Question about Westland Sunbird Custom Boat Cover - Spirit 170 BR / SL / CB - I/O Engine 95 - 98 Sunbrella
I need dash and engine wiring diagram
4.3 L V6
I need a diagram for a 1998 Ford Explorer XLT 4.0L V6 SOHC engine wiring harness cause I found bad places in mine and I need to fix them
Oplin Research Database has wiring diagrams. You need a library card to access. Can buy a Haynes manual.
Feb 27, 2015 | Ford Cars & Trucks
Where can I find the spark plug wiring diagram for 1994 Camaro, v6 3.4 liter?
Engine Coil Pack
5 6 / #4 / / #3 / / #5 /
3 4 / #1 / / #6 / / #2 /
1 2
Front Ignition Wires on Coils
#1 #4 #6 #3 #2 #5
O O O O O O
Firing Order: 1-2-3-4-5-6
Feb 24, 2015 | 1994 Chevrolet Camaro
Need spark plug wiring 1998 chevy V6 truck
the cap should be marked on a vortec 4.3 liter. the left side of engine is from front #1 #3 and #5 cylinders. the right side from front is #2 #4 and #6.
Jun 13, 2012 | Chevrolet 1500 Cars & Trucks
I have a 1995 dodge 1500 3.9L V6 truck,its back firing need spark plug wiring diagram,and firing order.
3.9L V6 engine firing order is 1-6-5-4-3-2, cylinders on the pass side front to back are 2-4-6, cylinders on the driver side front to back are 1-3-5.
Aug 31, 2011 | 1997 Dodge Ram 1500 Club Cab
RECENT ENGINE ROOM FIRE VAPORIZED ALTERNATOR HARNESS AND CONNECTOR ON THE ALTERNATOR BOUGHT CONNECTOR FOR ALTERNATOR AND REPAIRED DAMAGED WIRING IN ENGINE BAY WHAT I NEED IS A DIAGRAM OF CONNECTOR HARNESS...
Hi, this is a 2 wire Delco alternator. The wire from the terminal on the back goes to the battery or starter, and the other (excite) wire goes to the battery light in the dash. It also goes to the PCM--not sure which pin, sorry.
Mar 27, 2011 | 1995 Chevrolet Camaro
Trying to find a firing order diagram for a 91 ford aerostar 4.0L V6. I have a book for it, but it is impossible to put the plug wires on the coil block in the order they describe, wires are too short! ...
For the 4.0L V6:
Firing Order:
1-4-2-5-3-6
Cylinders:
........(back)........
|...3...|.......|...6...|
|...2...|.......|...5...|
|...1...|.......|...4...|
.........(front)
Ignition Coil Connections:
..(back)
1...2...3
5...6...4
Aug 08, 2010 | 1991 Ford Aerostar Extended
Need to know the placement spark plug wires 2001 chevrolet malibu
do not have a diagram, but heres the firing order. 1-2-3-4-5-6, 1-3-5 is in back, # 1 is closest to alternator. from left to right, or facing engine from front 2-4-6 is in front. 5-2-3-6-4-1 is coil pack, from left to right (facing from front of engine).
Jul 30, 2010 | 2001 Chevrolet Malibu
Spark plug wiring diagram
3.9L V6 Engine. Engine Firing Order: 1-6-5-4-3-2. Distributor Rotation: Clockwise.............did i guess the right motor? let me know/rate me
Jan 14, 2009 | 1991 Dodge Dakota
Ignition wiring
firingorder6a.gif firingorder6.gif 1991-1994 2.9L and 3.0L Engines Firing Order 1-4-2-5-3-6 1995 And Later 3.0L V-6 With DIS Ignition System Firing Order 1-4-2-5-3-6
4.0L Engines Firing Order: 1-4-2-5-3-6 DIS Ignition System
Nov 22, 2008 | 1995 Ford Ranger Supercab
Westland Sunbird Custom Boat Cover - Spirit 170 BR / SL / CB - I/O Engine 95 - 98 Sunbrella Logo
74 people viewed this question
Top Westland Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Westland Boating Expert? Answer questions, earn points and help others
