Question about Hunter Televison & Video
Where to purchase jumpers
I have a 85094-01 remote and the jumpers are broken. Where can I purchase them?
Remote wires
you may have a broken spot in your wire where it has been kinked, or stretched. use a new piece of wire, and it will be fine.
Nov 20, 2011 | Car Audio & Video
Remote is broken and tv wont turn on with button on side, just keeps turning itself off
The best solution for you would be to purchase a new remote control.
You can contact the manufacturer of your TV directly to arrange purchase of a remote or you can go in to an electronics store and purchase a universal remote for less than $10. With a universal remote, you need to do a code search and program it in, but it can do most basic functions of your tv.
Mar 07, 2011 | Televison & Video
Light comes on all by itself
You are probably picking up some kind of radio interference that is causing the receiver to think a remote has sent it a signal. A possible solution to this issue is to change the frequency that the remote uses to communicate to the receiver to turn the fan or light on.
I have had the same problem with the light coming on intermittently by itself. At first I also could not change the settings and have the remote work with the new settings. But I found out that when you change the dip switch of the receiver you must turn off the power using the wall switch or the circuit breaker and turn it back on before the receiver will use the new dip setting. I am still waiting to see if the light will come back on after changing the dip switches from 1-on, 2-on, 3-on, 4-off to 1-off, 2-on, 3-on, 4-on and the remote's jumpers from 1-jumpered, 2-jumpered, 3-jumpered, 4- no jumper to 1-no jumper, 2-jumpered, 3-jumpered, 4- jumpered.
These directions are for the Hunter 27157 model.
Aug 12, 2010 | Hunter 27185 Remote Control
Freedom Combi inverter/charger stopped working with the remote inside the RV. Replaced remote but still didn't work. I have to press inverter button inside RV, go to inverter outside RV and press...
Sounds like the link between the inverter and the remote is bad. Chaffed wire, broken wire, etc may be the culprit.
You should still have the shorting jumper that came with the Freedom. Put the jumper into the AUX port, and you should now have local control of the inverter. If so, then replace the wiring between inverter and remote.
Aug 08, 2010 | Xantrex Technology Xantrex 458 10 12...
Broken remote circuit board
Very few people could pull off the repair you describe. For about twenty bucks you can purchase a new universal remote.
Apr 30, 2009 | Televison & Video
Need a replacement remote
Hey,
yes you can purchase a replacement remote but not from fixya, can you tell me the brand and model of your device and I'll look up a replacement for you.
Thanks,
Ekse
Feb 21, 2009 | Televison & Video
Broken remote
It may be possible to purchase the remote for a particular model as a spare part.
Another option is to repair the remote if you still have it. If you know any basic electronics you could check my blog: http://www.instructables.com/id/Repair-your-remote-controls/.
Third option is to buy programmable remote which are generally cheaper than the first option
Jan 02, 2009 | Philips RC2573 Remote Control
Televison & Video Logo
16 people viewed this question
Top Hunter Televison & Video Experts
Michael Vanidestine
Michael Vanidestine
Level 1 Expert
Henry  Thomas
Henry Thomas
Paul Bade
Are you a Hunter Televison and Video Expert? Answer questions, earn points and help others
