Question about Panasonic Viera TC-P50S1
Tv turned off while i was playing xbox 360.
I have a 50in panasonic plasma tv. had it about 5 years. i was playing on my xbox 360 when it when plaid/fuzzy and then it just turned off. i unplugged it for 5 mins and plugged it back in and it will turn on but i can not navigate or change the input settings it will just turn itself off after about a minute. i read online it may be the main board and i can purchase for about 250$ but it i am not sure the symptoms match. any ideas?
    New Friend:
Well I had same problem about my 65" Samsung tv some ware I read to check small capacitor. I open back panel n find few capacitor burn out n replace it n work fine u can find those capacitor from radio sake for about $1.99 each good luck...
Posted on Mar 29, 2014
I have Panasonic th42 plasma.i m playing xbox360 for a year on hdmi port 1 .but 1 day when I turn on my TV than my Xbox the screen is showing black than change the port to 2 than port to 3 same problem not...
It sounds like you did some good testing by taking your xbox to a friend's home and trying it with his TV and HDMI input. You can try a reset on your Panasonic TV and see if that restores the HDMI input functions. Note this will erase your programmed TV channels so you'd need to re-enter those.
  1. Unplug the TV for at least 15 minutes
  2. Plug it back in and you'll be prompted to go through the initial setup just like when the TV was new.
If after that you still have no HDMI function on any of the inputs, that would indicate the set needs some service by a technician.
Good luck.
Mar 21, 2015 | Panasonic Televison & Video
5 year old plasma panasonic tv 42 " hdmi port not longer working, How to fix
hi you could try firmware update try the panasonic website hope it helps
regards
shaun
Nov 23, 2013 | Panasonic VIERA TH-42PX80B 42 in. Plasma...
Xbox 360 with HDTV (Panasonic plasma TV) help!!
It sounds that the video settings to TV should be checked. Refer its user manual for details.
Jun 16, 2013 | Panasonic Televison & Video
I have a 2008 46 inch Panasonic Plasma. Whenever I try to turn on the tv within an hour of turning it off, the tv doesn't turn back on and the power light blinks. To get the tv to turn on I h
I will be the barer of bad news. your Panel is failing. Plasma TVs are only made to last 5-7 years. 10-12 is more realistic from what I have seen. The TH46pz85u is a great model of TV but when that starts happening it means the panel is beginning to fail. Replacing the panel is cost prohibitive and they don't even make them anymore.
You will be wise to spend your money on a new TV. newer TV's are much more power efficient as well. your 46" TV draws a lot of electricity. Your TV draws almost 650Watts of power. A comparably sized TV today(55" or larger) Draws around 200 watts. Significantly less.
Jan 10, 2018 | Panasonic Viera TH-46PZ85U Plasma TV
How to put input on a samsung plasma? I have a samsung plasma and I am trying to connect an Xbox, can someone help?
you will have to use component cables with rca's
from xbox plug to rca to plasmas component input
use your plasmas remote to locate a channel to tune int channel o your xbox,when you turn on xbox the start screen should show,dont need a disk for tuning just playing
go forth and have fun .
Cheers MISTERDJ
Apr 11, 2010 | Samsung (TN-RBNG10) TV Input
Plasma screen
do you have the swich on the back of the xbox plug set up for reg tv? Does it work in that mode with just the red, yellow and white wire in the side AV slot? If you were using the xbox on another tv its possible you modified the display settings in the menu. Try hooking it up to a standard tv and reset the setting to default then try rehooking it up to the plazma.
Joe
May 20, 2009 | LG 42PC1D 42 in. Plasma Television
No screen saver
depending on your tv there is a function to turn screen off. most tvs come with this feature. on the remote there will be an power key with a red or black button. this is to turn the screen off. if it does not have this function and there is no screen saver setting on the dvd play there is not much you can do for this situation .
Jul 05, 2017 | Panasonic DVD-S97 DVD Player
Green interference on Panasonic TH-PX75U
Since the set is only 8 months old, it should still be under warranty. This may only be an internal connection problem, but opening up the unit will void the warranty. I would suggest that you call for warranty service. This is a problem with the set and has nothing to do with external devices or interference.
Keep us posted.
Dan
Jul 10, 2008 | Panasonic VIERA TH-65PV500 65 in. Plasma...
Panasonic Viera TC-P50S1 Logo
52 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
