Mitsubishi gto 1991 not changing gear a/t temp light on
The car will not change gear the a/t temp light is on
  • 5 Answers
SOURCE: gear change
You need a new gearbox
Posted on Jun 06, 2008
  • 51 Answers
SOURCE: Mitsubishi gto kangaroo jumps when i accelerate
i would say your valves or valve guides are going out and need replaced, or your vacuum advance needs changed
Posted on May 07, 2009
  • 18 Answers
SOURCE: 1991 ford thunderbird automatic and i cant change
SOUNDS LIKE YOUR SHIFT CABLE IS BROKEN TAKE YOUR CENTER CONSLE APART BY THE SHIFTER AND YOU WILL SEE A CABLE THAT IS CONNECTED TO YOUR SHIFTER MOVE YOUR SHIFTER BACK AND FORTH AND YOU SHOULD SEE YOUR PROBLEM.
Posted on May 18, 2009
  • 5 Answers
SOURCE: changing door mirrors on Mitsubishi gto to folding type
Try gtouk.com or 3si.com as it isn't that simple as you need 2 extra wires running to your door and extra relays to control the folding action.
Posted on Feb 05, 2010
postings909
  • 130 Answers
SOURCE: I need a diagram of timing belt for 1991
here it is let me know ist the wrong one, i cand send it to you also, im not sure which motor you have on that car theres 4 diffrent engines, this is the most common but be sure., its the V6
Posted on Aug 02, 2010
91 mitsubishi gto has random engine cut out.
Does this car have its original ECU? I ask this because this and a number of early 1990s Mitsubishi cars/truckas had isses with capaciors leaking. In truth I believe it is a matter of when and not if. As the ECU begins to fail the engine can begin to run poorly ( I speak from experience after changing both ECUs in my Montero and my son's Doge Stealth (3000GT) ) I did have an issue too with my son's Stealth running poorly, by good luck I happened to be looking under the hood with poor lighting and noticed a faint blue spark from the wiring leads by the coil after a good look I fould a wire would ground out when the engine was throttled; this caused the engine to torque slightly causing the wire to rub and finally ground out.
I hope this may have helped,
Tom
Oct 10, 2009 | 1991 Mitsubishi 3000GT
My turbo gto manual crunchs in ta 3rd evry time
if it only has problems going into 1 gear, it's most likely the synchro for that gear inside the transmission. but if this appeared out of thin air immediately after the hydraulic change, then i would definitely try re-bleeding the system first
Sep 29, 2009 | 1991 Mitsubishi 3000GT
Cant get 1st gear. 2nd gear nosiey and crunches, 3rd 4th 5th work but wine alot, reverse works fine. reverse lights stay on when driving. car is a mitsubishi gto twin turbo AWD 1991 plate.
Sorry but it sounds like it is trassmission time. you see the 3-5 gears work on another ration thatn 1& second they are on one shaft. the reverse is off in another world. sounds like one of the rods go stuck this is why the reverse lights stay on...
Hold your breath. It will be expensive but then on a manual I would see if the repair shop will find a used tranny. for 1/2 the cost..
Aug 03, 2009 | Mitsubishi 3000GT Cars & Trucks
Changing door mirrors on Mitsubishi gto to folding type
Jul 16, 2009 | 1991 Mitsubishi 3000GT
1991 gto non turbo
clogged fuel filter, or a short in your computer
Jun 30, 2009 | 1991 Mitsubishi 3000GT
May 07, 2009 | 1992 Mitsubishi 3000GT
HI I HAVE A MITSUBISHI GTO 1991 AND NEED TO KNOW ABOUT ALARM
i think this is a sensor, but cannot remember what for, mine never lit up,either, the car drove well and i never worried about it, it may be for climate control. sorry but this is all i can recall,
Jan 24, 2009 | 1991 Mitsubishi 3000GT
My 3000gt is stuck in 3rd gear why? this is a automatic
Your transmissions need to be service (fluid and filter change) and possibly a TCU replacement. Do NOT go to a dealer. Instead, look on ebay or craigslist for part outs. Transmission control units can be expensive but that is most likely the problem if you already changed ur fluid.
Dec 11, 2008 | 1991 Mitsubishi 3000GT
Gear change
Jun 03, 2008 | 1991 Mitsubishi 3000GT
Televison & Video Logo
29 people viewed this question
Top Televison & Video Experts
Electro Med Services...
