would help to have the model and type...but typically if the tub is not agitating the coupling between the motor and the tub is worn out or broken. However, if it is spinning properly, it probably indicates a problem with the transmission. Really need to know what type of washer it is to help pin down the problem. Any "burnt" smells coming from the washer? Give a little more information and maybe we can figure it out. Top load...side load, make and model preferred. You can locate that information on a plate usually attached inside the door on most models.
Apr 17, 2016 | Candy Washing Machines
Candy eclypsa ce104
it will need replacing the valve is at the top right on the rear
Jan 12, 2014 | Candy Washing Machines
My washing machine Candy CE10 does not spin and drain water
HI. firstly have you checked that all dirty water outlet pipe is clean and not blocked. or the cycle circuit could be broken.
Jan 13, 2012 | Candy Washing Machines
Candy Eclypsa CE124/1 drum does not move on any cycle, even spin cycle.
It sounds like the motor brushes have failed. Quite a common fault and not too complicated to fix.
Oct 25, 2010 | Washing Machines
My washing machine is Candy C435 T model.when i am filling the water it goes out directly without filling..Why?
Possibly the drain outlet is too low.
Try raising the outlet hose to a higher level, this will stop it syphoning out as it is filling.
Jun 06, 2010 | Candy AQW130 Front Load Washer / Dryer
Water overflows in washer
hi friend,
    Water Inlet Valve
  1. The water inlet valve connects the hot and cold water lines before entering into the washer, combining the two by means of solenoids in the appropriate proportions. The valve can become worn over time to the degree that it cannot close itself entirely, meaning water will continue to flow through it until the solenoids engage and shut off the flow. This can easily result in an overflow. To test the water inlet valve, first unplug the washing machine and disconnect the valve from the machine's back. Have a bucket handy because, if the valve is faulty, a good amount of water will drain from the valve when you disconnect it. A replacement water inlet valve is inexpensive and easily swapped out for the old one, provided you remember to turn off the water pressure leading to the hoses.
  2. Water Level Switch
  3. The water level switch is also known as the pressure switch. There should be a clear plastic tub running down from the control console to end near the bottom of the washer's drum. As water fills the drum, it rises within the tube as well, compressing the air already in the tube against the pressure switch. If the tube has become brittle and cracked, it will allow air to escape, preventing pressure from building inside and throwing the switch. Test it by blowing into the end. You should hear a click from the control console. If you do not hear anything, then either the pressure switch is broken or the tube is cracked. Remove the tube and the switch, which should be connected to the control console. The console can be accessed in various methods, depending on the exact model of washer you own. You should be able to remove the console by following instructions in the appliance's ownership manual. Blow directly against the pressure switch once you gain access. If it clicks, then the tube needs to be replaced; if it does not, then the pressure switch itself needs to be replaced.
  4. Drainage Problems
  5. The water outlet pipe near the base of the washer can become clogged with debris over time. Since washers continuously drain out dirty water and replace it with clean water as they wash clothes, it's possible that if the outlet valve or pipe is obstructed, the washer will overflow. Turn off the water and electricity leading to the washer and detach the outlet pipe, both at the machine and the wall. Run water through the pipe until the flow coming out is strong and clear and contains no sediment. If the pipe was clean to begin with, then the pipe running through the back of the wall to the drain may be the culprit. The pipe fitting should be female ended, identical to that of a garden hose. Attach a garden hose and slowly turn the water on until it's running at full force. The line should be cleared by the water pressure after 10 minutes of this. Attach the drain hose and turn the water and electricity back on.
jQuery('.article ol .image').each(function(i,e){ var $this = jQuery(this); $this.find('img').error(function(){ jQuery(this).remove(); $this.remove(); }); }); Who Can HelpSponsored hope this helps u
please rate me.....................
thank u for using fixya
regards
sivaranjini
Nov 30, 2009 | GE WBSR3140DW Top Load Washer
Washing machine leaking
This is called the "drain hose" or "discharge hose" -- it connects to the outlet port on the water pump.
May 07, 2009 | GE WBSR3140DW Top Load Washer
Indesit 123. Will not drain. Goes into spin cycle when set but no water comes out. Checked hose at front and rear.
You need to clean out your outlet filter;(which is accessible thru the front bottom right side of machine, small push door, or plastic screw) this needs to be done periodically - according to your usage. If this does not solve your problem check out your outlet pump. Plug off the wall first before you do the jobs. The machine will not drain water if the outlet is clogged. For the pump, tubes, etc you hav to open up behind the machine. Be prepared for water to come flowing out....... You need good pair of grip pliers for the tubes.
And rate me pl, if the solution has worked......
Nov 26, 2007 | Indesit W 123 Front Load Washer
Buttons on CE124 candy eclypsa not working
the on/off switch sounds faulty they can get hot and jam, with the button stuck in you cant open the door, the switch will have to be replaced
Jan 18, 2007 | Candy CN126 Front Load Washer
Washing Machines Logo
Top Candy Washing Machines Experts
Gerry Harvey
Gerry Harvey
Are you a Candy Washing Machine Expert? Answer questions, earn points and help others
