Question about Neff Daily Watch - cyan/pink/black
Neff daily watch won't start
I have purchased a newNeff Daily watch and although I can turn the hands once set it doesn't start or move at all. What's the solution? Help!
Changed the battery, hands move slowly but doesn't keep time...help
There is likely something wrong with the gears and mechanisms inside.... you can contact the manufacturer and ask if others have had a similar problem, and see if they might have a solution. Other than that, you may just have to get a new watch.
Feb 07, 2016 | Neff Daily Sucker Blue & Black Analog...
Neff daily watch
Does it come with a battery in it? I've had watches where there was a little clear plastic tab you had to pull to allow the battery to make contact and the watch to run. If not, then all I can suggest is to but another brand of watch. Here's their web site link. At the bottom of the page is the contact link...good luck.
Front Page
Mar 29, 2014 | Neff Daily Watch - cyan/pink/black
I bought a Neff daily black analog watch at Zumiez about a month ago as a present for a friend. the problem is that the minute hand and hour hand do not move... you can move them to set the time but once...
I would take it into a jeweler and they will put a new battery in it for $4. If that fixes it all well and good, if not it cost you 4 bucks to prove it needs to go back under warranty.
Feb 06, 2014 | Neff Daily Sucker Blue & Black Analog...
I'm able to set the time and date but once i push the crown back to its original place the watch doesn't start so i push the upper bumper and the seconds begin to run nevertheless the minutes never...
your watch is chronograph,. and it is not in the picture. probably your problem is the second hand won,t move, it is because that the sub dial on the lower part it is the real second hand. the big second hand is for the stopwatch. the to sub dial on the upper sides of your watch. the upper button/bumper is to start and stop the stopwatch or the big second hand and the bottom bumper/button is to reset it. i hope this can solve the problem...
Jul 25, 2011 | Swiss Army Wenger Sportedge Bracelet Watch
On the casio a158w how do I turn off the hourly chime? Thank-you
Hi Ms. Sophie Desro,
If the alarm has sounded, press "A" (top left-hand button) to stop the sound.
To switch the Daily and Hourly Time Signal on and off:
Press "C" (lower right-hand button) while in alarm mode in sequence:
a. }}}} + BELL = Both alarms on.
b. Display Blank = Both OFF.
c. }}}} = Daily alarm on only.
d. BELL = Hourly Time Signal on only.
Test the alarm by holding down "C" to sound the alarm.
Please note b. and c. to turn off the alarms.
For more information, Casio has an Operational Chart for your watch, Module QW-1275. You may download a PDF file here:
http://ftp.casio.co.jp/pub/world_manual/wat/en/qw1275.pdf
Try this and let me know if this works. Thanks.
Regards, Bill
Sep 16, 2010 | Casio DW290 1V Classic Alarm Chronograph...
Second hand stops for a few seconds and then starts again over and over again
Try manually winding it (assuming it's not a quartz watch). If a mechanical watch is not worn daily it will run down and need to be manually wound to get going. Turn the crown clockwise about 40 turns.
Apr 25, 2010 | Tag Heuer WK1120.BB0314 Wristwatch
I have a American Watch Co., (Waltham) pocket watch, 1867 key wound. How do I set the time and how do I open the back cover.
Since you need to open the watch (daily?)to wind it up, it should be fairly easy.
Push your thumb nail between the back and the main part of the case and it should open. There may be a button on the side opposite the hinge.
Adjusting the time can be done by pressing in the winder and turning it to move the fingers.
Feb 12, 2010 | Watches
My wifes recently repaired Rolex loses about an
Is it an automatic self wind or wind up? An automatic watch has a weight that winds the main spring and if you wind it by the crown it will not stop. If its one that you wind by hand then the watch should be wound daily at the same time...like right before bed or when she wakes up. Wind gently until it stops. That costly repair should come with a warranty so if she consistently winds daily and still loses time you need to send it back!
If the watch is an automatic then she can gently hold the watch in her hand and rock it back and forth a good 20 times or so and that will give it a good winding! This is a common issue we see at our watch repair business. Some people do not move enough during the day to keep an automatic movement wound. If thats the case then there is nothing ong with the repair, just make sure it gets a good daily wind! :-)
Jan 10, 2010 | Rolex Watches
Alarm
Alarm Setting:
1st: Press the mode button to go to the alarm screen.
2nd: Press the adjust button for the time to flash
3rd: (For the Hourly Alarm) You can adjust the time here while it is flashing by pressing the start/stop button. Cycle through this until you have the time you want. The setting will have the P in the left side of the screen for PM (night time).
4th: (For the Daily Alarm) Do steps  1-3 once the time is flashing use the Mode button to cycle through to the date field of the watch. Once it is flashing you can use the Start/Stop Button to chose which date Month/Day, after chosing the month just press the Mode button once more to go to the day field.
Jan 05, 2007 | Casio DW9052-1V Wrist Watch
Neff Daily Watch - cyan/pink/black Logo
32 people viewed this question
Top Neff Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Neff Watch Expert? Answer questions, earn points and help others
