Question about Linksys WRT54G2 Wireless Router
I see no lights on the 4 ports . what do i do
    Problem Solver:
  • 11 Answers
Hi..
Try with different wall socket
Even after that , u dont see lights ,then the product might have gone bad
Posted on May 14, 2014
Schematics compaq cq5210y x2
1 - PS/2 mouse port (green)
2 - PS/2 keyboard port (purple)
3 - Video Graphics Adapter port
4 - USB 2.0 ports 4
5 - RJ45 Network (LAN)
6 - Line In port (light blue)
7 - Line Out port (lime)
8 - Microphone port (pink)
Apr 10, 2014 | Dell Audio Players & Recorders
Usb light link
HP LaserJet 1022 is a "host-based" printer so it must be connected to a PC. Load the driver on PC first and connect the USB cable when software tells you to do so.
Will not work on a Linksys print server.
LaserJet 1022N & LaserJet 1022NW have "special" HP print servers that can support HP host based printers.
Nov 27, 2013 | Linksys Wireless-G WPS54GU2 Print Server
Check engine light comes on for 2004 Hyundai Sante Fe. O2 sensor was replaced but still has the problem. Does the EGR manifold tend to get clogged up on the Sante Fe? I fixed a Honda Civic check engine...
First of all, why was the O2 snsr replaced?... Check Engine light? What DTC (diagnostic trouble code) did you find stored in the ECU (Engine Control Unit)? The drivability you seem to be describing can have multiple causes -- faulty sensors, malfunctioning computer, clogged catalytic converter, leaky injectors, vacuum leaks, etc.
Ok... this is gonna take some time. The 04 Santa Fe came with 3 (three) different/possible engines -- the 4 Cylinder 2.4 lit, the 2.7 V6, and the 3.5 V6. Only the 2.4 (4 cyl) and the 3.5 V6 are equipped with EGR. The 2.7 does NOT have EGR. To answer part of your question, the EGR system on the 4 Cyl is known to develop restriction(s) in the EGR port (from the # 4 cylinder exhaust port to the EGR valve at the intake manifold). This port travels through the head (front to rear, i.e., Left to Right when viewing the engine from the transmission end). This port cannot be seen at the # 4 cylinder exhaust port unless you remove the exhaust manifold.
It would be very helpful if you could provide more detailed/specific information regarding the drivability issue & what/which codes were found related to the Check Engine light.
Feb 12, 2011 | 2004 Hyundai Santa Fe
Gigaware remote for ps3 cant connect
I can not locate a Remote For PS3 By Gigaware now if its a controller Follow these steps
Connect to PS3
1. Turn on your console and plug the receiver into the first port on the console. The RX indicator on the receiver flashes.
2. Slide POWER ON/OFF to ON to turn on the controller. The controller’s POWER indicator lights and the 4 port indicators flash.
3. The controller connects with the receiver automatically after about 3 seconds. If successful, the RX indicator on the receiver lights.
4. Press the PS button to assign a controller number. The corresponding port indicator lights.
Manual Search
If you are unable to automatically connect, try manual adjustment.
1. Repeat steps 1 and 2 under “Connect to PS3.”
2. Press CONNECT on the receiver. The RX indicator flashes.
6
3. Press and hold SELECT and L3 (left analog stick) on the controller simultaneously for at least 3 seconds. When the RX indicator stays lit, release SELECT and L3.
n Notes:
• Repeat “Connect to PS3“ or “Manual Search“ if the connection fails again.
• If you purchase a new receiver for the controller, but have previously been using it with the supplied receiver, you will have to follow connection steps again.
Reassigning a controller number
1. Press and hold the PS button for one second. The functional screen displays. Select “Controller Settings”, then “Reassign the controller.” Press X to confirm.
2. Use the D-pad to select the number that matches the controller’s port.
3. Press X again to confirm. The corresponding port indicator lights up.
7
Connect to PC
1. Plug the recevier into a PC’s USB port. The receiver’s RX indicator flashes.
2. Slide POWER ON/OFF to ON to turn on the controller. If connection is successful, the RX indicator on the receiver lights and the 4 port indicators on the controller turn off.
Test the controller
1. Open the control panel on your PC, and double-click “Game Controllers.” Then click “Properties“ and the testing screen appears.
2. Press the buttons of the controller. After testing, press OK to exit. You are now ready to play games.
Troubleshooting
If the controller stops working at any time, or will not connect to PS3 or PC, follow “Manual Search“ steps on pages 5-6.
Dec 14, 2009 | Video Game Consoles & Games
When I turn on my BEFSR41 the POWER and PORT #4 lights up even though nothing is connected to it yet... what seems to be the problem?... is it defective?
If you are using the Uplink port, this may cause port 4 to show active. Disconnect the Uplink cable to see if the light goes out. If it doesn't, then yes, it sounds like you may have a bad port on your router.
Aug 30, 2009 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
2 0f 4 ports do not work
It sounds as though the ports on the cable/dsl router as bad. There really isn't anything you can do. It just happens. The typical shelf life of those routers is about 3-4 years. You could go out and buy another one or if you just need more ports go out and buy a little 5 port switch and plug it into one of the working ports and your comptuers into the 5 port switch.
MO
Jul 12, 2008 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
Targus Travel USB 2.0 4-Port Hub with Notebook Light
I'm sorry to tell you your hub cannot be fixed. I have one just like it and have taken these things apart and repaired simple factory errors as loose wires and the such.
You should get yourself another Targus brand USB hub. They are good and quite reliable
Regards,
Worldvet.
Jun 08, 2008 | Targus 4-PORT TRAVEL USB 2.0 HUB...
Cannot switch between PC's
That unit mention above is a Mountable Dual Output VGA to UXGA Distribution Amplifier with Audio not a KVM Switch.
Apr 07, 2008 | Extron Electronics Extron P/2 DA2 MT...
Linksys BEFW11S4-RM 4 port wireless router
This is an old router. Look at the power light. You must have a STEADY power light. RESET the BEFW11s4 by pushing the reset button for 30seconds. Unplug the power of the BEFW11s4 for 30 seconds. Connect pc to port 2 or 3. pc should get an ip of 192.168.1.x. If you are getting this ip that means that the pc is already detecting the router.
Good Day
Mar 06, 2008 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
Linksys WRT54G2 Wireless Router Logo
23 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
