Question about Mitsubishi WD-73C11 New
Wd 73c11 has no picture or sound - Mitsubishi WD-73C11 New
Mitsubishi WD-73C11, blinking error code 48, replaced power supply board & still showing error code 48. Will not turn on,no sound or picture. HELP!!!!
Hello. I don't have access to the service manual at the moment, but you might want to check the lamp. Aftermarket lamps do not work in Mitsubishi TVs.
Jul 30, 2016 | Mitsubishi Televison & Video
WD-65833 and SC-PT750 DVD has sound no picture
double check connections, try another input / output.
Jun 07, 2008 | Televison & Video
I have a WD-73642 tv has no picture but has sound
I had this problem with a laptop of mine it's the led just replace the screen
Mar 21, 2016 | Mitsubishi Digital Television Mitsubishi...
Why is tv blinking 4 red lights and 8 yellow lights
An error code of 48 indicates a main power board failure. There is a short down the 3.3v or 5v switched supply.
recommend replace main power board.
part# 934C409001
see the following website:
http://www.shopjimmy.com/mitsubishi/wd-73c11?cat=59&q=WD-73C11&tv_models=Mitsubishi+WD-73C11
Jul 01, 2014 | Mitsubishi WD-73640 73-Inch 1080p...
I have a mitsubishi 73 inch tv model WD-73738. No picture with sound - why is this ?
sounds like the psu. power supply unit. check the caps are not bulged
May 17, 2014 | Mitsubishi Televison & Video
I have a Mitsubishi projection tv model wd-52526. The tv has sound but no picture. It will display channels or devices Is there a simple fix to this?
no picture or a big black box covering the picture. If it is a big box covering the picture then you need to turn off closed captioning.
Mar 11, 2013 | Mitsubishi WD-52526 LCD TV
WD-65732 has audio but no picture. Sound like
Replace Lamp Call Mats Electronics 1-800-628-1118
Mar 25, 2010 | Mitsubishi WD-65732 65" Projection HDTV
No picture or sound
did you remove any covers,lamp or filter? unplug for a few and try again!
Jan 21, 2010 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD-73C11 New Logo
16 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
