Question about Kenmore 98702 Stacked Washer/Dryer
Motor centrifugal switch bad
My manual schematic for 2004 GE dryer model dsxh43ea3ww states "when motor runs and problem is NO HEAT Replace motor centrifugal switch.  The switch has 2 star screws attached to the motor, unable to locate one except through GE for 291.00 dollars.  Not a misprint, where can I buy new or even used.
Christian McGinn
Santa Rosa CA
  • 58 Answers
You cant get the switch seperate for that motor, you have to get a whole new motor.
Posted on Oct 31, 2007
Why want this dryer stay on ?
you have a bad belt switch,if the dryer stays running while you hold the start button on and stops when you release the button its the belt switch part WD21X10261 i've seen this a few times,go here and look at part 803 this is the bad part.
www.searspartsdirect.com/model-number/DPXR473EW0WW/0432/0151200.html
Oct 03, 2017 | GE Dryers
I have a GE Electric Dryer model DPVH880EJMV. It stopped working and displays error code E12 - "Motor is not rotating or centrifugal switch is bad". Anyone run into this issue before or have a fix?
Jeff,
If your centrifugal switch is bad, more than likely you are going to need a new motor because those are built into the motor. The only other thing to check is to find out if you are actually getting power down to the motor. If you are, then motor problem, if not, then something else is bad that is not letting the current get to the motor. If you can find your wiring diagram, you should be able to find which wires deliver the current to the motor and you can back track to see where you lose the current. Hope this helps!
Jun 05, 2015 | GE Dryers
GE dryer model dwsr405eb0ww has intermittent heat problem associated with centrifugal motor switch. Interior drum light goes off with door open when centrifugal switch disengages. This is intermitte
First thing I would do is un-plug the product and remove the line cord access plate and check the terminal block/cord connections, a lot of times the installer of the product does not get the terminal block 'nuts' tight enough and it either burns up or cause erratic operation. If this checks out ok check your home electrical supply system.
Jan 09, 2015 | GE Dryers
Why does dryer only runs as long as start switch is depressed?
You give no information regarding make or model, but I believe you will find that the "run switch" on the motor is not working. This is a centrifugal switch located in or attached to the motor. With make and model, one could track down the part and replace it.
May 08, 2014 | GE GTDP300EMWS Dryer
No heat,but motor runs and drum turns
heating element is bad. check that the heat sensor is getting power. if it is getting power it is the element. if it is not getting electricity it is the unit
Apr 05, 2014 | GE Clothes Dryer Motor Centrifugal Switch...
Not drying
Runs but will not heat
1.loose wiring--check terminals & wiring
2. Defective thermostat--replace thermostat
3.defective centrifugal switch in motor--replace switch (check linkage to motor)
4. Defective timer--replace timer
5. Open heater element---replace heater element
6. Heat switch set to off----set switch for desired heat
Sep 22, 2011 | Bosch Nexxt WTMC 3300 Electric Dryer
The timer didn't lose ant time off of it and the dryer didn't get warm at all? What is the problem do you think?
Dryer will not run
1. No power--check fuse & power supply
2. Loose wiring--check terminals & wiring
3. Door switch--make certain door closed properly to actuate switch
4. Defective motor---check motor.
5. Defective timer---replace timer
Sep 21, 2011 | Kenmore Dryers
The dryer runs without the start switch being used.
Good day,
The dryer start switch, starts the motor by bypassing the centrifugal
switch built into the motor. Once the motor is running, releasing the switch doesn't matter because the motor gets it's power directly from the timer to the motor thru the centrifugal switch.
Either the switch on the consul has welded the contacts, or the centrifugal switch in the motor has done the same.
To test, unplug, and access the start switch. remove one of the wires from the switch, tape it to prevent shorting, and try the dryer. If it fails to start, then it is the switch.
If it still does the same thing as before, it is the centrifugal switch in the motor.
Dec 22, 2009 | GE Dryers
My ge automatic dryer model ddp 1275 c willnt
Sounds like motor trying to start. Simplest answer is article of clothing caught in the blower wheel and thus keeping motor from turning. Second is motor switch mounted to motor is bad. Not all dryers replace motor switch separately from the motor. Third, is the motor which contains a new centrifugal start switch with it.
Aug 19, 2009 | GE Dryers
Element does not turn off.
  • actually is sounds like the centrifugal switch in the motor is bad.
  • the element should not turn on unless the motor is running.
  • the thermostats are in place to pick up the heat of the airflow, not necessarily the heat directly coming from the element.
Jul 01, 2008 | GE DCSR483EA Electric Dryer
Kenmore 98702 Stacked Washer/Dryer Logo
461 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
