Question about Audiovox VD1400HT System
Need replacement parts for audiovox vd 1400 where do I get them?
I need replacement parts for the vcr within the vd1400. Where can I get them?
I need a manual for a sanyo dvd vcr combo. Model number DVW7200
Here you go...
www.retrevo.com/...VD-Players-manual/id/311ag906/t/2/ Just follow the link, fill in your e-mail address and download the manual for free!
Aug 22, 2011 | Televison & Video
TELL ME ABOUT ERROR 3270 FOR DSR-45AP
it is error in a Eprom IC.in VD board
Jan 04, 2011 | Sony DSR-45P DV / Mini DV VCR
No manual in box for Audiovox PVS72901
I had the same issue. After searching the net & the Audiovox website (this model is not listed on their website BTW) for a downloadable copy, I emailed the Audiovox helpdesk. Within an hour, they had sent me a pdf file of the manual. You can download it from: here
Apr 06, 2009 | Audiovox PVS72901 Portable DVD Player
Cannot connect a VCR/DVD player to Zenith SY1959Y
you don't need a code for the vcr/dvd combo to work on your tv. You need to make sure you have hooked up the cables correctly. remember that the dvd can be hooked up with the component cabels and the vhs may need to be hooked up thru the tv cable hookup.
Jan 08, 2009 | Hitachi UltraVision CineForm 55VG825 55"...
Ge universal remote
for the audiovox:
AUDIOVOX .................................. 0053
for sansui:
SANSUI ............................... 0135 0310
for the code search feature:
Code Search
If after trying “Direct Code
Entry” your device does not
respond, or if your brand is
not listed, try doing a search
of the code library for your
code by following the steps
to the right.
1. Manually turn on the
device (TV, VCR, etc.) to
be controlled.
2. Press and hold the SETUP
button until the red
indicator stays on, then
release the SETUP button.
3. Press and release the
desired Mode button (TV,
VCR, etc.). The red
indicator blinks once,
then stays on.
4. Press the CHANNEL UP
button repeatedly (up to
300 times) until the device
to be controlled changes
channel. The red indicator
blinks, then stays lit.
5. Press and release MUTE
to install the code. The
indicator light goes off.
Jun 12, 2008 | GE JASRM24912 Remote Control
Audiovox VD1400ht
I have the same model #VD1400HT.
Problem #1- the drive belt on the tray has "streached"
Solution- replace or cut out 1/4" & superglue back together.
Problem #2- the ribbon cable under the DVD assembly is hitting the bottom of the DVD tray as it attempts to open.
Solution- rebend the cable or apply tape to hold down.
These fixed my problem.
Apr 01, 2008 | Audiovox VD1400HT System
AUDIOVOX VCR SER#S9AA02677 MOD#AVP7000
That is 'dew' as in wet. Do you have it in a warm, dry location? This time of year they can attract condensation if the VCR is in a cold place.
Hope Ya Fix it!
Jan 06, 2008 | Audiovox AVP7000 VCR
Audiovox VD1400HT System Logo
22 people viewed this question
Top Audiovox Audio Players & Recorders Experts
Mohamed Ismail
Mohamed Ismail
Chinmay Joshi
Chinmay Joshi
Are you an Audiovox Audio Player and Recorder Expert? Answer questions, earn points and help others
