Question about Bvlgari Bulgari B Zero1 Stainless Steel Quartz Watch for Women
Bvlgari Bulgari B Zero1 Stainless Steel Quartz Watch for Women set hour
I Can't set the hour !
How to set time on a bvlgari bz22s
I usually read and follow the instructions that come with a new watch
Apr 10, 2014 | Bvlgari Bulgari B.ZERO1 BZ22S stainless...
Cracked spindles the movement watches, watches do not work. I have a repairman, I need new spindles. Thank
Not all watches/jewelery stores around the world sell Bvlgari luxury goods, therefore
you should visit http://us.bulgari.com/customer_service
to get services or to order parts for your repariman.
Visit Store Locator page to find the address and phone number of the boutique nearest you. You may also purchase a selection of Bvlgari watch products directly from Bvlgari website (currently available in the US only).
Q: How may I get my BVLGARI watch repaired?
A:
Please contact the BVLGARI boutique or authorized dealer where you purchased your BVLGARI watch.
For Japan, kindly refer exclusively to the Bvlgari boutiques in Tokyo Ginza or Osaka Umeda. Visit Store Locator page to find the address and phone number of your closest boutique.
I hope it helps.
Feb 19, 2011 | Bvlgari Aluminium Whtie Dial Black Rubber...
The watch does not run. Does it need winding or does it use a battery?
This watch is has a quartz movement and therefore is battery driven.
Have a merry Christmas!
Dec 23, 2010 | Movado 0310404 Concord Sportivo Polished...
Bvlgari sd 38 l 2161 is this watch battery or automatic brand new as gift not working email mailly@mweb.co.za
If the watch is automatic, it usually says so on the face of the watch.
I have looked at their web site and most of the models are automatic, although a few are manual or quartz.
If it is automatic, then you can wake it up by swinging it from side to side a large number of times. If you wear is daily, then it should keep working satisfactorily. If it is not used for 2 -3 days, then it will stop and you will have to shake it again to start it.
If it is a manual watch, then it can be wound up using the crown (winder).
If it is quartz, then these are usually working when sold (is the crown pushed in?) and if it doesn't work, it might be replaced under warranty.
If you need further help you can contact them http://en.bulgari.com/customer_service/customer_service.jsp?cat=cat00128#contactUs.jsp?cat=cat00131 and tell them your problem.
Jul 19, 2010 | Watches
Stem and crown have come out of my gucci watch how do i replace it?
If your Gucci watch is Quartz, or even Windup, it"s best to see a jeweler to identify any possible problem causeing the stem and crown to come out of the watch. Mike D 75
Jun 08, 2010 | Gucci 1400 Series Bangle Stainless Steel...
I have a stainless steel Bertolucci watch,it stopped working does it have a battery? ,plus i would like to sell it,i live in the st louis area
If you go to their web site and look at their "collection", you should be able to find your watch and be able to find out what you what to know.
Web site http://www.bertolucci-watches.com/en/collections.php
If your watch says "quartz" on the front, then it is battery driven, if it says "automatic" then it is a spring driven self winding type (which stops when not being used).
May 07, 2010 | Bertolucci Vir Mini Steel and 18k Gold...
Bvlgari BULGARI SD 38S L2161 steel chain
I have the same pb . did you get any solution yet.
by the way I have to replace the rubber strap too.
Nov 09, 2009 | Watches
I have missing stones in my bulgari sunglasses
you can repair them yourself by buying the rhinestones and special glue online at www.mrstones.com all shapes and sizes just measure where the stone was and match the shape and pick the col which is usually crystal and voila
Oct 07, 2009 | Bvlgari Sunglasses BV2012B_266_5317 Watch
I would like to Identify this watch and its value. It has two seperate letter / # combos on the back. BVLGARI - AL38A, L3276
This is a Bulgari watch (Printed BvGari) model number AL 38 A.
An authentic Bulgari watch of this style would sell for around $2000. This particular model was counterfeited a lot so its best to have a watch maker familiar with the model or brand look at the case, band, and movement. Be sure to have the movement inspected so you know it was not swapped for a cheap replacement.
Sep 18, 2009 | Bvlgari Watches
Bvlgari Bulgari B Zero1 Stainless Steel Quartz Watch for Women Logo
Top Bvlgari Watches Experts
Ansel Alberto
Ansel Alberto
rhodesworks
Bill Boyd
Are you a Bvlgari Watch Expert? Answer questions, earn points and help others
