Question about Canon MP18D II Basic Calculator
Won't run change ribbon then tape would not feed through.
Typewriter repair manual
I just replaced a ribbon in a 3500 IBM wheelrider ribbon with the following product which is supposed to be combatible.
DataProducts Compatible Typewriter Ribbon
Dataproducts Lift Offf Tape Catridge
I had no problem istalling the tapers, forwarded the ribbon as instructed, but when I type no tryping appears on my paper.
Aug 22, 2014 | IBM Typewriter Wheelwriter III 3 with 2...
What's your problem?keys typed are not the same as what's printed on paper. this after changing the ribbon
First be sure yhe ribbon and L/O tape are not obstructing the print wheel. The wheel will home itself on power up but if it gets interfeared with it won't reset without power off and on.
DickyO
Oct 11, 2011 | Brother GX-6750 Typewriter
For ZM400 and S4M, Has anyone had any luck with printing a white ribbon and a black or dark label without covering up the ribbon sensor with electrical tape? Isn't there a setting that can be...
You can try this: on the S4M, you can press the Menu key to go into setup mode. Under password level 3 parameters,there is a setting for ribbon which by default is set to Yes thermal trans. If you set it to No for direct thermal mode, this will in effect turn off the ribbon sensor. The printer won't stop now if it runs out of ribbon but usually you are there when printing to see that the ribbon is running out.
On other Zebras, you can turn down the sensitivity of the RIBBON LED sensor but the S4M doesn't have that setting.
See if that helps.
Jun 20, 2011 | Zebra 203DPI Printer
How do you put in the correction tape in the brother A X--425
The correction tape feeds the same direction as the ribbon, andI think it only goes on 1 way. The tape goes in front of the ribbon.
Jan 25, 2011 | Brother ® Starter Kit for AX, GX, SX and...
How to change the correction tape?
Changing the Correction Tape
1) Move the print carrier to the center of the platen using the SPACE or BS key.
2) To replace the correction tape, lift out the typing ribbon cassette (see Changing The Ribbon Cassette) and remove the two spools of the lift off tape by pulling them outwards.
3) Place the empty spool of new tape on the left pin so that the tape winds clockwise. Place the tape around the left guide. Pull the tape around the right
guide and place the loaded spool on the right pin so that the tape unwinds counter-clockwise.
Note: Make sure the sticky side of the tape is facing the platen.
4) Manually turn the left-hand spool in the clockwise direction, tightening the tape until resistance is felt.
5) Replace the typing ribbon cassette.
6) Press the CODE + = (SETTING) key.
Changing the Ribbon Cassette
2) Hold the ribbon cassette on both sides and lift up the front portion (where the ribbon is exposed) to remove the cassette.
3) To insert a new cassette, place the back end of the cassette on the cassette
holder on the carrier and gently press down on the front of the cassette unit it clicks into place.
4) Turn the ribbon feed knob counter-clockwise again to take up any slack in the ribbon.
5) Presss the CODE + = (SETTING) key.
Good Luck!
Oct 13, 2010 | Smith Corona Wordsmith 100 Typewriter
How do i change the tape on it?
This machine uses the Brother TZ tape, which is available in a variety of colors and three widths (1/4" (6mm), 3/8" (9mm) and 1/2" (12mm)). A TZ tape is supplied with this machine.
1 Press in on the rough area at the top end of the machine and fold open the back cover. Should be the exact process as loading batteries.
2 If a tape cassette is already installed, remove it by pulling it
straight up.
3 If the ink ribbon in the other tape cassette is loose, use your finger to wind the toothed wheel in the direction of the arrow on the cassette until there is no slack in the ribbon. Also, make sure that the end of the tape feeds under the tape guides. Note: If you are using a new tape cassette provided with a stopper, be sure to remove the stopper.
4 Insert the tape cassette firmly into the compartment, making sure that the entire back of the cassette contacts the bottom of the compartment. Note: When inserting a tape cassette, make sure that the inner ribbon does not catch on the corner of the metal guide.
5 Securely close the back cover, making sure that it snaps into place.
6 Feed the tape by holding down CODE and pressing PRINT once, and then push in the tape cutter lever to cut the tape.
You can also get a copy of the user's guide here.
Thank you for using FixYa! Don't forget to rate our service.
Feb 10, 2010 | Brother P-Touch 1180 Label Printer
Installed a corrective ribbon on a SL480 typewritter, now I can't get the ribbon back on.
Sounds like the correction tape is not installed properly. Try remving and reinstalling it again. Make sure the hammer solenoid assembly is latched to its home position. After installin the correction tape you can manually operate the lift arms to check the feeding of the tape. If you have a loca dealer you can probaly take your machine to them and they may install the tape for you at no charge.
Nov 15, 2009 | Smith Corona Office Equipment & Supplies
Lift off tape
Does the tape lift up far enough for correction? If so check to be sure the dull side of the tape is facing the paper. Then be sure you are using a correctable ribbon, the feed wheel should be either yellow or orange. DickyO
Jun 02, 2009 | Brother GX-6750 Typewriter
How to open to change ribbon on a Canon mp25dv
Remove the paper tape by pulling it back out of the calculator.
Feel along the back of the calculator right below where you insert the paper tape for a ridge. Gently lift up on this ridge and a plate will lift out of the machine exposing the ribbon.
Make a note to yourself as to how the old ribbon is in the machine before removing the old ribbon. Just gently lift straight up on both of the spools and the ribbon will lift out of the machie.
When you insert the new ribbon make sure that the ribbon is feeding off of the back side of both spools. You can use a small screwdriver or toothpick etc to position he new ribbon to keep the ink off of your fingers. Make sure the new ribbon feeds around the plates on both sides of the machine and it fits behind the roller that has all the numbers on it and that the red portion of the ribbon is on the bottom.
Take the plastic plate that you removed first and insert the tabs in the front underneath edge of the case on the front and gently push the back side of the plate straight down till it smaps into place.
Refeed the paper tape back into the machine and you are finished!
Hope this helps.
Apr 20, 2009 | Canon MP-25DV Calculator
Correction tape problem IBM Selectric II
Take off the ribbon, just inside the rt. side frame of the printer is the mech. for L/O feeding. There is an arm that moves back and allows the feed to ****, that mech. is probably gummy, lube with some WD40 on both sides of the printer (the left side sets up correction lifting.
DickyO
May 19, 2008 | Lexmark Wheelwriter 15 Series II...
Canon MP18D II Basic Calculator Logo
43 people viewed this question
old marine
old marine
