Question about GE GSS25JF Side by Side Refrigerator
GSS25JF not cooling
Not cooling
My GE refrigerator isn't cooling enough. I've cleaned the condenser coils, but it didn't affect it. Was hoping to find a repair guide. The model is GSS25JF.
check the thermostat for correct operation. Check the door gaskets are sealing all the way around the opening /are not cracked or gone hard. Finally have a refrigeration mechanic check the gas level
Aug 03, 2013 | Cars & Trucks
GE defrost control for GSS25JF
I just bought a filter for my Maytag Plus, and I reset the filter by pushing the Lock and Light buttons, and the RED LIGHT turned off, however, is it suppose to be a GREEN LIGHT. Thanks!
Jun 23, 2013 | Refrigerators
Hi, I have a GE GSS25JERF model refrigertor. I noticed it is not cooling and fan is stuck and not working in freezer section. Dispenser light is blinking. highly appreciate for any guidance
OK, Now would be a good time to see why the evaporator fan is stuck or not powered. Question is will you feel comfortable testing these items. I will give you a link to a Test Sheet and wiring diagram here=> GE GSS25JERF and I will be here to assist you. Thanks, Sea Breeze
Aug 24, 2010 | GE GSS25JF Side by Side Refrigerator
Refrigerator works and stops
call the place that you got it from and replace it
Jun 12, 2010 | GE GSS25JF Side by Side Refrigerator
How do you initiate a defrost cycle in a GE Ref GSS22JF (computer
nope not them models, i would just change the board, and to bypass the board you have to be a service man with a computer and equipment.
Jun 23, 2009 | GE GSS25JF Side by Side Refrigerator
TFX28PPCBWW leaking
the i/m holds between 3-5 ozs and will try to fill approx. every 10-15 mins with no water in it..
Jan 21, 2009 | GE GSS25JF Side by Side Refrigerator
Fridge is not 'freezing', Looks like fan stopped working
could be due to ice build up jamming the fan. take back panel off and check for ice. if ice present the defrost system has failed. also on some models, the fan stops when door is opened. check door switch is operating
Mar 22, 2007 | GE GSS25JF Side by Side Refrigerator
GE GSS25JF Side by Side Refrigerator Logo
41 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
