Question about Neff Daily Watch - cyan/pink/black
Neff daily watch
Just purchased the Neff Daily and it didn't run so I returned it. The second watch doesn't run either. The knob turns to adjust the hands but it doesn't run! Any suggestions?
    Master:
  • 435 Answers
Does it come with a battery in it? I've had watches where there was a little clear plastic tab you had to pull to allow the battery to make contact and the watch to run. If not, then all I can suggest is to but another brand of watch. Here's their web site link. At the bottom of the page is the contact link...good luck.
Front Page
Posted on Mar 29, 2014
How do I turn off the beep chime signal on casio f91w?
In a few words, here is how:
1 - Push button C to get to the ALARM mode
2 - Push button A to cycle through the options:
First, you will get daily alarm activated only,
then, only hourly beep signal,
then both daily and hourly signal chime
and finally both hourly signal and daily alarm turned off
3 - Push button C to return to the Time Mode
I try to make it short and straight to the point,
I hope you find it helpful!
Phil
Sep 28, 2017 | Casio Watches
Wich battery number may i use in this watch bulova 96t63 ??thanks
cant see that model watch on the Bulova web site user manuals
http://www.manualslib.com/brand/bulova/watch.html
if unsure if it needs a battery go to a jeweler or watch or battery seller
some model Bulova Watched instructions
IF YOUR NEW WATCH IS A MECHANICAL WATCH
(no battery)
Mechanical watches differ from Quartz watches in several
respects:
1. No battery changes are needed - they are powered by a main-
spring, which is wound either by wrist movement; or in some
models by daily winding of the setting crown.
2. Because it is a mechanical device, it's accuracy is subject to
the effects of gravity and temperature. You can expect, on the
average, a daily variance of up to 10 to 20 seconds for
mechanical watches.
3. Just like automobiles, these watches require routine mainte-
nance. Due to their mechanical complexity, mechanical
watches require cleaning and new lubrication every 3 to 5
years to run at optimum efficiency.
FOR THE AUTOMATIC SELF-WINDING
MECHANICAL WATCH
it must be wound at least six or seven times before you wear it.
After that, your daily activity should wind the watch sufficiently
to keep it running at night when it is not being worn. If your
normal daily activity is not sufficient, occasional supplementary
manual winding may be necessary. It is suggested that your
mechanical watch be cleaned and oiled periodically to insure
optimum performance. As a mechanical watch, quartz watch
accuracy cannot be expected. References to the power cell do
not apply to Automatic watches
May 02, 2016 | Bulova 96T53 Watch for Women
Changed the battery, hands move slowly but doesn't keep time...help
There is likely something wrong with the gears and mechanisms inside.... you can contact the manufacturer and ask if others have had a similar problem, and see if they might have a solution. Other than that, you may just have to get a new watch.
Feb 07, 2016 | Neff Daily Sucker Blue & Black Analog...
Where can i get a replacement battery for a Ohsen wr30m Watch?
In order to help people set the ohsen sport watches easlier in the right way, our company (www.360sportwatches.com) write the ohsen watch manual instruction in English for all the ohsen watch users, hope this page is useful for you to set your ohsen watch, this ohsen watch manual operation is suitable for almost all the Ohsen digital electornic watch, also it is suitable for the ohsen analogue quartz digital electronic sport watches, for details ohsen watches models, please have a look at the following content!
Ohsen watch manuales instruction description:
A Key = Light
B Key = Mode
C Key = Start
D Key = Reset
In normal time to show, press the button to enter B mode, click Settings when choosing D Key respectively, minutes and seconds, C key to adjust.
Hours, minutes, seconds, month, day, week;
12/24 hour clock selection
* Daily Alarm Clock
Daily alarm only " Hours" and " Minutes" to choose
The whole point timekeeping
* Running Seconds
From 0.04 seconds start running time;
The Longest 23 hours 59 minutes 59 seconds
* EL black light
Any mode, press the A light EL backlight for 3 seconds
* Use 3V batteries
Running Second Mode:
Press B button click into the race second mode, press the C key to start timing, the timing of the state, press the D key to pause time;
At the time of state, then C key, stop the clock, press the D key to this state would be zero time.
Press B button to return to normal time mode;
Alarm setting mode:
Regular time mode, press the B button 2 times into the alarm set;
Press C key to the "alarm" whole point of time" to set " open" and "off";
Press D key to adjust the hours, minutes;
Press C button to adjust the number of selected;
Press B tutton to return to normal time statues.
At the same time in any state, this button will issue a Bi Bi sound;
Time, date setting mode:
In normal working mode, press the B button 3 times to see the second in the flashing, then press the C key, " seconds" will be zero;
Press D key to select each "Hour" " Minute" " Day" " Week" set;
Press C key, you can adjust the number;
Press B button to return to normal time status;
12/24 hours;
Under normal travel time; Press B button 3 times to enter time setting mode, then second in the flashing, second place in the transferred into " H" when the table show has been converted to 24 hours system; when the position becomes"O" on the afternoon of adjustments; seconds into "R" for morning; "P" for PM.
Apr 01, 2015 | Watches
I bought a Neff daily black analog watch at Zumiez about a month ago as a present for a friend. the problem is that the minute hand and hour hand do not move... you can move them to set the time but once...
I would take it into a jeweler and they will put a new battery in it for $4. If that fixes it all well and good, if not it cost you 4 bucks to prove it needs to go back under warranty.
Feb 06, 2014 | Neff Daily Sucker Blue & Black Analog...
Watch is about 7 years old. It went unused, but remained in light & charged for about a year. I started using it again last week. After a few days, the hands and date stopped turning. Doesn't...
The hands are not driven by the knobs. The knobs set the digital and the digital drive the hands. Find full particulars here: http://www.citizenwatch.com/COA/English/settings_int.asp?caliber=C651&interactive=C650 Your watch is not driven by a battery in the usual sense.
If after you do all that is asked of you by the instructions and the watch still will not run as it should, contact Citizen and get a return authorization. My Sky Hawk was dead dead dead. I returned it to them and they got it running and it is still running these several years later. Of course, today I keep it where it can get light daily. In my case, there was no charge for this service, which is not to say yours will be the same. Ask them in your e-mail to them. In my case, it didn't make any difference, I had to get my $500.00 watch working again even if it cost some amount of $.
Thank you for your interest in FixYa.com
Feb 24, 2011 | Citizen EcoDrive AT0100-51A Wrist Watch
I have bought a new daytona but after every few hours it just stops anf i have to reset it again.its quite frustrating
A Rolex watch is automatic.It needs to be worn 8 hours per day to store enough power to run 36 hours off the wrist.Assuming that you are wearing the watch daily if it still stops there is a problem with the auto winding or mainspring.As a new watch it will be under the Rolex guarantee so return it to the place of purchase.If you dont have a guarantee contact www.rolexrepairs.co.uk for advice or a free estimate.
Regards
Jul 06, 2010 | Rolex Daytona 116520 Wrist Watch
Second hand stops for a few seconds and then starts again over and over again
Try manually winding it (assuming it's not a quartz watch). If a mechanical watch is not worn daily it will run down and need to be manually wound to get going. Turn the crown clockwise about 40 turns.
Apr 25, 2010 | Tag Heuer WK1120.BB0314 Wristwatch
Neff Daily Watch - cyan/pink/black Logo
256 people viewed this question
Top Neff Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Neff Watch Expert? Answer questions, earn points and help others
