Question about Electronics - Others
How to do callipration
If the device need (call..)what we do ?
I need to reset my ipad, and I forgot my passcode.
If you have synced your device with iTunes, you can restore your device.
  1. Connect the device to the computer you normally sync with.
  2. Open iTunes. If iTunes asks you to enter the passcode, try another computer that you've synced with.
  3. iTunes will automatically sync your device and create a backup. If it doesn't,sync the device with iTunes.
  4. After the sync is complete, restore your device
    • DANGER THE FOLLOWING WILL ERASE EVERYTHING
You'll need to put your device in recovery mode, which will erase the device and its passcode. Then you'll restore your device as new or from a backup.
  1. Disconnect all cables from your device.
  2. Turn off your device.
  3. Press and hold the Home button. While holding the Home button, connect your device to iTunes. If your device doesn't turn on automatically, turn it on.
  4. Continue holding the Home button until you see the Connect to iTunes screen.
  5. iTunes will alert you that it has detected a device in recovery mode.
  6. Click OK, then restore the device
Oct 27, 2014 | Computers & Internet
Device cannot start code 10
Device cannot start code 10 means that you are using the wrong drivers for the device or the device has a problem try using system information for windows to find out what drivers it needs if that is the problem but if not the device might need replacing
Aug 03, 2013 | ASUS Computers & Internet
While using Bluetooth I hit forget this device. I need to use the device now but it won't recognize it. How do I reset the Bluetooth?
Easy; Go to settings and tell the device to scan for devices. Obviously make sure the device you want to use is turned on first and all going well, your phone will tell you your ready to use that pareticular bluetooth device. Good Luck. George
Mar 30, 2013 | Apple iPhone 3G
Just got speakers no sound computer says no auto device is hook up
You need to install the drivers for the AUDIO device.... not your speakers. Go to control panel... Device Manager and look at the list of devices that is your computer. There should be a multimedia device that you'll need to update the driver for. You can do have it find the device automatically online. If the automated way doesn't work, you'll need to know exactly what sound card/device that you have.
Aug 04, 2011 | Kinyo Audio Zone 2.0 Sound System Computer...
I cant connect the usb from machine to computer i have windows 7 any answers
You need to open Control Panel, Device Manager and observe what happens when you connect your device to the machine. If you get a yellow triangle next to a device in the Device Manager, right click on it and choose Properties. You will know what the problem is from there, usually it is a driver problem.
You may need to download drivers for your device because Windows cannot find them, or you may need to delete the devices from Device Manager and let Windows discover them afresh from the Actions menu, Scan for hardware changes.
Jul 22, 2011 | Computers & Internet
I need to connect a bluetooth to my razr
Do you need to connect a bluetooth headset , or do you need to start bluetooth file transfers?
In either case, to activate blue tooth on the RAZR V3i go to settings>connections>bluetooth (May appear as "bluetooth link") > hands free> look for device. The Razr will scan for other bluetooth devices. If you need to send files over bluetooth, turn on the blue tooth antenna, and navigate to the files you wish to send. Press the menu button, and press "copy" and select the device you wish to send it to in the devices list. If there is no device, or the device you with to send it to is not in the list, press "look for devices".
Mar 28, 2011 | Motorola Mobility RAZR V3i Cellular Phone
I need my smart movie 4.0 license key my device serial number is
my device serial number is 355718022288839 i want to
Jun 29, 2009 | Gund Gobbles Thanksgiving Hoedown Musical...
Cannot get my USB memory stick to install on XP
I have a sandisk cruzer, titanium 512mb. Model: SDCZ3 512 I have used this to store massive amounts of data that I frequently need to access. Recently, when I plugged the device into my computer's USB, I received the following message: "USB Device Not Recognized" After double clicking on this message, I got the USB Root Hub. The last item on the tree stated: "Unknown Device." I double-clicked on the unknown device, and in the Device Status box, received the following message: "No Drivers installed for this device. If you are having problems with this device, click Troubleshoot to start the troubleshooter." I attempted to troubleshoot, but the device remains unrecognized. How can I access the data I have stored on this device? I have even tried to install the drivers automatically, but it would not istall succesfully.
xolani.
Feb 02, 2008 | SanDisk 1GB Cruzer Titanium USB Flash...
I need a manual with the progamming codes for a Sanyo tv
I don't have a code book for you, but I can tell you how to program the RCR660 using the automatic programming feature.
Programming RCA model RCR660 (no code search button)
While following these instructions, keep the following in mind:
device = the component you wish to control with your remote (TV, DVD, VCR, etc.)
DEVICE = the button labeled for the component you wish to program
1. Turn on the device you wish to program.
2. Turn off all other devices in the general vicinity.
2. Press and hold DEVICE
3. While holding DEVICE down, press ON/OFF and hold them both down until the LED turns on for that device.
4. Release both buttons.
5. Point the remote at the device, press and release PLAY and wait 5 seconds or until the LED stops flashing.
6. If the device does not turn off, then continue to press PLAY and wait the required interval (for a maximum of 20 times) until the device turns off.
7. When the device turns off, press REVERSE, wait two seconds and continue doing this until the device turns back on.
8. To finish programming, press and hold STOP until the LED turns off.
Dec 22, 2007 | RCA RCR660 Remote Control
Electronics - Others Logo
Top Electronics - Others Experts
Are you an Electronics - Other Expert? Answer questions, earn points and help others
