Question about Kitchen Ranges
Kenmore gas stove
Installing model 790.7423 convert to LP oven flame too high
catriver
  • 878 Answers
SOURCE: Kenmore Gas Range Oven not Working Properly
greg, sounds like your needle valve is not seated. Remove the bottom drawer. Look back to the base of the burner where the shutter air adjustment is. Right under there is the valve which should have a 1/2 inch or 7/16 nut. (I Forgot what size). Turn this nut clockwise until the flame is adjusted to the correct size, should be a nice blue flame. The nut maybe hard to turn because you are seating the needle. Catriver..post back
Posted on Dec 23, 2006
Krazytech
  • 725 Answers
SOURCE: Low flame
so you stove was converted from natural gas to LP using WB28K10043 KIT-CONVERSION L.P. ? is this correct?
Posted on Aug 25, 2007
  • 7 Answers
SOURCE: Oven flame is too high
the flame should be app 2" from each side of the burner. be very careful with lp conversions.
Posted on Feb 09, 2008
  • 95 Answers
SOURCE: Kenmore gas stove. Oven burns big flame which soots
The manifold needs to be cleaned and adjusted could have rust etc in it Not a good thing to do yourself unless you know what you are doing
Posted on Jan 24, 2009
jumptrout51
  • 3361 Answers
SOURCE: Oven flame too high.
Take a 1/2 inch open end wrench and tighten the orifice on the oven gas valve. Then adjust the air shutter on the venturi tube.
Posted on Mar 18, 2009
Installing stove model number 790.7423 to LP oven flame is too high
adjust the intake valve look in your manual for its location
Mar 29, 2014 | Craftsman Garden
Gas range converted to LP gas huge flame in oven
was the injectors converted in both and was the regulator converted
Jan 21, 2010 | Kenmore 78530 / 78531 Gas Kitchen Range
Flames are extremely uneven and high
okay, DO NOT USE THIS STOVE ON LP GAS.
It's not intended to be used with LP gas, because LP gas requires a smaller orifice than natural gas. Call your propane supplier IMMEDIATELY...DO NOT USE THIS STOVE UNTIL IT IS CONVERTED TO LP GAS (if it's even possible)...this is extremely dangerous and you could hurt yourself if you continue to use LP gas on a stove that was designed to run on natural gas.
Dec 06, 2008 | Frigidaire FGF326AS Gas Kitchen Range
Upper & Lower Broiler Flame Adjustment
MY KENMORE OVEN BURNER FLAME IS TO HIGH AND IT WILL NOT TURN LOW
Jul 16, 2008 | Ovens
Lp flames to top of oven
You need to tighten down the orifice spud for the bake burner. Remove drawer in bottom of oven. Look for bottom of burner tube, where the shutter adjustment is. Right below it is the orifice spud. Usually a goldish color. Take 1/2 inch open end wrench and tighten until it stops. Do-not overtighten! Try it now. If flames are still to high, tighten a little more. Repeat if needed.
Nov 18, 2007 | Kitchen Ranges
Low flame
Aug 23, 2007 | Hotpoint RGB745 Gas Kitchen Range
Changed from natural gas to propane when new oven flames up the side top burners ok
Just bought a Kenmore and did this conversion myself. You do not change the oven nozzle (jets) but have to wrench it down with a 1/2" wrench as per instructions. After I did this the falme was high as you described. I wrenched it down further and adjusted the air shuttle and it was fine. The brioler is done the same. The wrench adjustment is tight so be aware.
Apr 08, 2007 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Kitchen Ranges Logo
24 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
